Blueadventures Posted October 18 Posted October 18 9 hours ago, Moneybox said: I've bought an industrial Wagner airless spray gun. We used to use a similar Graco back in the 70's for applying marine coatings. They say it won't give the fine gloss finish of a regular spray gun but there's no overspray. I actually bought it to paint the old 1910 house that we've now sold without using the spray gun but I'm eager to give it a go. I think the choice of coating will determine the finish more than the gun used. Select the paint then get the right spray gun and a compressor that gets right pressure and volume. You don’t want to muck up the finish and need a gloss finish. Cheers and look forward to seeing the painted bird. 2
danny_galaga Posted October 18 Posted October 18 18 hours ago, Marty_d said: Beautiful day down here today. Low 20's but feels hotter, no wind. Good day to test the inflatable spray booth I bought in winter and haven't unpacked since. Second hand, never used. All went well - the two pumps work great, the whole thing was up in about 5 minutes. Windows have removable panels with filters and the whole inside is pressured by the small pump, so you don't get any nasties coming in. The booth has clear windows, skylights and loops to hang LED strips, so will get a couple of those too. Will probably need to bring down extension cords from two different circuits. Both fans went off one, but I wouldn't like to add a compressor as well. I have the quote for all the paint and accessories. Will set up some racks / tables for the smaller bits. Measured the interior of the booth while it's up, the main room is 6m long and my plane is 5.9m from prop to end of fuselage. 😄 Masses of space inside, it's about 4m wide so there's room to get around the plane. Didn't measure the height but they're advertised as 3m. Even managed to get it back in the bag afterwards, which I consider the crowning achievement! Will also buy some tent pegs and guy ropes before I put it up again. It was fine today but any wind on it and it'd want to run away. I love jumping castles 🏰 1 3
Moneybox Posted October 18 Posted October 18 If you are not a painter then I suggest you find some old panels for practise, car door or bonnet, old washing machine or similar. You don’t have to mess up your new booth, just practise/learn outside. 1
skippydiesel Posted October 18 Posted October 18 Check out the Stewart Paint System - follow the instructions to the letter and you will surprise yourself at how good the finish is. https://stewartsystems.aero/ 😈 1 1
BrendAn Posted October 19 Posted October 19 22 hours ago, Moneybox said: I've bought an industrial Wagner airless spray gun. We used to use a similar Graco back in the 70's for applying marine coatings. They say it won't give the fine gloss finish of a regular spray gun but there's no overspray. I actually bought it to paint the old 1910 house that we've now sold without using the spray gun but I'm eager to give it a go. I think the choice of coating will determine the finish more than the gun used. They are for painting fences and houses. You would lay on far too much paint for an aircraft. Blue adventures advice is good. Buy the right gear.. 3 3
Moneybox Posted October 21 Posted October 21 I like this setup but you might want to consider static charge while painting. A nice spray mist of a highly flammable substance and a static ignition source and you might have more excitement than you wish for. 1
skippydiesel Posted October 21 Posted October 21 4 hours ago, Moneybox said: I like this setup but you might want to consider static charge while painting. A nice spray mist of a highly flammable substance and a static ignition source and you might have more excitement than you wish for. The Stewart System is: Water born - so fare less flammable and toxic than standard two pack paints Low Pressure/High Volume application - very little "mist " most of the paint hits the target,rather than drifting of into the environment. I purchased the right "gun" & compressor to suit. Not every compressor will deliver sufficient volume of low pressure air 25 psi (from aged memory) There may be other similar products. 😈
BrendAn Posted October 21 Posted October 21 6 hours ago, Moneybox said: I like this setup but you might want to consider static charge while painting. A nice spray mist of a highly flammable substance and a static ignition source and you might have more excitement than you wish for. I think the airflow would maintain a mixture to lean to ignite. Thousands of spray booths used every day you would think they are safe.
Blueadventures Posted October 21 Posted October 21 6 hours ago, Moneybox said: I like this setup but you might want to consider static charge while painting. A nice spray mist of a highly flammable substance and a static ignition source and you might have more excitement than you wish for. Wear cotton.
skippydiesel Posted October 21 Posted October 21 (edited) I wore disposable hooded overalls. Light weight, comfortable to work in, no washing and cheaper to purchase than cotton etc. I modified an engine stand as a wing jig that could be rotated, so that both sides could be painted in the one job (rather than paint one side - dry - flip - paint the other). The fuselage underside was painted by temporarily modifying, using a hydraulic elbow, my paint gun reservoir, to sit near vertical with the gun pointed up. I painted lying on my back. 😈 Edited October 21 by skippydiesel 2
Moneybox Posted October 21 Posted October 21 3 hours ago, Blueadventures said: Wear cotton. I was thinking more of the all plastic environment, nothing sitting on a concrete floor.
Marty_d Posted October 21 Author Posted October 21 10 hours ago, Moneybox said: I like this setup but you might want to consider static charge while painting. A nice spray mist of a highly flammable substance and a static ignition source and you might have more excitement than you wish for. Ground strap? But from where? 2
Marty_d Posted October 22 Author Posted October 22 Public holiday here today, so spent the day installing the port flaperon control rod cover. 64 rivets - not sure why I didn't fire up the compressor, stupidity may be a factor... 3
BrendAn Posted October 22 Posted October 22 Marty, are you going to treat the inside with alodine, the green stuff the aviation workshops use. I think that's what it's called. 2
facthunter Posted October 22 Posted October 22 Alodine and alumiprep it's called. It leaves it a yellow colour I think. I still have some I got from Aviall. You would be well advised to use it.. Nev 1
Marty_d Posted October 22 Author Posted October 22 37 minutes ago, BrendAn said: Marty, are you going to treat the inside with alodine, the green stuff the aviation workshops use. I think that's what it's called. I don't think so. The alloy is 6061-T6 which has anti corrosive properties. The L4 who has done 2 inspections has advised me to get some Cor-Ban spray and give enclosed areas a blast with that (I did buy some but turns out it was the wrong type). 1 1
Marty_d Posted October 22 Author Posted October 22 1 hour ago, sfGnome said: So which is the right type? Not the one that's designed for wiring, apparently 😄 2
Marty_d Posted November 19 Author Posted November 19 Santa delivered early this year – a pair of nav/strobe tip lights for my plane. (Ali Express, $238). Yesterday I drilled the 14mm holes in the tips to take the wires, then felt around thru the hole for the string I’d left inside conduit running the length of the wing (for the express purpose of pulling through wires, if I ever decided to use tip lights). One wing worked beautifully. Found the string, pulled it through the hole, tied a nut to it to keep it hanging there, went to the wing root and tied another nut to that end to keep it hanging. The other wing – not so good. I found the string and pulled it through. Unfortunately, I pulled it a bit far… not realising that at the root, the string had come loose from the tape that secured it to the root rib, so as soon as I pulled it out of the tip, the other end disappeared into the conduit. Bugger!! The conduit is very small – around 8-10mm ID, corrugated lightweight stuff. Held securely to the nose ribs through the lightening holes by metal cable clamps riveted to the ribs. Absolutely no way it was coming back to the wing root end. Next I attempted to use wire from the wing root end to snake through the conduit. No luck, as soon as it hit the first bend in the conduit it refused to go any further. Tried a thinner wire with similar results. (Unfortunately I can’t go from the tip end, because the only access is through that 14mm hole – and that end of the conduit is hanging down after the last rib). After discussing with my wife, she thought it might be the sharp end of the wire not making the turn, so maybe I should put a knob on it. (Stop your sniggering, you filthy lot) Going through her jar of assorted buttons and beads, I found one which looked the right size. Drilled a hole in it, pushed the end of the wire in, and fed it into the root end of the conduit… Where the bead, obviously being JUST the right size, jammed in the end of the conduit and pulled out of the wire as I withdrew it. So now it’s not only string-less but blocked! Anyway, lots of thinking and a fair bit of swearing later, my only option is to remove the plastic wingtip, feed wire through from the tip end, and hopefully get all the way to the root and push the damn bead out. If that doesn’t work, at least I’ll have access to the LE lightning holes so I can feed the wires down that with something long and straight! So now I have to drill out 24 rivets. Easy job, only I don’t have any more Avdel Avex 1/8” rivets to replace them. So on to Aircraft Spruce Australia this morning where luckily they have some in-country, and placed an order for 300 so I have some spares… Now they just have to arrive before I do the painting next month! Ah the joy of building a plane. 4 1
BrendAn Posted November 19 Posted November 19 18 minutes ago, Marty_d said: Santa delivered early this year – a pair of nav/strobe tip lights for my plane. (Ali Express, $238). Yesterday I drilled the 14mm holes in the tips to take the wires, then felt around thru the hole for the string I’d left inside conduit running the length of the wing (for the express purpose of pulling through wires, if I ever decided to use tip lights). One wing worked beautifully. Found the string, pulled it through the hole, tied a nut to it to keep it hanging there, went to the wing root and tied another nut to that end to keep it hanging. The other wing – not so good. I found the string and pulled it through. Unfortunately, I pulled it a bit far… not realising that at the root, the string had come loose from the tape that secured it to the root rib, so as soon as I pulled it out of the tip, the other end disappeared into the conduit. Bugger!! The conduit is very small – around 8-10mm ID, corrugated lightweight stuff. Held securely to the nose ribs through the lightening holes by metal cable clamps riveted to the ribs. Absolutely no way it was coming back to the wing root end. Next I attempted to use wire from the wing root end to snake through the conduit. No luck, as soon as it hit the first bend in the conduit it refused to go any further. Tried a thinner wire with similar results. (Unfortunately I can’t go from the tip end, because the only access is through that 14mm hole – and that end of the conduit is hanging down after the last rib). After discussing with my wife, she thought it might be the sharp end of the wire not making the turn, so maybe I should put a knob on it. (Stop your sniggering, you filthy lot) Going through her jar of assorted buttons and beads, I found one which looked the right size. Drilled a hole in it, pushed the end of the wire in, and fed it into the root end of the conduit… Where the bead, obviously being JUST the right size, jammed in the end of the conduit and pulled out of the wire as I withdrew it. So now it’s not only string-less but blocked! Anyway, lots of thinking and a fair bit of swearing later, my only option is to remove the plastic wingtip, feed wire through from the tip end, and hopefully get all the way to the root and push the damn bead out. If that doesn’t work, at least I’ll have access to the LE lightning holes so I can feed the wires down that with something long and straight! So now I have to drill out 24 rivets. Easy job, only I don’t have any more Avdel Avex 1/8” rivets to replace them. So on to Aircraft Spruce Australia this morning where luckily they have some in-country, and placed an order for 300 so I have some spares… Now they just have to arrive before I do the painting next month! Ah the joy of building a plane. Do your strobes still use the control box or is it all in the light itself these days. I have wingtip strobes that are wired to the strobe unit inside. I don't know what it's called. 1
Marty_d Posted November 19 Author Posted November 19 1 hour ago, BrendAn said: Do your strobes still use the control box or is it all in the light itself these days. I have wingtip strobes that are wired to the strobe unit inside. I don't know what it's called. All in the lights. Just have to wire to each other, the switches and the fuse. 1 1
Moneybox Posted November 19 Posted November 19 (edited) Marty, What if you found a plastic bead a little smaller than the tube. Put some fishing line or similar into the bead knotted then give it a blast of compressed air to shoot it through your conduit. Phil Edited November 19 by Moneybox 4 1 1 1
Thruster88 Posted November 19 Posted November 19 Or use a vacuum cleaner to suck the string through. 3 1 1
Marty_d Posted November 19 Author Posted November 19 4 hours ago, Moneybox said: Marty, What if you found a plastic bead a little smaller than the tube. Put some fishing line or similar into the bead knotted then give it a blast of compressed air to shoot it through your conduit. Phil Great idea, when I can access the other end I'll give that a try.
