facthunter Posted 7 hours ago Posted 7 hours ago Has voltage drop got much significance over say 12 feet in an aircraft? Most of the distances are Much Less. We used to have Cars with 6 Volt systems. Big current users can have relays. Earth wires don't need to have Insulation. Nev
Marty_d Posted 6 hours ago Author Posted 6 hours ago (edited) On 24/11/2026 at 3:41 PM, sfGnome said: Marty, apologies if this is all obvious, but just in case it isn’t… Looking at the curves for the tyco W23 and W31 breakers, you need to take into account the ambient temperature and the amount of overload. At an ambient of 40C, the breaker is derated to 87% of nominal, and at 0C (pleasant Tassie weather), it goes in the opposite direction to 120% of nominal. So, with no margin, for a 5A draw, you need at least a 6A device so it doesn’t pop off on hot days, so let’s say use a 7.5A unit. Sounds ok, however… On a cold day, its nominal breaking point will be 9A. Fine if you have a short circuit, but what if the lamps fail to a mode where they just draw a greater than normal current (they’re solid state - it can happen). Now we run into the time-vs-current graph. At 135% of nominal (which is now 9A because it’s a cold day), the breaker will take an hour (yes, you read that right) to trip, meaning that the wiring will be possibly carrying 12A continuously for that hour. This is where wire size and connector rating comes into it. The issue with wire size is not its fusing point; it is its heating profile. For instance, an 18G wire (in free air) with 12A continuous will have a temperature rise of 30-50C. Wrapped in a bundle in a conduit will get hotter, but given that you’re using tefzel wire and we started with an ambient of 0C, that’s no problem at all. With 18G cable at normal operation (5A), the voltage loss across (say) 9m of cable (ie out to the light and back) will be in the order of 1V, which may or may not dim your lights a bit, depending on how they are designed. Any connectors in the route have to be able to carry that 12A without overheating, and connector bodies generally are nylon or pvc, so you don’t want them getting hot. Make sure the connector is rated for at least that long-term fault current. Summary? On the basis of all that, it appears that a 7.5A breaker is the right size. Don’t go bigger because that increases the long term fault current that can be carried as discussed above. Finally, although I’ve use 18G wire in this example, I’d actually be tempted to use 16G as the only down side of that is a minuscule weight increase (oh, and a cost increase too). Hope this all made sense. Thanks sfGnome. I had just bought 20AWG from Jaycar (because that's what the instructions recommended), but given this info I will get 16AWG Tefzel. Any recommendations about connectors? I despise those nylon jobs with the folded metal pins. Are Deutsch the way to go? Edited 6 hours ago by Marty_d 1
Blueadventures Posted 6 hours ago Posted 6 hours ago 22 minutes ago, Marty_d said: Thanks sfGnome. I had just bought 20AWG from Jaycar (because that's what the instructions recommended), but given this info I will get 16AWG Tefzel. Any recommendations about connectors? I despise those nylon jobs with the folded metal pins. Are Deutsch the way to go? Its worth fitting connectors at the wing root in case you have to disassemble the aircraft. 1 1
Marty_d Posted 5 hours ago Author Posted 5 hours ago 42 minutes ago, Blueadventures said: Its worth fitting connectors at the wing root in case you have to disassemble the aircraft. Definitely, the wings are off until after painting and moving, so connectors are necessary. 2
