danny_galaga Posted November 19 Posted November 19 For really long conduit on petrol tankers, we used to get string, tie a big fat knot on the end, and blast it through with compressed air. 2
facthunter Posted November 19 Posted November 19 Try the compressed air and hold on to the wingtip bit securely. Nev 1
Marty_d Posted November 21 Author Posted November 21 Removed both wingtips today. After I got the first off, I realised it would be far easier to bolt the lights on if I could fully access the inside, not try to fit 3 M3 nuts through a 14mm hole. Anyway they're both bolted and Loctited. There is a risk that I need to get them off again one day, but apart from installing nutplates (which still would have required taking off the tips), I couldn't think of another way to do it. 5
Marty_d Posted Sunday at 09:02 AM Author Posted Sunday at 09:02 AM Managed to push some wire rope through the conduit - no assistance from compressor needed! Question for the brains trust - I have a 5A, 10A and 15A fuse. The strobe is 20W and position light 10w, operating between 10 and 15 volts. Do I double those watts (because there's 2), so that's 60w divided by 12v = 5A, then put it on the 10A fuse? 2
BurnieM Posted Sunday at 09:14 AM Posted Sunday at 09:14 AM I believe if the lights pull 5 amps then you up it by 50% and use a 7.5 amp fuse. This assumes you have checked the wiring and it can handle 7.5 amps without overheating. 2
Moneybox Posted Sunday at 09:26 AM Posted Sunday at 09:26 AM 20 minutes ago, Marty_d said: Managed to push some wire rope through the conduit - no assistance from compressor needed! Question for the brains trust - I have a 5A, 10A and 15A fuse. The strobe is 20W and position light 10w, operating between 10 and 15 volts. Do I double those watts (because there's 2), so that's 60w divided by 12v = 5A, then put it on the 10A fuse? I'm no expert but that sounds about right to me however I'd be using resettable circuit brakers rather than fuses. It's a bit hard to just pop out and get a replacement fuse when you need it. It's a lot easier to just reset the circuit breaker and if the problem repeats then no harm done, you just have to find the fault and fix it.
Marty_d Posted Sunday at 09:38 AM Author Posted Sunday at 09:38 AM 11 minutes ago, Moneybox said: I'm no expert but that sounds about right to me however I'd be using resettable circuit brakers rather than fuses. It's a bit hard to just pop out and get a replacement fuse when you need it. It's a lot easier to just reset the circuit breaker and if the problem repeats then no harm done, you just have to find the fault and fix it. Yeah sorry, bad choice of words, they are push in breakers, not fuses. 2
Blueadventures Posted Sunday at 10:43 AM Posted Sunday at 10:43 AM 1 hour ago, Moneybox said: I'm no expert but that sounds about right to me however I'd be using resettable circuit brakers rather than fuses. It's a bit hard to just pop out and get a replacement fuse when you need it. It's a lot easier to just reset the circuit breaker and if the problem repeats then no harm done, you just have to find the fault and fix it. I fitted the toggle / cb in single unit - aviation grade items. 1 1
Moneybox Posted Sunday at 11:04 AM Posted Sunday at 11:04 AM 20 minutes ago, Blueadventures said: I fitted the toggle / cb in single unit - aviation grade items. Could you post the item please? 1
Blueadventures Posted Sunday at 11:13 AM Posted Sunday at 11:13 AM (edited) 9 minutes ago, Moneybox said: Could you post the item please? Not cheap I’ll have a look on Tuesday what spares I have. Good space savers and super practical. I may only have 10 amp but know I have some different amp sizes. Edited Sunday at 11:14 AM by Blueadventures 1
Moneybox Posted Sunday at 12:33 PM Posted Sunday at 12:33 PM 1 hour ago, Blueadventures said: Not cheap I’ll have a look on Tuesday what spares I have. Good space savers and super practical. I may only have 10 amp but know I have some different amp sizes. Thanks Mike. I did google them. They look expensive but you only buy one item not a switch and breaker. The price varies a bit with amperage but seems to be about the same with all suppliers. There's a push-pull option that's a little cheaper. 1
Blueadventures Posted Sunday at 04:25 PM Posted Sunday at 04:25 PM 3 hours ago, Moneybox said: Thanks Mike. I did google them. They look expensive but you only buy one item not a switch and breaker. The price varies a bit with amperage but seems to be about the same with all suppliers. There's a push-pull option that's a little cheaper. Yes a 3A is dearer than a 20or25A etc ObN Tuesday I’ll see what I have and may have a 7.5 or 10 you can have. I liked them as like you said blows fuse then need to replace it, short or overload not rectified the new one blows these combined cab/switches are good and excellent quality. 2
danny_galaga Posted Sunday at 09:50 PM Posted Sunday at 09:50 PM 12 hours ago, Marty_d said: Managed to push some wire rope through the conduit - no assistance from compressor needed! Question for the brains trust - I have a 5A, 10A and 15A fuse. The strobe is 20W and position light 10w, operating between 10 and 15 volts. Do I double those watts (because there's 2), so that's 60w divided by 12v = 5A, then put it on the 10A fuse? It's not critical when it's all said and done. The closer it is to the nominal amperage, the more likely it will blow unnecessarily. The higher it is over the nominal, the more likely it won't trip at all if there's a problem (other than a dead short). I'd go with burnies recommendation of 50% over the nominal. Although I'm not sure what he means about checking the wiring. Presumably you've already made sure the wiring can handle the current draw of the devices. The rating of the breaker/fuse won't change that. 2
Moneybox Posted Sunday at 11:07 PM Posted Sunday at 11:07 PM 6 hours ago, Blueadventures said: Yes a 3A is dearer than a 20or25A etc ObN Tuesday I’ll see what I have and may have a 7.5 or 10 you can have. I liked them as like you said blows fuse then need to replace it, short or overload not rectified the new one blows these combined cab/switches are good and excellent quality. I’m hoping to catch up with Sean, the guy doing the panel, today but he doesn’t answer his phone or emails. I’ve had a friend 3D print the 13” iPad fan mount. It’s ready to pickup but I’m not keen on driving to Mandurah if I can’t drop it into Sean on the way back. I’m just hoping he can fit it in. Same with the switches, I don’t know where he’s at with the job. 2
facthunter Posted Sunday at 11:17 PM Posted Sunday at 11:17 PM People shouldn't reset circuit Breakers more than once in Planes. Nev 1 2
skippydiesel Posted Sunday at 11:18 PM Posted Sunday at 11:18 PM (edited) 13 hours ago, Moneybox said: I'm no expert but that sounds about right to me however I'd be using resettable circuit brakers rather than fuses. I Good point however I would sugest that lights on an RAA (Day VFR only) aircraft, are no where near essential for continued safe flight ie fuses would be just fine and a lot cheaper 😈 Edited Sunday at 11:21 PM by skippydiesel
Blueadventures Posted Sunday at 11:25 PM Posted Sunday at 11:25 PM 4 minutes ago, facthunter said: People shouldn't reset circuit Breakers more than once in Planes. Nev Agree, where these SW/CB are good is when they trip the main circuit doesn't trip and other items available. Where I have blade fuses in other things my trouble shoot box has some blade CB's as it's a pain to blow a number of fuses trouble shooting a short. The blade CB's are a bulking item but have their place. 3
skippydiesel Posted Monday at 09:25 AM Posted Monday at 09:25 AM I am not an auto electrician. The following is speculation; A word of caution to anyone considering Auto Set CB's I strongly advise against the automatic reset Circuit Breakers (CB). If a fuse or CB blows/trips, it is likly for a good reason. An automatic reset CB, may keep resetting, energising the damaged circuit ,which in tern may lead to an inflight fire. 😈 2 2
Blueadventures Posted Monday at 09:57 AM Posted Monday at 09:57 AM 10 hours ago, Blueadventures said: Agree, where these SW/CB are good is when they trip the main circuit doesn't trip and other items available. Where I have blade fuses in other things my trouble shoot box has some blade CB's as it's a pain to blow a number of fuses trouble shooting a short. The blade CB's are a bulking item but have their place. These are the manual reset blade circuit breaker I use and mentioned in my post. 1
facthunter Posted Monday at 09:57 PM Posted Monday at 09:57 PM Certainly don't use auto reset. Nev 1 1
sfGnome Posted Tuesday at 04:41 AM Posted Tuesday at 04:41 AM Marty, apologies if this is all obvious, but just in case it isn’t… Looking at the curves for the tyco W23 and W31 breakers, you need to take into account the ambient temperature and the amount of overload. At an ambient of 40C, the breaker is derated to 87% of nominal, and at 0C (pleasant Tassie weather), it goes in the opposite direction to 120% of nominal. So, with no margin, for a 5A draw, you need at least a 6A device so it doesn’t pop off on hot days, so let’s say use a 7.5A unit. Sounds ok, however… On a cold day, its nominal breaking point will be 9A. Fine if you have a short circuit, but what if the lamps fail to a mode where they just draw a greater than normal current (they’re solid state - it can happen). Now we run into the time-vs-current graph. At 135% of nominal (which is now 9A because it’s a cold day), the breaker will take an hour (yes, you read that right) to trip, meaning that the wiring will be possibly carrying 12A continuously for that hour. This is where wire size and connector rating comes into it. The issue with wire size is not its fusing point; it is its heating profile. For instance, an 18G wire (in free air) with 12A continuous will have a temperature rise of 30-50C. Wrapped in a bundle in a conduit will get hotter, but given that you’re using tefzel wire and we started with an ambient of 0C, that’s no problem at all. With 18G cable at normal operation (5A), the voltage loss across (say) 9m of cable (ie out to the light and back) will be in the order of 1V, which may or may not dim your lights a bit, depending on how they are designed. Any connectors in the route have to be able to carry that 12A without overheating, and connector bodies generally are nylon or pvc, so you don’t want them getting hot. Make sure the connector is rated for at least that long-term fault current. Summary? On the basis of all that, it appears that a 7.5A breaker is the right size. Don’t go bigger because that increases the long term fault current that can be carried as discussed above. Finally, although I’ve use 18G wire in this example, I’d actually be tempted to use 16G as the only down side of that is a minuscule weight increase (oh, and a cost increase too). Hope this all made sense. 2
Moneybox Posted Tuesday at 05:42 AM Posted Tuesday at 05:42 AM 57 minutes ago, sfGnome said: Marty, apologies if this is all obvious, but just in case it isn’t… Looking at the curves for the tyco W23 and W31 breakers, you need to take into account the ambient temperature and the amount of overload. At an ambient of 40C, the breaker is derated to 87% of nominal, and at 0C (pleasant Tassie weather), it goes in the opposite direction to 120% of nominal. So, with no margin, for a 5A draw, you need at least a 6A device so it doesn’t pop off on hot days, so let’s say use a 7.5A unit. Sounds ok, however… On a cold day, its nominal breaking point will be 9A. Fine if you have a short circuit, but what if the lamps fail to a mode where they just draw a greater than normal current (they’re solid state - it can happen). Now we run into the time-vs-current graph. At 135% of nominal (which is now 9A because it’s a cold day), the breaker will take an hour (yes, you read that right) to trip, meaning that the wiring will be possibly carrying 12A continuously for that hour. This is where wire size and connector rating comes into it. The issue with wire size is not its fusing point; it is its heating profile. For instance, an 18G wire (in free air) with 12A continuous will have a temperature rise of 30-50C. Wrapped in a bundle in a conduit will get hotter, but given that you’re using tefzel wire and we started with an ambient of 0C, that’s no problem at all. With 18G cable at normal operation (5A), the voltage loss across (say) 9m of cable (ie out to the light and back) will be in the order of 1V, which may or may not dim your lights a bit, depending on how they are designed. Any connectors in the route have to be able to carry that 12A without overheating, and connector bodies generally are nylon or pvc, so you don’t want them getting hot. Make sure the connector is rated for at least that long-term fault current. Summary? On the basis of all that, it appears that a 7.5A breaker is the right size. Don’t go bigger because that increases the long term fault current that can be carried as discussed above. Finally, although I’ve use 18G wire in this example, I’d actually be tempted to use 16G as the only down side of that is a minuscule weight increase (oh, and a cost increase too). Hope this all made sense. All this talk of wire size compared to current flow is also dependant on the length of the conductor so just because some bit of literature says use an 18g wire it could be way over the top or grossly undersize. 1 1
skippydiesel Posted Tuesday at 07:09 AM Posted Tuesday at 07:09 AM 1 hour ago, Moneybox said: All this talk of wire size compared to current flow is also dependant on the length of the conductor so just because some bit of literature says use an 18g wire it could be way over the top or grossly undersize. Seconded! AND in a 12V system be sure to: Have good clean & tight connections Run a dedicated earth/ground wire return (don't rely on airframe/chassis) 😈 1
danny_galaga Posted Tuesday at 07:53 AM Posted Tuesday at 07:53 AM 2 hours ago, Moneybox said: All this talk of wire size compared to current flow is also dependant on the length of the conductor so just because some bit of literature says use an 18g wire it could be way over the top or grossly undersize. You just need to look up a chart for the relevant type of wire, eg automotive, tefzel etc. it will give you gauge for a given current and length. It always amuses me when I see or hear someone say '10 amp wire' etc. totally meaningless for low voltage DC to describe wire that way. As sfgnome says, always go a heavier gauge if it's a close thing. 2
sfGnome Posted Wednesday at 04:44 AM Posted Wednesday at 04:44 AM 22 hours ago, Moneybox said: All this talk of wire size compared to current flow is also dependant on the length of the conductor so just because some bit of literature says use an 18g wire it could be way over the top or grossly undersize. Yes and no. Temperature rise is independent of cable length, but voltage drop is length dependent (which is why for that aspect, I guessed at Marty’s cable being 9m). 2 1
