Flying a friends Aerostar a few days ago. Really nice ,But the radio......Loud engine (912uls) related noise (change of pitch when increasing revs) Except when I transmit, then all is quiet. No-one complaining of poor reception.  Difficult to hear other's transmissions. Where would I start to look for the problem. Regulator has the large capacitor attached. Radio is ICOM 200. Thanks
G
You may want to check how the 'mag' switches are wired. Unless they are as per Rotax installation instructions, with correct shielding, they can make for radio noise.
G
Worth buying a new capacitor, even if not the cause its not an expensive outlay.  Often the issue is a faulty capacitor.  Need to be the correct size and also check its wiring circuit.
2 hours ago, facthunter said:
Topic should be Engine Radio Interference. Nev
Wouldn't it be better if you gave him some helpful advice
Edited by BrendAn
I know what I don't know and Radio was never one of my strong points but I thought calling it Interference would be HELPFUL as Engine Noise is just engine Noise. Nev
Has it always done that, or is this a new thing? Knowing that may help to ascertain whether it is a build problem (like unshielded mag wires) or a failure issue (like an old cap or a crook earth, etc).
"Engine noise" - if its electrical interference, this is something other than engine noise as in  -  ignition, charging/stator.........😈
sounds like alternator whine sound, do other stations report the whine on your transmissions or just in your reception
