skippydiesel Posted Wednesday at 11:35 PM Posted Wednesday at 11:35 PM White is the most boring but all round functional colour ie relativly high viz, cooler than most others, less vulnerable to UV, shows the dirt/scratches less, usually easier to colour match/repair. If I repaint my white Sonex, I think I will go for "Burnt Sienna" otherwise known as high viz yellow/orange.😈 1
sfGnome Posted Thursday at 12:39 AM Posted Thursday at 12:39 AM 11 hours ago, Marty_d said: The 701 also has rounded pop rivet heads all over it so that's probably not good for vinyl either. I was able to line up my numbers to miss the rivet heads, but the logo on the tail hit about 20 of them on each side. They form a bubble when first applying the vinyl, but a pin hole allows the air out and the vinyl stretches a bit to sit down over the shape of the head. Having said that, I wouldn’t want to do it over hundreds of heads if applying large areas of vinyl. 2 2
Blueadventures Posted 9 hours ago Posted 9 hours ago On 02/06/2026 at 10:20 PM, Marty_d said: On the weekend I bought a second hand inflatable spray booth. This saves me from having to build my own inside the shed the plane is in, and I should be able to resell it for about the same price. This means the plane is coming home again - which makes it easier to work on than jumping in the car and going up to where it is, only to realise the tool I need is still at home... Anyway - I know we're going into exactly the wrong time of year for painting, but I figure by the time I get ready it'll be summer again! Started off today by doing a couple of tentative colour schemes on some printed out 3 views. I think I'll end up doing 3 colours - white, "Marker yellow" and black trim. Idea attached. Also attached is my son's preference, which seems a bit complicated for me... This is another nice design. 2
