Builds By Baz Posted August 24 Posted August 24 It's been recommended by some in my path and shrugged off by others. As a trainee pilot with less than three hours of flying experience, Is it a good idea this early to have a flight sim at home for practice and familiarity? I used to have Microsoft flight simulator back in 2006, with a Saitek joystick and throttle control, but I had no idea what I was doing and didn't keep it long. If they are a good idea, what would I need? Stick or yoke, rudder and brake pedals, power and choke? How close are they to the real thing when it comes to learning and practice? Where would I get one of so? I am learning to fly, so obviously cash is important right now, so are there second-hand ones that would fit the bill? Baz.
rgmwa Posted August 24 Posted August 24 (edited) I’m sure you will get lots of opinions. I don’t think they help much for flying because you don’t get the seat of the pants sensations, noise and movement of a real aircraft to develop your sight picture and coordination. I think the time and cost would be better spent on lessons and studying the books. Edited August 24 by rgmwa 2 3
Ian Posted August 24 Posted August 24 I think that it's worthwhile but not quite in the way that you expect. Flying is quite easy but like learning to drive it takes time and it's full of things that can bring you undone. If you can afford it - go with a flight sim with a 3D headset, this helps you with your spatial awareness and get a yoke, joystick pedals to make it as real as possible. What it might be worth doing is to chip in with a few other trainee pilots because you're not going to be doing this 24/7, but it is way way cheaper than flying. Can you cut 5 hours of training time off - yes definitely. What flight sims can do is assist with the muscle memory, radio calls and spatial awareness, when is a good time to turn base, I've lost power, what are the steps I go through. Because it is so much cheaper even if it's not as effective as being in a plane you can do the rough cutting on a sim and polish in the plane. Like you, I don't really enjoy using a sim, but it is a useful tool. If they weren't useful airlines and the military wouldn't use them. 1
BurnieM Posted August 24 Posted August 24 If you can add the gear for less than $200 to an existing PC then it is worth a try. If you are paying $2000+ for a new PC and gear then I think it is more worthwhile to spend the money on additional lessons. The top end sims give you a feel for the plane but desktop sims only give you a mental exercise without developing much of a feel for the plane. 2 3
facthunter Posted August 25 Posted August 25 A full motion simulator will cost 1,000 's of dollars/hr of operations. It's designed to do emergency Procedures where doing it in a Plane used to get People killed. You need to be securely strapped in or you can get injuries. Its for ONE type of Plane ONLY IF it's Part of a Conversion to a type process.. There's usually about 6 sessions of four Hours Plus One 4 Hour test all as a crew. After that you jump in the real thing and fly it.. Google Map can help you plan a flight to places you are not familiar with.. You are in the Hands of your Instructor so to speak. Work with Him/Her. Nev
Ian Posted August 25 Posted August 25 1 minute ago, BurnieM said: If you can add the gear for less than $200 to an existing PC then it is worth a try. If you are paying $2000+ for a new PC and gear then I think it is more worthwhile to spend the money on additional lessons. The top end sims give you a feel for the plane but desktop sims only give you a mental exercise without developing much of a feel for the plane. Flying lessons are so expensive pretty much anything which lowers training time and reduces the likelihood of failing an exam is money well spent. If it cuts a few hours from your training or If it gets you through a test it, it's paid for itself. What's the hourly rate with an instructor - do the maths? And you can sell it once you're finished if you want.
BrendAn Posted August 26 Posted August 26 When you look at the link trainers they used to teach airforce pilots in you would think modern pc simulators should be way ahead of those.
facthunter Posted August 26 Posted August 26 I have "time" in a link but it's all in a context. Modern sims save Lives by allowing you to do things which if done in the real thing, run a significant risk of being fatal. They are so good that Info from a Flight data recorder entered into their intel can work out exactly what the real plane flew like in a crash situation, but they cost more than what a smaller plane would cost to operate. WW2 training casualties were about 17% and they also FAILED the Bottom 10% on each course. Too bad if you got on a Course of Geniuses.. Nev 1
Jabiru7252 Posted August 26 Posted August 26 30 years ago I used a flight simulator on my home computer to practice using the VOR and NDB as it simulated those instruments very well. Also, for navigation training it could be useful for getting time, speed distance calculations etc. up to speed. As for actual flying, I have never been very impressed. I did fly a real simulator, as big as a caravan back in 1980 while working in London. That was fun. 1 1
Ian Posted August 26 Posted August 26 Current simulators with a current VR headset are a massive change from the old simulators. They are completely immersive and engage your spatial senses I'd strongly suggest to anyone making recommendations about the relative benefits or the technology to try what is currently available. You'd be surprised, I've also tried the big old caravan sized sims and it is a completely different experience. The steps change over the last few years is huge. 1
Garfly Posted August 27 Posted August 27 23 hours ago, facthunter said: .... WW2 training casualties were about 17% .... Yes, as this USNavy training film puts it, more pilots and aircraft were lost in training than in combat. 3
facthunter Posted August 27 Posted August 27 In the early days the 'graveyard Spiral' killed just as Many. The first thing in such situations is 'Spin OR Spiral'? The correct response is completely different. As far as it goes, that Mil Training film is OK, but there's a lot more to it and Different Aircraft Behave a lot differently. You must know the Plane you are in. (and have enough height). Nev 2
Builds By Baz Posted November 1 Author Posted November 1 Thanks guys. I'm a few hours into my flying lessons now, hopefulliy will be landing the thing tomorrow. I see that a sim could be useful for all the other things outside actually flying, like practicing drills and radio. Baz. 3 1
facthunter Posted November 1 Posted November 1 Procedures too. The Motion and full view are so good you can get straight out of them and fly the Aeroplane.They also cost quite a lot and are for a specific Aeroplane type. Nev
Garfly Posted November 2 Posted November 2 (edited) 2 hours ago, facthunter said: Procedures too. The Motion and full view are so good you can get straight out of them and fly the Aeroplane.They also cost quite a lot and are for a specific Aeroplane type. Nev I think Baz is talking about software/hardware that you buy to install on your home computer for a few hundred bucks. That's a far cry from the multi-million dollar, full-motion, Level-D simulators that you're familiar with, Nev. Still and all, I find the X-Plane sim to be super useful as a currency/training device for my own private flying. The modelling of aerodynamics, atmosphere and geography is astonishingly realistic in modern home-sim software. (Though a pretty capable computer is needed). Even without an elaborate hardware set-up (yokes and pedals etc.) there's lots of useful education to be had; admittedly, more in connection with cross-country flight than with aircraft handling, per se. I'd say that it's, by far, the best way to get familiar with the many useful features of your EFB (by running it in 'Simulator Mode') For example, you could practise planning and flying a route in OzRwys on your tablet networked to a laptop that's running X-Plane. The EFB behaves exactly as if the flight you're simulating is a real one. (I use the C172's auto-pilot so I don't have to hand-fly the whole trip). And, since actual real time weather - and time of day - can be dialled in to the simulator you can plan and fly with currently available WX info. And, IMHO, the beautiful - and accurate - depiction of weather phenomena, landforms and the aircraft in flight is, alone, worth the price of admission. ;- ) Edited November 2 by Garfly 3 1
facthunter Posted November 2 Posted November 2 I agree. You can pre-run a trip you intend to do, practice let downs and holding Patterns and circuit entry and departure procedures, do your check lists at the appropriate time. Do timed circuits, Lay off drift. Plenty of reasons to give it a go. Nev
