Moneybox Posted 8 hours ago Posted 8 hours ago I've seen some discussion on this forum regarding ASIC cards. Who has them and why? I can't see a good reason for me to apply. Who needs an ASIC? You may need an ASIC if: • your occupation requires you to have frequent access to secure areas of an airport; or • you are employed in a specifically prescribed security-sensitive role. There are certain occupations that require you to hold and display a valid ASIC while on duty at a security controlled airport (regardless of whether you are accessing a secure area). These include passenger check-in staff, baggage handlers, screening officers, airport security guards and eligible customs officers. You may also need an ASIC if you are contracted or employed in a security-sensitive role with the following entities: Known Consignor, Regulated Air Cargo Agent (RACA), Accredited Air Cargo Agent (AACA), ASIC issuing body or visitor identification card (VIC) issuer. 2What type of ASIC do I need? All cards are evidence of a background check, however, the colour of your ASIC depends on your operational need. If your operational need changes, your issuing body may issue you with a different card. If you are unsure which card type you require, please check with your employer or issuing body. It is important to remember that holding a valid ASIC does not give you the right to access a secure area or zone. Access is controlled by the airport owner or operator. ASIC types Red ASIC John CITIZEN AUS AUG 19 XYZ 123456 Secure areas Airside security zones Landside security zones AUS Grey ASIC John CITIZEN AUG 19 XYZ 123456 Secure areas Airside security zones Landside security zones AUS White ASIC John CITIZEN A AUG 19 XYZ 123456 Secure areas Airside security zones Landside security zones Note: airside security zone as defined under regulation 3.01 of the Aviation Transport Security Regulations 2005 (ATSR).
