Garfly Posted Tuesday at 04:49 AM Posted Tuesday at 04:49 AM In-flight engine shutdown and forced landing involving Cessna 441, VH-LBZ, 3.6 km from Broome Airport, Western Australia, on 19 March 2026 | ATSB WWW.ATSB.GOV.AU And according to the Google bigbot, this ain't the first time such a thing has happened (poor ergonomics strikes again): AI Overview The primary problem with the Cessna 441’s engine Stop and Start buttons is their vulnerable ergonomic layout in the cockpit. Because these buttons are closely grouped together and lack sufficient physical barriers, pilots have inadvertently triggered engine shutdowns during critical phases of flight. 1 2 1
facthunter Posted Tuesday at 06:06 AM Posted Tuesday at 06:06 AM Understand your Plane before you start Playing engine failures. Always "confirm" correct switch Before Moving it and it's Purpose/ action. You should also know the Quick restart procedure. Turbo Props not feathered can create a lot of drag. That's why they Have Auto-feather. Nev 3 1
flying dog Posted Tuesday at 09:35 PM Posted Tuesday at 09:35 PM I agree with Facthunter. I watched the clip and was shocked that the FUEL BOOST and ENGINE OFF buttons were so close to each other and were the same kind of button. 1
Thruster88 Posted Tuesday at 10:35 PM Posted Tuesday at 10:35 PM That would be a very good reason to Visually identify and only press one button at a time to avoid the risk of double engine failure. 1 1
onetrack Posted Wednesday at 12:02 AM Posted Wednesday at 12:02 AM To reach out and hit control buttons by memory, whilst your eyes are elsewhere, as this co-pilot did, would rate as a dangerous cockpit practice - as proven by the result here.
facthunter Posted Wednesday at 07:34 AM Posted Wednesday at 07:34 AM With Auto feather, it's locked out once one engine has been feathered. This type of aircraft should easily fly on ONE engine if operated at the required Weights. Doing things at rapid speed invites wrong actions. Nev 2
