shafs64 Posted November 3, 2020 Posted November 3, 2020 Hi is it normal for the Savannah to run out of nose up trim in full flaps
Blueadventures Posted November 3, 2020 Posted November 3, 2020 Hi may need to add the model and the asi that your at and wanting more nose up. Also I may be doing a fly Friday morning early, just need to confirm no work on. Cheers
shafs64 Posted November 3, 2020 Author Posted November 3, 2020 it's 771 matts s model at full nose up trim you still need back pressure on the stick. just send us a text if you are going Friday.
IBob Posted November 3, 2020 Posted November 3, 2020 Yep, that's entirely normal. I have Mark Kyle's 3 position trim bracket. My trim tab swing was originally set by the book, I have now adjusted it to give more nose up. This now gives neutral trim at 33% flaps @ 50kts. At 100% flaps I still get pronounced nose down trim. However, I am reluctant to adjust it further, as the full nose up trim for landing gives very strong nose up when taking off again (my routine for circuits is land, drop back to 33% flaps while trimming down as much as possible before taking off again).
Kyle Communications Posted November 4, 2020 Posted November 4, 2020 I had my trim setup so that for level flight the indicator was the second top bar....you set the trim indicator where you want for level flight then adjust the antibalance tab position for level flight in that position. Then you get what you get. Always on full flap you (my indicator fully at the bottom) will need a good back pressure on my middle position of the flap lever then not so much and the first and most common position I used to use for general flying I basically needed no pressure on the stick
IBob Posted November 4, 2020 Posted November 4, 2020 That's pretty much what I have too, Mark: my neutral trim for cruise is about 2 to 3 bars. My instructor flies a VG, which originally had a smaller trim (not antibalance) tab. He converted it to the same tab as the S (full width on one side, but still trim, not antibalance), reckons it still pulls harder with full flaps than the S. Some places (the UK?) seem to require tabs on both sides, so effectively twice the tab area. Presumably they are able to get closer to neutral trim at full flaps?
facthunter Posted November 4, 2020 Posted November 4, 2020 A tab unloads the force on the Horiz stab ,Having it only on one side imposes a twisting force into the stabiliser and loads the hinges. Nev
IBob Posted November 4, 2020 Posted November 4, 2020 Yep, a more balanced arrangement would clearly be nicer. Having said that, apparently with tabs on both sides on the Savannah, there are 2 separate servos, which I think have to be synced prior to each flight by running them to nosedown limit.
facthunter Posted November 5, 2020 Posted November 5, 2020 Or have a single servo with a linkage or cable to ensure symmetry. This is sometimes used with flaps for the same reason. Use care as exposed light cable is easily damaged and a disconnect will guarantee flutter. Nev
