Pilot error may have led to each predicament, but the outcomes differ.
Extracted from Aviation et Pilote and translated from French….,
Ultralight accidents in 2025
By La Rédaction May 26, 2026
SAFETY HIGHLIGHTS
In 2025, the BEA published 13 reports involving ULMs whose class distribution is as follows: an event concerning an identified paramotor, an event concerning an identified ultralight helicopter and eleven events concerning multi-axis. These events resulted in the deaths of thirteen people. Seven themes emerge from these reports, several had already been identified in previously published assessments.
The emergency parachute was triggered in three events of this 2025 assessment during which no occupant was injured:
·      Accident of the G1 04IF multi-axis: on a cruise, the wing of the ULM was deformed, making it uncontrollable. The instructor triggered the parachute.
·      WT9 67BVN multi-axis accident: during a double-command stall exercise, the ULM suffered a right-hand rolling spin. The instructor who was unable to regain control of the ULM triggered the emergency parachute thinking of a structural rupture of the aircraft.
·      FK9 10NA multi-axis accident: during his flight, the pilot faced a deterioration in weather conditions. He continued the flight to his destination and, while moving at an altitude of 1,500 ft, he inadvertently entered the cloud layer several times. During a third pass in the layer, when he had lost all external visual reference, the pilot activated the parachute.
For several years, BEA investigations have shown late triggering or non-use of the parachute in a context where this rescue device could have mitigated the consequences of the accident. In the reports published in 2025, two accidents can be mentioned:
·      WT9 04FO multi-axle accident: during a double-command instruction flight, the ULM probably went into a spin during a slow flight and stall exercise. The spin was established until it collided with the ground. The parachute that was triggered late did not have time to deploy, inflate and slow down the aircraft's fall. Both occupants died.
·      Shark 22LE multi-axis accident: the pilot lost control of the ULM in unfavourable weather conditions for visual flight. He failed to regain control before the collision with the ground and did not activate the emergency parachute. The event is detailed in the 5th theme of this review on the destination objective.
A BEA study entitled "Emergency parachute activation: cognitive, emotional and physical mechanisms" was published in 2025. The objective was to better understand the mechanisms at play in the activation or non-activation of an emergency parachute. The analysis of the events and the associated testimonies made it possible to highlight key factors favouring the activation of the parachute: it is first of all the appropriation of the parachute by the pilot through his knowledge, rules (trigger criteria) and a willingness to use it or at least an absence of aversion to its use. The stress and surprise generated by an abnormal situation can slow down this decision-making. On the contrary, it seems facilitated if the parachute activation procedure is recalled during a briefing. In addition, simulating the gesture before the flight can allow this gesture to be executed almost automatically in stressful situations and in unusual flight attitudes
I recall reading a while back that when Cirrus introduced the ballistic parachute, they didn’t find any reduction in fatalities. They then made simulator training of parachute activation mandatory for new purchasers, where the stress of the training was “don’t wait, activate”, and the fatality rate dropped significantly. Unfortunately, I can’t link to the article as I don’t remember where I saw it.
I have seen vids of the Cirrus training and undoubtedly making it a standard part of low level standard actions saves lives.
They also removed thinking from the process. I can see how this would save lives but I wonder how many recoverable events were abandoned or not even tried because of this pull it early training approach.
More than 80% of parachute pulls write off the aircraft.
Not an issue if it saved your life but I would like to see an analysis of how many were actually required.
That would be an interesting but tricky analysis. Yes, ULs /LSA’s don’t have the kinetic energy of something like a Cirrus, so theoretically you have a better chance of saving yourself and the aircraft by ‘flying through the crash’…….but in the heat of the moment, you don’t know.  We all have the bullet-proof belief that our training will kick in, and of course we’ll naturally save the day, and be the ‘highly skilled pilot’ that walked away, featured on the news.
I’d be interested to hear an actuarial viewpoint, say in the circumstance where a pax was killed/injured in a crash where the BRS was not deployed, but it was considered that the BRS may have reasonably prevented it. That conversation could get ugly.
If the precursor event occurred over a cleared area of even terrain and the aircraft was still controllable, it would seem difficult to justify pulling the handle.
However, the instances detailed in the Aviation et Pilote article probably did justify pulling the handle as the safest outcome, but sometimes it wasn’t done soon enough.
In Europe, many countries mandate BRS, so it was more the psychology behind the ‘pulling the handle’ decision that was interesting to me.
Anyhow, may the debate rage begin……..
Some see it as a cure-all but it isn't .  It was done because the Plane never  passed the spin test. . IF you don't pull it and someone's Injured you are Probably in the $#!t Legally. THAT is NOT a good situation. Nev
39 minutes ago, Reynard said:
... ///   In Europe, many countries mandate BRS, so it was more the psychology behind the ‘pulling the handle’ decision that was interesting to me.
Or continue .....      ;- )
I think those guys knew exactly what they were doing by installing the parachute. Best selling single engine aircraft for the last 20 years. They just used an available alternative method of spin recovery. Can any light piston twin pass a spin test?
Yeah, the story about airframe parachutes having been introduced by Cirrus as a way to circumvent spin testing has been around - and hotly refuted - for years.
A random instance from 2015    https://backcountrypilot.org/forum/cirrus-caps-history-17494
Re: Cirrus CAPS History
TangoFox wrote: In order to get certified they had to add the parachute because it has problems recovering from a spin!!!
Ummmm, not quite.
In fact, the Cirrus airplanes were subjected to spin testing, and no unusual spin characteristics were documented. In fact, the MOLE cuffed wing used on the Cirrus is based on the same NASA studies that the Sportsman leading edge cuff was based on. The Cirrus wing is quite spin resistant.
One of the points that Cirrus makes is that the vast majority of spins are actually entered at or below 1000 feet agl. And, as the accident statistics prove, very few pilots are capable of recovering from an inadvertent spin at that height. That is the primary reason that Cirrus opted to certificate the airplane with the parachute. That and the fact that the parachute could save the day in other situations as well.
But, the Cirrus airplanes were subjected to spin testing to meet JAA (European) certification, and there wasn't anything there that suggested they couldn't be certified for spins under the normal one turn certification requirement. ... ///
27 minutes ago, Reynard said:
It’s a rainy day, so I found some rage bait. 🤪
Only teenagers fed-up with dad-jokes are likely to be baited by that one   ;- )
I believe there have been 35 fatalities after Cirrus CAPS pulls so ....
I rode motorcycles for many years and have many discussions about what is safe and what is dangerous.
The summary is "nothing is absolutely safe or absolutely dangerous".
The appendum is "nobody gets out of this place alive".
Edited by BurnieM
Making a BRS "Mandatory" seems one step too far. There ARE risks associated with it including extra weight, rescuer safety and being blown away in highs surface winds. Cost and servicing. Nev
Motorcycles are inherently dangerous. I've ridden them all my life, but no matter how carefully   YOU ride , some clown can easily take you out with an "I didn't SEE him" piss weak excuse. Didn't SEE. because you weren't LOOKING. Nev
OF course we are ALL going to die, but the More careful you are affects your chances, greatly of LIVING Longer, better and Healthier. It's NOT Boring, Sissy or Woke to be careful. Nev
It's NOT that simple. There is no easy fix. You are talking like a salesman or Legislator. Nev
Yep.  It’s not simple to be difficult and awkward.
Now I’m talking like a politician.
16 hours ago, Reynard said:
It’s difficult and awkward to put a price on safety.
Everyone has their own opinion.
I agree.
I advocate for safety to be a personal decision, once you have achieved  the age of legal adulthood.
I do acknowledge that the authorities must also consider the safety of others ie the actions of an individual should not put others at risk.
There needs to be a balance - not easy to achieve.
The mandating of safety equipment/standards in factory build vehicles (ground & air) is reasonable, as the purchaser is unlikly to have the knowledge to make an informed assessment. The mandating of the same, for homebuilts, is a complete overreach/stupid.
Unfortunatly human behaviour comes to rely on the perceived (actual?) safety systems, to keep them safe - skill/knowledge deteriorates and unwitting behaviour increases.
Then we add politics - The need of a politician to be seen to act, all to often overrides empirical evidence. Propaganda /urban myth takes over and safety systems that have little or no impact on the root cause of accidents is enacted (This is the Nanny State in action, all too prevalent in Au)
As an example on 'safety systems' training you to fail.
Since 2022 my car has an electronic hand brake. When you drive off this brake automatically disengages.
Apparently this was introduced because some people would drive off leaving the handbrake still on wearing out the brake pads.
In 50 years of driving I only left the manual handbrake on once while I was learning.
With the new car they just tell you to drive off.
A week ago I got a loaner car with a manual handbrake. Twice I have left it on.
Yes this is my screw up and if I kept  the car I would quickly train my self out of this.
Is an electronic handbrake required or even desirable ?
So much is going on with the dumbifaction of cars with little analysis of whether you are creating a bigger problem than you are trying to solve.
i have read this before. what makes an aircraft fail a spin test. is it the design of the detail. i have no idea thats why i am asking. i read this about bristells being hard to recover as well.
“The mandating of safety equipment/standards in factory build vehicles (ground & air) is reasonable, as the purchaser is unlikly to have the knowledge to make an informed assessment“
One of the reasons for the introduction of airbags in cars was the low usage of seat belts in the US and the resulting high injury rate.  Regulation substantially improved the overall safety outcome while still allowing freedom of choice to wear a seat belt or not.(in the US)
 Despite that, I don’t believe BRS in aircraft should be mandated. If it is an optional extra and the prospective aircraft owner wants it, so be it. It’s their choice and they can assess the cost/benefit.
 You only have to Look at some aircraft and you can tell they won't get out of spins easily. Usually because of fin and rudder shielding when the Plane is stalled. Nev
my lsa 55 with its tiny rudder would not be easy to recover either  would it.
