Reynard Posted 27 minutes ago Posted 27 minutes ago Pilot error may have led to each predicament, but the outcomes differ. Extracted from Aviation et Pilote and translated from French…., Ultralight accidents in 2025 By La Rédaction May 26, 2026 SAFETY HIGHLIGHTS In 2025, the BEA published 13 reports involving ULMs whose class distribution is as follows: an event concerning an identified paramotor, an event concerning an identified ultralight helicopter and eleven events concerning multi-axis. These events resulted in the deaths of thirteen people. Seven themes emerge from these reports, several had already been identified in previously published assessments. The emergency parachute was triggered in three events of this 2025 assessment during which no occupant was injured: · Accident of the G1 04IF multi-axis: on a cruise, the wing of the ULM was deformed, making it uncontrollable. The instructor triggered the parachute. · WT9 67BVN multi-axis accident: during a double-command stall exercise, the ULM suffered a right-hand rolling spin. The instructor who was unable to regain control of the ULM triggered the emergency parachute thinking of a structural rupture of the aircraft. · FK9 10NA multi-axis accident: during his flight, the pilot faced a deterioration in weather conditions. He continued the flight to his destination and, while moving at an altitude of 1,500 ft, he inadvertently entered the cloud layer several times. During a third pass in the layer, when he had lost all external visual reference, the pilot activated the parachute. For several years, BEA investigations have shown late triggering or non-use of the parachute in a context where this rescue device could have mitigated the consequences of the accident. In the reports published in 2025, two accidents can be mentioned: · WT9 04FO multi-axle accident: during a double-command instruction flight, the ULM probably went into a spin during a slow flight and stall exercise. The spin was established until it collided with the ground. The parachute that was triggered late did not have time to deploy, inflate and slow down the aircraft's fall. Both occupants died. · Shark 22LE multi-axis accident: the pilot lost control of the ULM in unfavourable weather conditions for visual flight. He failed to regain control before the collision with the ground and did not activate the emergency parachute. The event is detailed in the 5th theme of this review on the destination objective. A BEA study entitled "Emergency parachute activation: cognitive, emotional and physical mechanisms" was published in 2025. The objective was to better understand the mechanisms at play in the activation or non-activation of an emergency parachute. The analysis of the events and the associated testimonies made it possible to highlight key factors favouring the activation of the parachute: it is first of all the appropriation of the parachute by the pilot through his knowledge, rules (trigger criteria) and a willingness to use it or at least an absence of aversion to its use. The stress and surprise generated by an abnormal situation can slow down this decision-making. On the contrary, it seems facilitated if the parachute activation procedure is recalled during a briefing. In addition, simulating the gesture before the flight can allow this gesture to be executed almost automatically in stressful situations and in unusual flight attitudes
