"Description:
An Air Astana Embraer E190 takes off from Alverca, near Lisbon, after heavy maintenance, and the crew immediately loses effective control. For more than an hour they fight the jet in cloud, ask for the sea to ditch, then fly east into better weather, where two Portuguese Air Force F-16s guide them to Beja. Real ATC audio, with the flight path on the map. On November 11, 2018, flight KC1388 (callsign Astanaline 1388), E190 P4-KCJ, was ferrying from Alverca to Almaty via Minsk with three pilots and three company technicians on board, in low cloud and rain. Seconds after take-off the jet started rolling on its own and the autopilot would not engage. The crew declared an emergency, switched the flight controls to direct mode, and asked several times for headings to the sea to ditch. With some control back, they flew east into better weather and turned south to Beja air base, escorted by two F-16s from Monte Real. After two go-arounds the E190 landed on runway 19L at 15:27 UTC. One passenger had a minor injury; the airframe was loaded beyond its limit loads.
GPIAAF probable cause: the aileron cables on both wings were installed the wrong way round during maintenance, and the independent inspection did not catch it, so the ailerons worked in reverse and the crew lost control in flight."
Edited by Garfly
Jesus Christ, this is exactly why they introduced this very basic check so many decades ago. I believe it's what killed Aristotle Onassis son, who flew flying boats. Even flying my own plane, that no one else has serviced, I do that check. And I make a point to STARE at the aileron and actually think about if it's moving the right way. Besides, who knows what else. Maybe some kid left something sitting on the plane and it rolled into an aileron or elevator slot.
imagine the panic when it did the opposite to the inputs.
... further complicated by the spoilers working in the correct sense.
And what will initially happen is that you are only feeding in a small input. If you don't immediately realise what's wrong, then you instinctively think you didn't put enough input in, and feed in more. It's a credit to the pilots that they got past that initial confusion.
A question for the big boy pilots- I'm guessing on an airliner or similar large aircraft, the pilot can't directly check for correct movement. How does the pilot satisfy themselves that it's correct? Ground crew observing?
The vid is obviously made for non pilot audience. Dramatic but laking the details real pilots want to know.
If the roll control was fully reversed they would have crashed. My understanding is that there is a dead band in the centre of the yoke were the roll spoilers (which operated correctly)  do not respond. With the ailerons being reversed small inputs rolled the aircraft the wrong way and larger inputs must have made the roll correct but probably very slow with the ailerons fighting the spoilers. Rudder would have functioned normally to aid roll. Would take a while to work all this out.
The rice rocket Mitsubishi MU-2 only has spoilers for roll control.
  • Informative 3
Yeah, here is some better info from Aviation Safety Net:
https://aviation-safety.net/wikibase/319540
And there's heaps more detail in the offical Portuguese final report (incl. english translation)
https://asn.flightsafety.org/reports/2018/20181111_E190_P4-KCJ.pdf
I think this par from the official report (p.34) relates to the point you were making, T88:
"The roll spoiler function drives the Multi-Function Spoiler panels asymmetrically as a function of control wheel position. Control wheel movement of ± 40 degrees results in roll spoiler panel movement from 0 to 30 degrees up. There is a dead band of the control wheel, that when moved around the neutral position, the spoiler panels do not move, only ailerons move. The dead band in DIRECT Mode is 5.5 degrees. The dead band in NORMAL Mode varies with air speed and flap setting."
Edited by Garfly
Where a Plane has inboard and outboard ailerons the Only time BOTH operate is after some flap is selected.. Spoilers don't operate at all unless the control wheel exceeds about 25 Degrees from Horizontal. IF you are operating with speed brakes extended partly IT can all become a bit sensitive and you Really have to keep the Control wheel central. Once you are IN a turn you can do that. Nev
A plane can easily be designed so that Incorrect assembly is not Possible. Controls operating fully, freely and in the correct sense is an essential check, especially after any servicing. In a light Plane "Once around the World " gets peoples feet out of the way of the controls, just before you roll.  Nev
The control stick operated flight controls always "rise to meet the stick". So, right stick deflection means right aileron rises and vice versa. Similarly, stick aft means elevator up. Again , stick forward ...elevator falls. I hope that this is not too basic a statement but I use it.
. You should be well beyond that knowledge or you wouldn't have survived your first solo take off. It's still valuable and sometimes you can see the stick respond to you Moving the controls manually from outside. The Problem that we are discussing is Having the CONTROL Surfaces work the way the should when they are commanded to do so. On jets (and Gliders) you also have spoilers and sometimes the spoilers are operated differentially to Make roll response more Powerful and roll rate Higher.  They have things like Spoiler ratio mixers for that. The ICE-dangerous Mitsubishi MU-2 Only had spoilers. Nothing else. for roll. .
On some Larger Planes you can't see the controls from the cockpit, but a lot of them have indicators on the Panel and they are checked as you taxi  as well as brakes.    You would have to be very switched on to save a plane that had controls reversed and you didn't detect it prior to getting airborne. Nev
Edited by facthunter
Why don't they have cameras looking at the wings. You would think it would be an excellent safety addition.
Position indicators give a better record.  Not enough space on Panels  for camera viewer screens and the wings are rather Long. The camera lens might get crap on it. Nev
they have the tail camera on the 380, you can watch from the screen at your seat.
MentourPilot's take on the sissue:
Same thing happened on an A320 a few years ago. Somehow, an AvTech swapped the wires in the Captain's sidestick plug. Commanding left roll on the stick sent a right roll demand to the FBW.
Many years ago a mentor of mine ran a maintenance course for gliders in VIC. I think it was a libelle that was used. There was an issue whereby the the left and right bellcranks where interchangeable. If swapped the ailerons worked in reverse. MOST of the class did not detect this in the daily inspection.
Human factors.
KRviator, click on my previous link. It was an ELAC1 flight control computer at fault. (ELevator Aileron Computer).
Can confirm. I watched mine on an Emirates flight this year 🙂
Good design prevents ambiguity.. Adequate checks are part of the deal. Flying permits very few errors. Don't trust on luck. If you are NOT sure check it again. Its NOT Sissy. TOO TOUGH  to CARE?  Think about others and the example you set. Nev
There's no room for a large screen on an RPT Jets panel and it would be slower to assess.  You select the test. Its not there all the time and naturally it's done on the ground. When clean (No flap extended )only the inner ailerons function  till you exceed a certain  wheel deflection. THEN you get spoilers as well on one wing.. Once you extend any flap the outer Ailerons as well are working. This is Just a Natural progression to preserve adequate roll control as you slow down. Nev
I would imagine a camera screen could be integrated into a glass cockpit . Select a small popup window when you want look at the exterior. Easily done these days.
OK, I see that you want to critique my post on a technicality. But this is a light recreational aircraft forum and I took the line that I always do a, "Controls, free and full movement and in the correct sense" check before committing to aviation. This is certainly a throwback to my gliding days. It could be helpful to some and it recalls that the great Sanda Veenstra was killed by  just this mix-up when testing his self-designed motor glider. Cheers Don
Edited by Methusala
You might have missed my query earlier - how do the big boy pilots satisfy themselves that the controls are full and correct? Do you have ground crew observing? I'd never really thought about how they do it until now.
