Garfly Posted 6 hours ago Posted 6 hours ago (edited) "Description: An Air Astana Embraer E190 takes off from Alverca, near Lisbon, after heavy maintenance, and the crew immediately loses effective control. For more than an hour they fight the jet in cloud, ask for the sea to ditch, then fly east into better weather, where two Portuguese Air Force F-16s guide them to Beja. Real ATC audio, with the flight path on the map. On November 11, 2018, flight KC1388 (callsign Astanaline 1388), E190 P4-KCJ, was ferrying from Alverca to Almaty via Minsk with three pilots and three company technicians on board, in low cloud and rain. Seconds after take-off the jet started rolling on its own and the autopilot would not engage. The crew declared an emergency, switched the flight controls to direct mode, and asked several times for headings to the sea to ditch. With some control back, they flew east into better weather and turned south to Beja air base, escorted by two F-16s from Monte Real. After two go-arounds the E190 landed on runway 19L at 15:27 UTC. One passenger had a minor injury; the airframe was loaded beyond its limit loads. GPIAAF probable cause: the aileron cables on both wings were installed the wrong way round during maintenance, and the independent inspection did not catch it, so the ailerons worked in reverse and the crew lost control in flight." Edited 6 hours ago by Garfly 1 1
