Ice and more ice.
If you watch Juan Brown you can see that they were threading the needle between thunderstorms then at the end they diverted to the right directly thru a cell.
If their weather radar was working properly they should have seen the cell.
1 hour ago, flying dog said:
But how did it get to overspeed?
What would be the terminal velocity of the jet?
I've just watched a long breakdown of what happened and I'm more confused - kinda.
Let me explain:
Yeah, we've all seen the clips, the plane dives straight into the ground - nose first.
Problem - for me:
So they got hit with ice.   Aerodynamic stall/what ever.
This would mean (maybe) a wing stalls and the plane drops a wing.
Spiral down.
Or an extreme stall - both wings stalled and the `T` tail can't push the nose down to regain airspeed.
So the plane would ..... (what's a word?) flutter (yeah, not the best, but indulge me) down.   Spinning or yawing, or SOMETHING.
The clips showed it clearly going node first into the ground.  No spin (z axis) no yaw.....
So I don't understand how - if a wing was iced up - it would get into such an attitude.
P.S.   I'm not the sharpest tool in the box.
Watch the blancolirio clip posted above. He doesn't focus on just the sensational crash. He spends a bit of time with the radar. Right about where they got in trouble, they diverted STRAIGHT for a storm cloud. There is a chance that either their storm radar was faulty, or that it wasn't interpreted correctly. Until now I didn't realise that there's a lot going on to have the radar reading correctly. So when they seemed to inexplicably divert straight for the storm, it could be that what they were seeing on the radar (for whatever reason) meant that they thought they were diverting AROUND the storm. Have a look.
Hoover did an analysis that’s worth watching too.
A report from the NTSB has revealed that it had located “the majority” of the Learjet’s left elevator  in three pieces, between two and six kilometres away from where the plane nose-dived into Greenacres, near West Palm Beach.
It needs experience to use a weather radar to it's full capacity and the pilots have to co-ordinate well. In those cells  the vertical currents can be extreme. There's limitless energy coming from the Latent heat of Vapourisation Gas to Liquid.A change of state.  Clear ice at such high levels could only be the result of super cooled water vapour lacking condensation nuclei.  The usual OAT would be about minus 55 degrees Minus the heat factor of moving at the Planes cruising speed which is in the Order of 32 degrees, so minus 23 degrees Still pretty cold . There could easily have been an upset with the turbulence and there's 2 Pages of Memory items in the POH to be got through on that, The terminal velocity of 450+ Mph is feasible. The Overspeed in the dive caused the control surface failure. Death would have been very rapid. Nev
{ the pilots have to co-ordinate well.}
this snippet out of nevs post above is interesting because in the minutes leading up to the crash the copilot was texting her boyfriend
talking about the weather conditions.  how much help was she to the captain if preoccupied with texting.
You certainly could not hand fly a plane in those turbulent conditions AND Operate the Weather Radar. (You don't JUST turn it On) at the same time.  You scan up and down and vary the sensitivity to READ the clouds by level of return from the water drops or Hail  etc. The only effective way to do this is by experience in actual conditions.. Nev
Some aviation experts now believe the plane may have fallen foul of 'coffin corner' while trying to climb above two storm systems, known as cells.
Coffin corner is a phenomenon whereby the jet's minimum safe speed and maximum safe speed converge into a very narrow range at high altitude, making it extremely difficult to fly safely.
If the plane goes too slow or fast it will stall and quickly become uncontrollable.
You are completely correct . A lot of RPT aircraft fly too close to where Vmo Mmo  limits are not far apart.  Just try to Imagine keeping your airspeed in a narrow band in severe Turbulence . When you can't achieve that you have an UPSET. (loss of control) where you will lose a lot of height even IF you can recover it without damage to the Aircraft.  The LEAR is pretty good in this respect compared to a lot of others, but when you have say 8 knot's Margin total and the gusts can easily be 40 you have Buckley's chance of NOT falling out of the sky. Trying to go higher just exacerbates the Problem.  When I first went on Jets in 1970  this was High lighted and thumped into us Constantly.   Some People must want to be Nearer to God or Claim the Higher level before you've burned off enough fuel to safely do it. What if the Plane is a bit heavier than the Load sheet says?   Using standard Weights can do that or just a miscalculation or just a small overload because the Pax want to carry it? Nev.
24 minutes ago, facthunter said:
that was a cut and paste off a story about this crash.
i don;t want to take credit .😁
Edited by BrendAn
I wouldn't read too much into that yet. They say it was ten minutes before the accident. Plenty of time to knuckle down. After all, the text was to say they were experiencing turbulence.
I agree. All she wrote was," I've got turbulence, I've got ice" ten minutes before the accident. That text probably took her less than ten seconds.
I should add that even though sending the text had no effect on what happened subsequently I would imagine it's not allowed, although I'd be surprised if it doesn't happen more often.
Yeah, I'll agree with the comments about "texting while flying".
I am sort of guilty of stuff like that but noticed it and so now keep the phone AWAY from things if/when in those kind of conditions.
It is ok for the PAX to do stuff like that, but pilots!!??
They should be concentrating on flying the plane especially in conditions like that.
But.....  alas lessons - sometimes - come at the cost of others.
I hope people learn from this and avoid the same situation happening to them.
Remember that she is the co pilot, so at that moment the captain was flying.
I haven't heard anything about the captain yet?
Edit:
https://abc7.com/post/pilot-jeff-gregory-learjet-crash-killed-9-florida-was-husband-father-devout-christian/20012411/
Edited by danny_galaga
It's a bad look for a professional pilot responsible for passengers
To be texting at all I think.
pilot not flying or pilot flying......   To me that's not an excuse.
Commercial (Private jets like that etc) it is NOT a game.
You are responsible for people's lives and are being paid for it.
CRM is the term I believe.
Just because you aren't pilot flying doesn't give you an excuse to let your mind drift.
Sorry, that's my take.
That is a better/shorter way of what I said.    Shame I failed English.
I think the text is not relevant. It was a short flight related message to her boyfriend and she was not the pilot flying.
How and why they turned into a cell is the question.
I don't believe it is irrelevant.
I think it shows a lack of concentration on the task at hand.
Again, I would say "Crew Resource Management".  CRM
If the "co-pilot" isn't staying in front of the plane/situation it is too easy for them to become BEHIND and that is dangerous.
If you are flying yourself:  do what you want.   But when you are getting paid to fly people and are "distracted" by things outside the scope of your work:  You maybe need to think of another job.
Seriously ?
So if the pilot not flying eats or drinks or goes to the toilet she is also distracted ?
These tasks all take longer that sending a short text.
1 minute ago, BurnieM said:
Seriously ?
I.think you and thruster are missing the point . I don't agree with you but each to his own.
In situations such as that Both pilots should be working on the problem in a co-ordinated way and giving it their full attention. It's 2 person crew and each has their duties to perform as per the POH. 2 pages of emergency memory items The CM2 is not just sitting there like stuffed dummy waiting for the CM1 to die, before they do anything. AS FD says it's cockpit resource management. You would not even be able to safely loosen or undo your seat belt in those circumstance let alone go to the Toilet.  A plane moving at those sorts of speeds hits turbulence very  hard. Nev
Edited by facthunter
