I agree. Many pilots are weekend joy flighters or hire an aircraft and go for a trip once in a while. 800 hours is 20 hours a year and I know plenty of pilots who fly less than that. Life gets in the way of the majority of pilots who get their PPL or RPC. It is only a minority of amateur recreational pilots who would have anywhere near 800 hours over their lifetime of flying.
Plenty of pilots at the end of the war had only a bit over 300 Hours. It's hard to motive oneself to keep a high standard unless you work hard at it .My method was to keep instructing where you're supposed to be on top of everything..  I also got frequently asked to try out other people's planes , and there's heaps of other flying where I've shared it but not logged it.  Nev
8 hours ago, RFguy said:
I have already made my conclusion. And it is harsh !
Pilot became unconscious. Passengers were not sufficiently briefed on activating the CAPS system (shutdown engine, activate CAPS).
Should have been with so many souls on board.
It is a terrible ending to a what should have been survivable situation.
Pilot only accumulated 800 hours in 38 years which for me is a question mark.
For whatever reason he failed to provide duty of care to that family through his own errors.
Given they were young children, it's a bit much to expect them to save the day.
If a pilot can't control it or loses consciousness and spins the chance are very low.
But you are correct, in that a design that needs a chute to recover is a death sentence unless the chute is pulled. That still assumes a spinning iced aircraft will recover and float gently down.
A chute should be to save you after structural failure or engine loss. Not because it is unrecoverable from a spin.
I personally do not like the SR22 but your life your choice.
Given the destruction, I doubt we will ever know the actual truth.
NTSB interim report released last week. Says the aircraft landed fairly flat left wing low. Maybe flat spin. Difficult aircraft to recover from a spin.
I've logged almost 900 hrs over 45 odd years. I fly for the joy of it and the marvel of levitation. Don't use lighties for transport, that where Airbus excells. Fly in good weather and (mostly) can glide to survivable terrain. Don
Hey Don, this would have to be one of the best statements I’ve ever read reference private/recreational flying, I agree with you 💯%.
And Don, if I recall correctly, in your 900 hours you survived a broken/collapsed wing spar in flight & at least 2 ‘outlandings’ into paddocks following engine failures; one into a crop of lupins over a metre high.  The last 2, both the aircraft and you could fly again.  I also recall you doing a precautionary landing into a paddock near Braidwood to avoid hail.  So you must be doing something right. Mark
  • 1 year later...
Bringing this one back to the surface - the ATSB has released its final report on this crash, and unfortunately, due to the near-total destruction of the Cirrus, the investigators are unable to definitively find a cause for the crash.
Icing causing a stall, from which the pilot couldn't or didn't recover from, is certainly high on the list of likely causes. The fact that the ballistic parachute wasn't deployed is also cause for concern.
https://www.atsb.gov.au/media/news-items/2025/gundaroo-cirrus-light-aircraft-accident-final-report-published
A thorough brief needs to be part of pre takeoff if you have that kind of safety gear it would be beneficial if your pax knows how it works if poo hits the fan.
it might have changed the outcome for the better.
Clinton, unfortunately the pilot was a grandfather, and his pax were his 3 small grandchildren. There was previous discussion about whether any of the children had the strength or understanding on what to do, as regards an emergency situation.
I understand there's a reasonable level of strength required to pull the ballistic parachute, and if the aircraft was spinning, the pilot would've had his hands full just trying to recover - and I understand from reading survivors accounts, that an aircraft in a spin throws a fair few G's, making it even harder to move from your position, to carry out physical actions.
Edited by onetrack
A spinning Plane doesn't pull much G until the recovery dive Pull out. Most Aerobatic Planes have G meters that record a MAX figure.   Nev
Edited by facthunter
extra content
