skippydiesel Posted August 14, 2025 Posted August 14, 2025 I suspect (no real insight) that the initial cost of putting power lines underground, would be offset by lower in service costs & higher reliability (no wind or fire)😈
facthunter Posted August 14, 2025 Posted August 14, 2025 Exceedingly expensive and Harder to repair. More losses in transmission too I think. IF it was easy we'd be doing it. Nev
Flightrite Posted August 16, 2025 Posted August 16, 2025 On 14/8/2025 at 1:56 PM, facthunter said: How else does POWER get transmitted?. Nev At election time😂😂 1 3
facthunter Posted August 16, 2025 Posted August 16, 2025 That's POWER to the People and they should use it wisely while we can still vote. Nev 2 1
Blueadventures Posted August 28, 2025 Posted August 28, 2025 Had a great overnight fly out to Lake Dunn a nicely prepared strip surface and is planned to be lengthened a bit for Royal Flying Doctor requirements / use. Weather was mint, great company and good feeds. It's a 207 N/ml flight from my home strip. Lake Dunn August 2025.mp4 13 1
Blueadventures Posted September 8, 2025 Posted September 8, 2025 Six years ago did a trip to Bowen River Pub / rodeo and return. Land on the road to the dump. Always a good feed there and welcomed by the publican and staff. Can either camp or rent a donga room when the camp drafts and rodeo events are not on. Bwn Riv 2018 PCversion.mp4 5 1
Thruster88 Posted September 11, 2025 Posted September 11, 2025 Had a very nice fly in the thruster following 61mm of rain on the canola. Money falling from the sky, the joy of farming. 11 4
BrendAn Posted September 12, 2025 Posted September 12, 2025 22 hours ago, Thruster88 said: Had a very nice fly in the thruster following 61mm of rain on the canola. Money falling from the sky, the joy of farming. great photos. canola crops look fantastic. 1 1
facthunter Posted September 13, 2025 Posted September 13, 2025 Don't crash in a Yellow Plane in the yellow Plain. 1 1
Blueadventures Posted September 13, 2025 Posted September 13, 2025 (edited) 2 hours ago, facthunter said: Don't crash in a Yellow Plane in the yellow Plain. Yep, It'll be like a where's wally search. Edited September 13, 2025 by Blueadventures spelling 1 1
onetrack Posted September 13, 2025 Posted September 13, 2025 Canola loses its bright yellow flowers within a month or five weeks, as the plant sets seed, and the paddock then turns to a plain dark green as it forms pods, then it turns to a dull yellow as the pods ripen. Canola produces a lot more flowers than it sets as seed, it seems this is the plants way of dealing with heat, heavy rain, insect attack, or other stressors. 1
Thruster88 Posted September 13, 2025 Posted September 13, 2025 Canola flowers can be aborted by frost or dryness. If every thing goes right there is a pod for each flower. A pod typically has about 20 seeds so lots more seeds than flowers. 1 kg of Canola contains about 120,000 seeds, crushed this produces about 420ml of oil per kg. Typical yield is about 2000kg per hectare. So there is about 160,000 litres of oil in that field plus the by product which is high protein animal feed. 3 2
BrendAn Posted September 14, 2025 Posted September 14, 2025 (edited) Nice weather for this morning's flight. Did my first off airport landing on a farm strip. Great fun and many thanks to the owner for the invite. IMG_6200.3gp Edited September 14, 2025 by BrendAn 6 3
T510 Posted September 14, 2025 Posted September 14, 2025 Spent the weekend flying in the Legend Cub after 6 months away from flying due to work commitments and weather cancellations for the last couple of planned trips. Was great to be back in the pilots seat, playing around off airport and practicing my slipping turns. 5
facthunter Posted September 15, 2025 Posted September 15, 2025 What height do you continue them to? Nev
T510 Posted September 15, 2025 Posted September 15, 2025 1 hour ago, facthunter said: What height do you continue them to? Nev The slipping turns? It varies depending on the ALA I was using and the crosswind component.
facthunter Posted September 15, 2025 Posted September 15, 2025 I'm often surprised HOW many People don't do them very well. Without flaps you get a lot of practice, Nev
BrendAn Posted September 15, 2025 Posted September 15, 2025 On 13/09/2025 at 6:20 PM, Thruster88 said: Canola flowers can be aborted by frost or dryness. If every thing goes right there is a pod for each flower. A pod typically has about 20 seeds so lots more seeds than flowers. 1 kg of Canola contains about 120,000 seeds, crushed this produces about 420ml of oil per kg. Typical yield is about 2000kg per hectare. So there is about 160,000 litres of oil in that field plus the by product which is high protein animal feed. boss used to send us out to the bins with a supply of foam tape and duct tape. had to seal tailgates and auger doors before loading. canola runs like water. big money at stake. 1 2
T510 Posted September 15, 2025 Posted September 15, 2025 14 hours ago, facthunter said: I'm often surprised HOW many People don't do them very well. Without flaps you get a lot of practice, Nev Having only flown taildraggers*, mostly without flaps, I feel very comfortable slipping through the circuit and all the way to the flare. A well executed slip to flare is one of the most rewarding feelings when you get it right *I mistakenly got an hour in a nose dragger which confirmed I have no desire to fly anything with a nose wheel 1 1
facthunter Posted September 15, 2025 Posted September 15, 2025 You are Not Wrong about the side slips but tricycles will always be with us but keep the weight OFF the Nosewheel. Nev 1 1
RFguy Posted September 16, 2025 Posted September 16, 2025 (edited) In the PA28-180, Flew up to Mudgee (from Cowra NSW) for lunch to see a mate a couple of weekends back, good TAS at 9500. nil significant cloud. and then went up and had a good look at a Gulgong airstrip. YGGG Now is bitumen for about 1km, and nice grass at each end for a few hundred meters. great approaches, seems wind wise well orientated. E-W It's PPR, look up Bob Priddle in the book, he is a very nice bloke. then , last weekend flew down to wagga for lunch (again to see a mate) , plenty of canola flowers. few/6500 down there, scattered/5500 back. that's the nice big wing on the Archer, an extra foot longer compared to the Cherokee 180. non tapered. Edited September 16, 2025 by RFguy 9 1
Ian Posted September 16, 2025 Posted September 16, 2025 On 15/08/2025 at 8:29 AM, skippydiesel said: I suspect (no real insight) that the initial cost of putting power lines underground, would be offset by lower in service costs & higher reliability (no wind or fire)😈 Not that it relates to flying except as obstacles. Putting power lines underground is about an order of magnitude more expensive, and transmission lines are expensive enough that you've zero hope of getting the capital back. The only reason it is every done is to appease local voters with lots of government subsidies. Transmission and distribution already make up about 40% of your power bill. Image multiplying this by 10. Humelink costs have gone from the initial estimate of $1B to $5B for 365km of transmission. It's also worth noting that this is a regulated asset, so returns are guaranteed to the builder. https://www.afr.com/policy/energy-and-climate/transgrid-inflated-cost-of-running-power-line-underground-farmers-20230718-p5dp2o 3 1
skippydiesel Posted September 24, 2025 Posted September 24, 2025 (edited) On 17/09/2025 at 7:26 AM, Ian said: Not that it relates to flying except as obstacles. Putting power lines underground is about an order of magnitude more expensive, and transmission lines are expensive enough that you've zero hope of getting the capital back. The only reason it is every done is to appease local voters with lots of government subsidies. Transmission and distribution already make up about 40% of your power bill. Image multiplying this by 10. Humelink costs have gone from the initial estimate of $1B to $5B for 365km of transmission. It's also worth noting that this is a regulated asset, so returns are guaranteed to the builder. https://www.afr.com/policy/energy-and-climate/transgrid-inflated-cost-of-running-power-line-underground-farmers-20230718-p5dp2o Would the subterranean power lines have the (a) same (b) lower (c) higher maintenance cost ? While putting the power lines underground may be "to appease local voters" , there is no doubt in my mind that it its better for the visual amenity, unlikly to suffer from wind/fire/electrical storm damage and will not injure/kill fauna or unlucky persons. I suspect that the service life of underground cables is significantly longer than for aerial. The upfront investment may be higher (as you suggest) however once established , the pipelines carrying the cables would have a very long service life. "...............transmission lines are expensive enough that you've zero hope of getting the capital back." This is one of the biggest problems of a capitalist society - the obsessive need to have a (quick) return on capitol. All too often Government makes short term decisions - leaving the down stream costs/impacts to future governments/generations to deal with. I am not convinced that underground power reticulation, would not be cost effective in the long run.😈 Edited September 24, 2025 by skippydiesel
facthunter Posted September 24, 2025 Posted September 24, 2025 Its FAR too expensive to go underground. IF you WANT Electricity, WIRES ARE part of the deal. Get Real. Nev 1
