That used to be done to reduce condensation. Trouble is your next flight may not require full tanks.  Nev
39 minutes ago, JohnSim said:
Ok, Thanks for that. So, in your opinion would it be better to leave the tanks full to eliminate the amount of air in the tanks?
Its up to you.
Full is one strategy, for shortish term inactivity.
The alternative would be refresh with fresh fuel.
I guess I would err on the side of the latter, particularly if the inactive time span, went much above 4 weeks or if you don't really know how long it will be for the next flight.
Refresh also has the benefit of knowing exactly how much fuel (I always fill to Max) before any flight after a period of inactivity.😈
Edited by skippydiesel
Yes, I understand. I think it makes more sense to fill with fresh fuel. Thanks for your advice.
1 hour ago, skippydiesel said:
Its up to you.
Fuel stabiliser is your Friend
2 hours ago, skippydiesel said:
Its up to you.
Surely we are all dipping the tanks at the beginning of each day ?
The topic is about fuel left in the tanks long term. Fuel stabiliser keeps it mixed and fresh.
The topic is NO Avgas by 2030.?  Dipping tanks is a positive way of checking fuel Quantity. Sometimes people steal fuel from planes .Nev
Sorry not a fan of "Fuel stabiliser"
If I thought the aircraft / engine was going to be inactive for, say 3 months,  I would drain the tanks, fuel delivery system and carburettors.
Not sure why you asked this. Was there a suggestion that tanks would not be "dipped"?😈
It hadn't been mentioned. Planes get filled to the Level they require for the Proposed flight. No more No Less. The amount to be added must be a known amount added to  a known amount. Gauges alone aren't considered adequate for accuracy. Nev
what facts do you base this on.
Edited by BrendAn
We used to turn the fuel off when taxiing in timed to run out as you lined up in a Row on the DH82. As the engine died the throttle would be opened to clear out the spent gases  from the engine.  IF it ran out prematurely you had to lift the Tail and push it to the correct position, for all to see.  Nev
like a walk of shame😁
No "facts" just some experience and reading.
I have a fair bit of experince in what happens to a carburetor engines that suffer from stale fuel - not hard to fix but a pain in the rectum and the smell of stale fuel turns my stomach, somewhat. True this has been engines left for many months, even a year or more but does illustrate what can happen, something I wish to avoid. FYI : almost all these engine's have been running on 91 or 95 RON. The 91 RON lasts very well compared with 98 RON, hence my conservative 3 month time limit.
Reading - At least 1-2 of the major Australian fuel suppliers,Petrol storage times . Provide reasoned recommendations on fuel storage,  times, conditions (air tight container 75% + full, 98 RON good for 6 -12 months) and what happens to the fuel over time (loss of volatiles) Dont know if still available , you may find the info somewhere on this Forum, as I am sure this topic has been exhaustivity debated.
https://www.bp.com/content/dam/bp/country-sites/en_au/australia/home/products-services/fuels/opal-factsheet-storagehandling.pdf
My Reasoning; If you know the aircraft will not be flown for an extended period, why muck aground with fuel conditioners (approved for aviation?) filling with AvGas, etc when all you have to do is drain the tank(s), gascolator, float bowls, save the fuel for use in the car/mower. When the time comes refuel with known fresh (certain)😈
i know stabil works. it has to be approved for petrol not aviation. the fuel doesn't know what its in.   but each to his own.  i am not interested in looking up all the previous posts on the topic. if  i want to leave my plane for more than 6 months i will just add stabil.
I support free will (in most circumstances) - your prerogative my friend.
What sort of engine and does your aircraft /fuel delivery system maker, approve of Stabil?
STA-BIL® STORAGE • Keeps fresh fuel fresh for quick, easy starts after storage • Removes water from fuel to help prevent fuel separation • Protects the entire fuel system against gum, varnish, rust and corrosion • Contains powerful cleaning agents to remove gum and varnish build up that rob your engine of power and efficiency • Eliminates the need to drain fuel tanks before or after storage • For best results always store vehicles and equipment with a full tank of fresh fuel rather than a near empty tank. Always run the engine for up to 5 minutes after adding STA-BIL® to ensure the entire fuel system is treated and not just the fuel stored in the fuel tank • Use for storage and intermittent use.
modern marine engines and motorcycles and jetskis for that matter are more advanced and complicated than most aircraft piston engines.  if conditioners protect them whats the problem. this is the last i will comment on the subject. we shouldn't be taking over someone elses thread .
Very nice - but did not address/answer my question.😈
