skippydiesel Posted July 1 Posted July 1 (edited) I am contemplating changing my API 4" tail wheel, to an API 6". The reason for the possible change, is that my bird lives on a grass airfield. The 4" tail wheel does not like ground ops after rain (diggs in). The 6" wheel will reduce the ground pressure/unit area (improve "flotation") ie be less likly to penetrate the surface & reduce rolling resistance, in all circumstances. Depending on single fork or two fork configuration, the weight difference (from the 4") will be 0.06 kg & 0.15 kg . My Sonex Legacy is a tad "nose heavy" in Cruise , some up up elevator trim /stick back is applied, when no weight in (rear) baggage area. I would expect that a slightly heavier tail wheel, may reduce the need (to some degree? for aft trim. I know I should do the proper W&B calculations but just wondering what you think (possibly from experience) what the subjective effect (if any) will be, with the 6 " tail wheel weight increases , so far back on the airframe & of course a smidgeon more drag? PS - I think it likly that I could replace the API solid tyre/wheel, with a Peter Anson pneumatic, for reduced weight & even better "flotation' which may negate the weight increase 😈 Edited July 1 by skippydiesel 1
facthunter Posted July 1 Posted July 1 You should be able to calculate the New C of G position and New AUW from the existing W& B docs. The Safest thing is to do a reweigh and Balance. AS troubling as it is. Tailwheels can easily develop "shimmy" If the castor angle or damping is wrong. That will rapidly Ruin the tyre on sealed runways, unless you taxi tail up, risking a ground loop. Nev
Blueadventures Posted July 1 Posted July 1 I'd do a w&b, do the cofg calcs for loads and compare with its most recent and original weighing report, 5 kg / percentage max will determine next steps. 1
rodgerc Posted July 1 Posted July 1 I replaced the Sonex wheel with the Vans RV (solid) wheel and a bracket that was supplied by Kip Laurie (see photo) at the time. During building I had ditched the Sonex push-rod for an aluminium version with a couple of rod ends. The wheel and bracket swap had negligible impact on weight and moment. Peter Anson’s bracket has been subject to FEA and validated in application. 2
skippydiesel Posted July 1 Author Posted July 1 Thanks Rodgerc, My Sonex has a custom tail wheel "head" ie the API swiveling fork fits into it. The head is delivering the correct caster angle. This means that I am stuck with the API forks, the only alternative being replacing the whole" kit & caboodle" - expensive & unnecessary, as its only the tail wheel diameter that concerns me. Just done a rough estimate of 4'-6' weight - Seems likly that the an Anson wheel, mated to the API 6" fork, would be lighter than the current 4" API solid wheel/fork assembly. 😈 1
skippydiesel Posted July 12 Author Posted July 12 (edited) I am in a quandary. Have contacted Peter Anson regarding his highly recommended 6" Nylon hub tail wheel. "Nylon/Al wheel http://www.ansoneng.com/wp-content/uploads/2025/08/20250813_152356-300x222.jpg http://www.ansoneng.com/wp-content/uploads/2015/09/Nylon-wheel-150x150.jpg"This is the type I use on my own Sonex. It is fitted with quality 6000RS sealed ball bearings and a bearing spacer, enabling full tightening of the axle nut. The wheel is machined from PA6 nylon with a removable 6061 Aluminium rim half. Standard tire fitted is 6″ x 1.25″ 4 ply. Mass of wheel and tire is less than 340 grams (0.75 pounds). " In the course of writen conversation Peter has offred : 150 x 50 nylon wheel – 810 grams (1.79 pounds) http://www.ansoneng.com/wp-content/uploads/2025/02/20241207_180539-300x201.jpg http://www.ansoneng.com/wp-content/uploads/2025/02/20241207_180539-300x201.jpg"Heavy duty and still pretty light weight – these come fitted with a “Hota” 150 x 50 skateboard/electric scooter tyre." The Nylon/A1 wheel is narrower, a little cheaper and lighter than the Hota. The Hota will have better "flotation" ie deal with soft ground and dirt strips better, but likly higher drag (less speed/increased fuel consumption). Both a pneumatic. Decisions! Decisions! All informed comments will be well received😈 Edited July 12 by skippydiesel 1
skippydiesel Posted Friday at 05:40 AM Author Posted Friday at 05:40 AM (edited) Circumstance caught up with the decisions making process - Peter Anson advised Nylon/AI currently not available. Great service from Petre. Have fitted the Hota 150-50. Looks great! Change over weight increase 0.213Kg. Weather not conducive to test flying.😈 Edited Friday at 05:41 AM by skippydiesel 4 1
Marty_d Posted Friday at 08:21 AM Posted Friday at 08:21 AM Looks like a tiny motorbike tyre. Nice! 1
skippydiesel Posted Friday at 11:34 AM Author Posted Friday at 11:34 AM Peter Anson makes the split rim, fits the bearing's to suit buyers specifications and supplies the Hota tyre. He also made the bush/spacers to adapt to the API castering fork to the wheel. Great service.😈
skippydiesel Posted yesterday at 12:15 AM Author Posted yesterday at 12:15 AM Test taxi/flight . All went well. New tail wheel certainly helps with taxying, need less power . In flight, hard to say but possibly slight more forward trim in Cruise. Purchased a spare inner tube 6 x 1.25" (recommended by Peter A) from a disability equipment supply shop. The tube features a 90 degree valve stem, which I hope will be a bit more accessible than the OM 45 fitted 😈 2
