danny_galaga Posted Thursday at 06:13 AM Posted Thursday at 06:13 AM So tomorrow might be my last flight for a while depending on how the fuel situation pans out in Australia. I'm wondering what the best thing to do is regarding the fuel tank. The tank is 94 litres. After tomorrow's flight it will have roughly 40 litres of 98 octane. I have two Jerry cans of fuel. They are a couple of months old. They are well sealed as witnessed by the plastic cans expanding and contracting with heat. The planes fuel tank is relatively sealed, but definitely not air tight like the jerry cans. The engine is a Rotax 912uls Should I: Top up the fuel tank with the two Jerry cans. Or leave it as is, relying on really fresh fuel later to dilute the (probably if some months later) slightly stale fuel. And just use my 98 to top up my car's fuel tank every second tank or so when it gets to about half? What about additives? Is there something I can get from a servo that is known to be fine with Rotax? Normally shy of additives, but am open to suggestions. 1
facthunter Posted Thursday at 06:35 AM Posted Thursday at 06:35 AM Use it in your car. Fuel can go off. My mates Royal Enfield's fuel went off and the Fuel Pump had to be removed and dismantled. Lawn Mowers and tractors. It's a Bacteria.. That's why you shouldn't handle Jet A1. It has something in it to prevent it happening. Nev 1 1
danny_galaga Posted Thursday at 07:30 AM Author Posted Thursday at 07:30 AM Yeah, now I've written it out, I think that's the best solution. I'll try and run the tank low, it's not simple to drain. Also, on Rotax you normally just shut down via ignition, as there is no mixture control. So tomorrow I'll shut him down by turning off the fuel switch so there's virtually nothing in the carbies. I've timed how long it takes to run out of fuel. Takes 90 seconds. Longest 90 seconds I've ever sat through 😄 1 1
skippydiesel Posted Thursday at 08:07 AM Posted Thursday at 08:07 AM In my (limited) experince; 98 RON is good for at least 4 weeks in the aircraft tanks (open to atmosphere) Can be refreshed to almost origional standard by adding fresh 98 RON (shandy) Why not refresh the fuel in say 4 weeks with 98 RON, fly the aircraft to 1/4-1/2 tanks - repeat every 4 weeks until normal flying start again. Or drain As much 98 RON out of tanks as possible, replace with AvGas to full tank, go flying for an hour or so, park plane. Depending on how long you anticipate not flying this aircraft I would: Drain the tanks Drain the fuel lines & blow out with compressed air, if in doubt as to efficacy of drain. Remove & drain the carburettor flat bowls On the last two - I doubt that running the engine until fuel exhausted will remove all of the fuel. This then leaves small amounts in system (including float bowl) which will evaporate relativly quickly, leaving a "varnish" (gluggy mess) , which may or may not cause issues when you next fuel up & try to start the engine. Disconnect battery & put it on trickle charge. The 98 Ron in the "jerrycans" If filled to at least 75% capacity (more is better) will last at least 6 months (likly much longer), as long as container air tight. For container integrity - best to store out of direct sunlight 😈 2
Blueadventures Posted Thursday at 09:58 AM Posted Thursday at 09:58 AM Some cars won't run well on 98, read the cars manual about fuel. If 98 is ok use in your car. If you need to get it used someone doing regular flying at the field may buy it off you (at the pre war price its attractive). 1
BrendAn Posted Thursday at 10:03 AM Posted Thursday at 10:03 AM would it be worth refilling with avgas to keep eveything wet and prevent condensation in empty tanks. 1
skippydiesel Posted Thursday at 10:39 AM Posted Thursday at 10:39 AM 35 minutes ago, Blueadventures said: Some cars won't run well on 98, read the cars manual about fuel. If 98 is ok use in your car. If you need to get it used someone doing regular flying at the field may buy it off you (at the pre war price its attractive). Not sure that I agree with "Some cars won't run well on 98,..." My understanding is that its not worth (ie nothing to be gained) putting a higher RON fuel in an engine designed to run on a lower RON. I recon you could put 98 RON in your your lawn mower. It wont object , neither will it do anything better. Putting a lower RON in an engine designed for higher RON, will certainly not do the engine any good, may knock. 😈 1
danny_galaga Posted Thursday at 10:59 AM Author Posted Thursday at 10:59 AM My plan if using the 98 in my car is to just top up the tank. Say half a tank. As far as I can tell, a modem car like mine will automatically adjust timing etc with the aid of different sensors like anti knock sensors.
kgwilson Posted Thursday at 11:04 AM Posted Thursday at 11:04 AM BP produced a major study on this some years ago. 98 is generally good for up to 5 weeks in a fuel tank or if in a sealed container with little air gap about 4 months. I had some in my tank for about 7 months after the aerodrome was too wet to get out & I just added 5 litres of fresh 98 & it was fine. That is enough to refresh about 40 litres of old fuel. 98 has a number of light aromatic hydrocarbons ( Xylene, Toluene, Bezine Trymethyl benzine & others) that evaporate off first & this happens quite quickly (within 5 weeks). Interestingly the RON increases a little over that time but then often the engine is hard to start and once running it is prone to overheating which can lead to disastrous results. This happened in a chainsaw that we had in the SES. It had sat for at least 6 months & someone who was not aware didn't empty & replace the fuel with fresh as required. It was hard to start & ran till it was empty but refused to start again & there was no compression. The result was it had a hole in the piston, the big end bearing was stuffed & the bore was scored. We got a few spare parts from it though.
Blueadventures Posted Thursday at 11:18 AM Posted Thursday at 11:18 AM 17 minutes ago, danny_galaga said: My plan if using the 98 in my car is to just top up the tank. Say half a tank. As far as I can tell, a modem car like mine will automatically adjust timing etc with the aid of different sensors like anti knock sensors. All good but no good in an ED Ford 6cyl.
danny_galaga Posted Thursday at 12:42 PM Author Posted Thursday at 12:42 PM 1 hour ago, Blueadventures said: All good but no good in an ED Ford 6cyl. Honda Jazz, slightly more sophisticated engine ☺️ 1 1
danny_galaga Posted Thursday at 06:39 PM Author Posted Thursday at 06:39 PM 10 hours ago, skippydiesel said: In my (limited) experince; 98 RON is good for at least 4 weeks in the aircraft tanks (open to atmosphere) Can be refreshed to almost origional standard by adding fresh 98 RON (shandy) Why not refresh the fuel in say 4 weeks with 98 RON, fly the aircraft to 1/4-1/2 tanks - repeat every 4 weeks until normal flying start again. Or drain As much 98 RON out of tanks as possible, replace with AvGas to full tank, go flying for an hour or so, park plane. Depending on how long you anticipate not flying this aircraft I would: Drain the tanks Drain the fuel lines & blow out with compressed air, if in doubt as to efficacy of drain. Remove & drain the carburettor flat bowls On the last two - I doubt that running the engine until fuel exhausted will remove all of the fuel. This then leaves small amounts in system (including float bowl) which will evaporate relativly quickly, leaving a "varnish" (gluggy mess) , which may or may not cause issues when you next fuel up & try to start the engine. Disconnect battery & put it on trickle charge. The 98 Ron in the "jerrycans" If filled to at least 75% capacity (more is better) will last at least 6 months (likly much longer), as long as container air tight. For container integrity - best to store out of direct sunlight 😈 Ok, good point on the carbies. Could actually make things worse shutting the fuel off. I will shut off normally. And why not refresh the fuel in four weeks? This is the big question. How much fuel will we have? I probably use as much fuel in my car, roughly 20 litres, going to the airfield and back as in the plane. If things are tight for a while, that seems a frivolous thing to do. As you say, the fuel in the cans will last a long time. They are always in a cool stable environment, so I guess I won't touch them for now. If it's ok to go to the airfield again then I can still top up the plane as I usually do 😇
skippydiesel Posted Friday at 12:42 AM Posted Friday at 12:42 AM Petrol "How much fuel will we have?" in the months to come. My gut feeling, petrol will still be available however the price may be eye watering (I remeber petrol at 25c/L). Diesel is another matter - may be rationed, to non essential activities (domestic use) to preserve it for industry & essential services. It seems to me that the Australian public, still do not comprehend the importance of diesel to every aspect of our society (including its influence on the price of petrol). The Gov encourages this lack of awareness, by lowering the tax on all fuel. True they have removed the heavy vehicle Road User Charge (RUC), but what good does this do for the fishing /farming/etc non road industries?? The proper response would have been to remove entirely the various taxes/levies on diesel, for the duration of the emergency. This would have assisted all diesel dependent industries & services, (inc the cost pf petrol) and had a moderating influence on the rising cost of living. Personally I am reducing my flying hours - not so much spontaneous levitating, in favour of a few planned trips, with know fuel availabity (if required)😈 1
facthunter Posted Friday at 12:49 AM Posted Friday at 12:49 AM There's a war on Mate and there's plenty of Places worse off. Philippines as an example..Nev 1
facthunter Posted Friday at 02:13 AM Posted Friday at 02:13 AM You couldn't get petrol at all here during ww2 and we had coupons for other essentials. Cars were put on Blocks for the duration.. Nev 1
Student Pilot Posted Friday at 10:26 AM Posted Friday at 10:26 AM I run 98 in all sorts of machinery, no trouble with it going "Off" even after months. With the lower grade fuels it seems to go off very quickly and leaves a green slimy residue in float bowls. 1 1
onetrack Posted Friday at 10:29 AM Posted Friday at 10:29 AM I store petrol in full jerry cans (of all types, PVC, poly and steel), inside sea containers, and the 91 ULP I use for all my equipment, keeps for 6 - 9mths with no problems. The secret is full, sealed containers. 2 1
skippydiesel Posted Friday at 11:00 PM Posted Friday at 11:00 PM 12 hours ago, Student Pilot said: I run 98 in all sorts of machinery, no trouble with it going "Off" even after months. With the lower grade fuels it seems to go off very quickly and leaves a green slimy residue in float bowls. Using 98 RON, in engines that can not benefit from the higher octane rating, will do no damage other than to your finaces. Expensive 98 RON is for high compression petrol engines. Cheaper 91 RON at the other end of the scale is for (relativly) low compression engines. The practical effects of using a low RON fuel, in a high compression engines ( usually sport cars/Rotax 100 hp & up) is the potential for destructive "knock". For optimum cost/effect - use the fuel grade recommended by the engine maker😈 1
facthunter Posted Friday at 11:05 PM Posted Friday at 11:05 PM Don't go Lower than the grade recommended and what about the Leaning effect of E10? Nev 1
danny_galaga Posted yesterday at 12:50 AM Author Posted yesterday at 12:50 AM 14 hours ago, onetrack said: I store petrol in full jerry cans (of all types, PVC, poly and steel), inside sea containers, and the 91 ULP I use for all my equipment, keeps for 6 - 9mths with no problems. The secret is full, sealed containers. Yes, that's my experience too. My fuel is sealed in plastic Jerry cans. Definitely seal well as you can see them swell and contract over the course of a day. Undercover, out of the sun. I think I'll keep my 98 cans for the plane then. I got a bit carried away at one stage because of the crazy price fluctuations in Brisbane, in normal times. So I ended up with four cans of 98, and two of 91 for the car. But it's been pointed out to me that I'm rooted if there's a fire in my garage because insurance will only allow for one can. So my plan is to reduce these as I can, and just try not to have a fire in the meantime 😄 1
facthunter Posted yesterday at 01:16 AM Posted yesterday at 01:16 AM The point is that fuel does go off in some tanks due to what's in the tank and once it starts I have no idea how to stop it. They go to a lot of trouble with Jet A1 and it doesn't sit for Long in Airliners that fly about 18 Hours each day. Bigger Lawnmower places have ADDITVES for sale. Nev 1
BrendAn Posted yesterday at 04:30 AM Posted yesterday at 04:30 AM 3 hours ago, facthunter said: The point is that fuel does go off in some tanks due to what's in the tank and once it starts I have no idea how to stop it. They go to a lot of trouble with Jet A1 and it doesn't sit for Long in Airliners that fly about 18 Hours each day. Bigger Lawnmower places have ADDITVES for sale. Nev That's an option for Danny. Pick up a bottle of stabil from BCF or supercheap. Don't know if it's recommended for aircraft though. Why does avgas last for years, what do they put in it.
skippydiesel Posted yesterday at 04:47 AM Posted yesterday at 04:47 AM 9 minutes ago, BrendAn said: That's an option for Danny. Pick up a bottle of stabil from BCF or supercheap. Don't know if it's recommended for aircraft though. Why does avgas last for years, what do they put in it. I would be super cautious about "....a bottle of stabil from BCF or supercheap" and it would likly take more than a bottle to treat an aircraft system (no matter how small). "Why does avgas last for years, what do they put in it" Google has some answers for you. If you want to combine storage with easy return to service - It seems to me that; AvGas may offer some of the solution Complete draining of the fuel system is the most reliable long term solution to fuel deterioraton. Proper "pickling" of the engine should also be looked into - I believe Rotax have a chapter on this. 😈
BrendAn Posted yesterday at 05:01 AM Posted yesterday at 05:01 AM (edited) would be super cautious about "....a bottle of stabil from BCF or supercheap" and it would likly take more than a bottle to treat an aircraft system (no matter how small. Skippy. I agree with you accept for this statement. Completely unfounded guesswork on your part. You need to do some research then make an informed comment. Edited yesterday at 05:01 AM by BrendAn
facthunter Posted yesterday at 05:02 AM Posted yesterday at 05:02 AM Methanol lasts for Ages also if the cap is sealed. It depends on how stable the Substance is. Complex things tend to degrade or oxidise or be attacked by Bacteria or Mould. Nev
