rhtrudder Posted April 22, 2025 Posted April 22, 2025 Thoughts on using anti puncture goo in aircraft tyres, planning on some trips away , don’t need flats, anyone tried thisÂ
turboplanner Posted April 22, 2025 Posted April 22, 2025 There's a long and informative thread about this on the site.
skippydiesel Posted April 22, 2025 Posted April 22, 2025 (edited) There was a conversation/thread on this, just a little while back. From imperfect memory the respondents fell into three camps; Carry a spare inner tube And or tube repair kit Various goo supporters The first two are self explanatory. The third: Some opinion that goo's of various types, including the pressurised (inflating) delivery, are not suitable for tubed tyres. For the most part direct the user to drive for ?? kilometers at significant (?) speed - presumably to distribute the product & through tyre heating, cure it. Not so easy in an aircraft. May cause a severe imbalance - Could be dangerous, would certainly be alarming. May get you off the ground, only to arrive & land with a flat tyre - not a "good look" at all.  I am a supporter of 1 & 2 Carry a spare tube & tyre repair kit. However I recently experienced multiple small holes ,in one of my Ranger tubeless tyres, and for the first time used a pressurised goo type sealer - worked a treat. Did have to pump up to to correct pressure and complied with driving instructions, by doing a 20 kilometre round trip at 100 kph - not so skeptical now  Possibly your best preparation/defence against punctures, is to have your tyres inflated to their highest recommended pressure, to reduce side wall bellow/flex. The side walls are the thinnest part of the tyre carcass and most prone to damage. Low pressure allows the side walls to flex out more than normal, making them more vulnerable to penetration. 😈  Edited April 22, 2025 by skippydiesel 2
Blueadventures Posted April 22, 2025 Posted April 22, 2025 (edited) 5 hours ago, rhtrudder said: Thoughts on using anti puncture goo in aircraft tyres, planning on some trips away , don’t need flats, anyone tried this I am set up to fix flat tyres when flying solo; so have a jack (0.5kg by Peter Anson Engineering), two bottles of repair foam for tubed tyres (0.3kg each), two tubes, tube repair kit, spare valves and removal tool and the necessary tools to remove wheel and disassemble the wheel; and a pump. Mine is split rims and easy to get apart. I've been involved with Savannah tyre changes and re tubing and there are a problem to get tyre bead off the rim, real hard and near impossible. I say be able to do solo as you need to get wheel off the ground and a rock under the leg if you don't have a jack or a support. The P3 is great for a quick fix, get you going and about $26 a can. Edited April 22, 2025 by Blueadventures 1 3
Freizeitpilot Posted April 22, 2025 Posted April 22, 2025 Just curious - does the P3 have a flammable propellant and the can have a temperature limit stated on it at all ? 1
skippydiesel Posted April 22, 2025 Posted April 22, 2025 Blueadventures,  As a repair in a can proponent, would you mind addressing the perceived negatives.  How often have you used this sort of product onan aircraft tyre?😈
Blueadventures Posted April 23, 2025 Posted April 23, 2025 22 hours ago, Freizeitpilot said: Just curious - does the P3 have a flammable propellant and the can have a temperature limit stated on it at all ? It contains a flammable propellant; there is a safety data sheet for it. It works very well I'm told by a reliable person who has used two cans on at least two occasions as he fly's a Nynja at an airfield that has thorns in the grass. 1
Blueadventures Posted April 23, 2025 Posted April 23, 2025 10 hours ago, skippydiesel said: Blueadventures,  As a repair in a can proponent, would you mind addressing the perceived negatives.  How often have you used this sort of product onan aircraft tyre?😈 I have detailed my knowledge of the P3 product in the earlier post and in the other thread.  It would be helpful to all if you could update your post with the product brand detail of what you used. You have omitted this information. 2
skippydiesel Posted April 23, 2025 Posted April 23, 2025 Further to Blue adventures request - some information about the wheels/tyres that this or similar products have been used on.  Reasons - As stated earlier here is some suggestion that its not so effective in tubed tyres. How has the instruction post application, to drive for a certain time & speed, been accomodated? 😈 1
facthunter Posted April 24, 2025 Posted April 24, 2025 (edited) It was introduced way back when tubed tires were common Fenelec I think. Nev Edited April 24, 2025 by facthunter 1
facthunter Posted April 24, 2025 Posted April 24, 2025  Personally I'd prefer tubeless tires as you don't tear the Valve out if the tire rotates a bit on the rim. That gives you INSTANT deflation. Caltrop is the worst thing for Punctures. Echuca had it. and It's hard to eliminate once you have it. Nev 1
skippydiesel Posted April 24, 2025 Posted April 24, 2025 15 hours ago, Blueadventures said: I have detailed my knowledge of the P3 product in the earlier post and in the other thread.  It would be helpful to all if you could update your post with the product brand detail of what you used. You have omitted this information. Yes , you wrote about the product, all the tools you have and some tips on wheel/tyre removal but did not mention any actual experince of the product mentioned/shown.  Experience is all important. Without it you are just echoing marketing & third hand myths, which does little to inform the Forum readers😈 1
Blueadventures Posted April 24, 2025 Posted April 24, 2025 39 minutes ago, skippydiesel said: Yes , you wrote about the product, all the tools you have and some tips on wheel/tyre removal but did not mention any actual experince of the product mentioned/shown.  Experience is all important. Without it you are just echoing marketing & third hand myths, which does little to inform the Forum readers😈 Skip; I've shared what I know, Your detail is piss poor as you don't bother to share the brand you used with success. You often do this when you push for detail off myself and others, you need to lift your game or exit.  As for your comments running down my information you can keep your opinion to yourself. For others I can assure them that the information is as good as top shelf RD testing by an approved authority, and I'll back in the effectiveness of the Motul P3 product for flat tubed tyres.  1 1
skippydiesel Posted April 24, 2025 Posted April 24, 2025 So Blue - I take it from your "forceful" response - no experince.  I am NOT "running down" your information. I am rightly seeking first hand experince.  "You often do this when you push for detail off myself and others"  I think you will find that I ALWAYS give as full an account of my experince as I can - Am upfront when speculating or passing on others comment/information, that I don't have personal experince of.   As my experince was not directly related to aviation, I did not think to include the brand.- it came from Repco - cant remember for sure - think it may have been the Holts product (pictured). The bloke behind the counter reckoned it was a good one.  I stress - I used this on a 4x4 tyre - not an aircraft. The multiple holes were very small, deflation rate estimated on 5psi/day - no idea what caused the problem. I also stress - being a land based vehicle, I was able to follow the, after use, instructions, to drive for a distance (?) at, I think, at 60 mph - this is likly not practical in an aircraft. I also had to supplement the pressure delivered by the can, with added inflation to correct psi.  Â
spacesailor Posted April 24, 2025 Posted April 24, 2025 well ! . I have bought at least a half-dozen products.  but never used one . When 4x4ing I found it was quick to use " tyres-pliers " & put a proper patch inside the tyre I . should give / throw them out . ( dead weight ). spacesailor 1
skippydiesel Posted April 24, 2025 Posted April 24, 2025 6 hours ago, spacesailor said: well ! . I have bought at least a half-dozen products.  but never used one . When 4x4ing I found it was quick to use " tyres-pliers " & put a proper patch inside the tyre I . should give / throw them out . ( dead weight ). spacesailor Problem (for me) is they are such a great idea BUT who do you know has had success, using any one of the several products, on/in an aircraft tubed tyre?😈 1
BurnieM Posted April 24, 2025 Posted April 24, 2025 Do we need to analyse this to death ? 'Repair in a can' products are cheap and in some circumstances (mainly with tubeless tyres) useful. They are less useful with tubed tyres where the tube sometimes tears. Â 'Repair in a can', spare tube, tools to remove the wheel and the tyre from the wheel and a pump are still cheap and relatively light weight. Buy it, chuck it in the back and hope to never use it. 1 1
Red Posted April 24, 2025 Posted April 24, 2025 On 22/04/2025 at 5:47 AM, rhtrudder said: Thoughts on using anti puncture goo in aircraft tyres, planning on some trips away , don’t need flats, anyone tried this RR, I notice you use the words "Anti Puncture" as oppossed to puncture repair. Are you referring perhaps to products like Slime?. I have experience of Slime and other similar products in Mountain Bike tyres and they are effective on small punctures but they dont half leave a mess inside the tube or tubeless tyre. I would steer clear of these products. Are your Aircraft tyres tubed or tubeless?  If tubeless and you were actually asking about repair and not prevention, then the motorcycle Plug type repair kits work really well in my experience. 1
skippydiesel Posted April 24, 2025 Posted April 24, 2025 BernieM, "Do we need to analyse this to death ?"  Yes! Why - as is often pointed out, we are discussing this product/concept application in aircraft tyres - not ground based vehicles. If the use of these product do end in a "death" that could have been prevented by some informed comment, we are all moral responsible.  It would be realy great if someone WITH EXPERIENCE addressed some/all of the following:  Some opinion that goo's of various types, including the pressurised (inflating) delivery, are not suitable for tubed tyres. For the most part direct the user to drive for ?? kilometers at significant (?) speed - presumably to distribute the product & through tyre heating, cure it. Not so easy in an aircraft. May cause a severe imbalance - Could be dangerous, would certainly be alarming. May get you off the ground, only to arrive & land with a flat tyre - not a "good look" at all. 😈 1
skippydiesel Posted April 24, 2025 Posted April 24, 2025 7 hours ago, Red said: RR, I notice you use the words "Anti Puncture" as oppossed to puncture repair. Are you referring perhaps to products like Slime?. I have experience of Slime and other similar products in Mountain Bike tyres and they are effective on small punctures but they dont half leave a mess inside the tube or tubeless tyre. I would steer clear of these products. Are your Aircraft tyres tubed or tubeless?  If tubeless and you were actually asking about repair and not prevention, then the motorcycle Plug type repair kits work really well in my experience. Good points Red, I too have seen Slime promoted as an "Anti puncture" product to add to lawn tractor/mower tyres when new. Of course its not "anti puncture" but can block small leak that would otherwise cause the tyre to deflate. I speculate that its use may cause a significant out of balance condition, which has no significance for a mower but could be quite dramatic in an aircraft .  "...Aircraft tyres tubed or tubeless?" In my, limited, experince most small aircraft tyres are tubed  Tyre plugs work very well in all classes of ground based tubeless tyres. I would guess that they would be a worthwhile item to carry in a small aircraft fitted with such tyres. 😈 1
facthunter Posted April 25, 2025 Posted April 25, 2025 I wouldn't use Gloop in a planes tires, full stop. If it goes flat, FIX it. Nev 1 1
BurnieM Posted April 25, 2025 Posted April 25, 2025 "Analysis paralysis" Analysis paralysis is the inability to make a decision due to overthinking or overanalyzing a problem, often resulting in inaction. It can occur when faced with numerous options, too much information, or the fear of making a mistake.  Frequently a mid range or non-optimal product or action is better than no product or action at all.  1 1 1
facthunter Posted April 25, 2025 Posted April 25, 2025 You don't HAVE to take off with a KNOWN sub standard condition, existing. Nev 1
BrendAn Posted April 25, 2025 Posted April 25, 2025 1 hour ago, BurnieM said: "Analysis paralysis" Analysis paralysis is the inability to make a decision due to overthinking or overanalyzing a problem, often resulting in inaction. It can occur when faced with numerous options, too much information, or the fear of making a mistake.  Frequently a mid range or non-optimal product or action is better than no product or action at all.   like me trying to buy stuff at woolies 1
spacesailor Posted April 25, 2025 Posted April 25, 2025 SO ! , Weight wise it wIll be , " plugs " , small package & quick and effective. There ! , problem solved . No more dilly-dallying. Go get a small kit . spacesailor  PS. : hope you find that hole , to put your plug in . LoL
