Thruster88 Posted December 16, 2024 Posted December 16, 2024 Perhaps this is why BrendAns instructor said not to use the centre of the runway.🤔  If only the hapless pilots friend had said something like, "see that cessna with the big flaps that you are rapidly catching, he might exit on the left at A3. Pass on the right like you have been trained to do".  The numerous cracks in the instrument panel was unusual.Â
facthunter Posted December 16, 2024 Posted December 16, 2024 Don't get yourself into such a situation in the first place.. Passing on the right refers to when you are in the air, not playing dodgems on a sealed runway.  Nev 1 1
IBob Posted December 17, 2024 Posted December 17, 2024 (edited) wrong thread..( Edited December 17, 2024 by IBob
onetrack Posted December 17, 2024 Posted December 17, 2024 The way the aircraft was bouncing around on final looked like enough reason to do a go-around to me. But what would I know, I wasn't there, and who knows what pressure the pilot was under. He probably thought a cabin fire was going to break out any minute, and it was imperative to get on the ground. 1
CT9000 Posted December 17, 2024 Posted December 17, 2024 14 hours ago, onetrack said: The way the aircraft was bouncing around on final looked like enough reason to do a go-around to me. But what would I know, I wasn't there, and who knows what pressure the pilot was under. He probably thought a cabin fire was going to break out any minute, and it was imperative to get on the ground. Then put it down on the grass next to the main runway 1
