WWW.FACEBOOK.COM
🚨🚨Active Incident 🚨🚨 Paramedics have assessed 2 patients after the light aircraft they were in came down in a residential backyard at Cootharaba....
I know whose aircraft this is..looks like he is ok and the wife flown to hospital but not critical injuries thank god
  • Like 5
Might be  the one I've flown in. Had a very special Red. drive. They are quite a nice plane but I'd keep the Lycoming in it.  Nev
In the same news broadcast, a Cirrus (model unknown) was involved in an emergency landing in Texas, overshot the runway and collided with a car.
That was a Lancair 4p, normal looking circuit entry, went off end at speed on the second attempt.
Only saw it for a couple of seconds, and it was a bit blurry.
The Gastar was made originally with the suburu but he bought a Lycoming and was going to refit it I believe. I know he had just upgraded the wheels and brakes
Scott Reeman, a LifeFlight Rescue Aircrew Officer, said the plane was coming in to land on the private airstrip and “ended up somersaulting and crashing into a tree”.
“It clipped a palm tree in a house yard while it was airborne and then cartwheeled end-to-end across the yard and clipped another tree,” he said.
The pair were able to get themselves out of the wreckage, Reeman said.
https://aviation-safety.net/wikibase/347798
The wreckage of the light plane that crashed in a Sunshine Coast backyard.  CREDIT:RACQ LIFEFLIGHT
Edited by onetrack
From the pilot himself on FB only partial of hs post
His wife has a few broken ribs and some vertibrae damage but will recover ok
So, we had been out for a pleasant morning flight up the coast. We were coming in to land a got a gust of crosswind that blew the aircraft to the right, I’d initiated a go around but clipped a tree which caused us to speared into the ground.
Thankfully the Glastar has a very good safety cage and we were wearing 4 point harnesses."
  • Informative 5
On 13/11/2023 at 12:02 PM, facthunter said:
The way things are going there will be many more wind and weather related incidents/ accidents.  Nev
Do you mean as in more violent wx events due to ' climate change '?  If I remember correctly this strip is uphill several degrees to the west - which would require your go round to be initiated earlier? Most pvt strip's only have a single windsock, often lost to sight on short final. Makes it hard to detect a late wind change.  RLOC strikes again!
