Area-51 Posted April 24, 2023 Posted April 24, 2023 (edited) On 22/04/2023 at 2:33 AM, BC0979 said: Anyone have roo seats? Is the hide similar to cattle? Roo steak? Serious question Roo is softer than cow hide but tougher than sheep and pig skin... Steak is lean and tastes of full iron; unique taste and smell. Edited April 24, 2023 by Area-51
BC0979 Posted April 24, 2023 Author Posted April 24, 2023 Any similarities to Buffalo meat? Buffalo is very lean and has a mild taste, not gamey.
facthunter Posted April 25, 2023 Posted April 25, 2023 Only had NT (water) buffalo and it's full flavoured. Generally wild fowl and animals are leaner and more flavour. I don't eat much red meat these days. Nev
IBob Posted April 25, 2023 Posted April 25, 2023 We don't generally chew on our stick grips much round here..........
facthunter Posted April 25, 2023 Posted April 25, 2023 Certain people have a taste for Leather. (I'm reliably Informed). Nev 1
Marty_d Posted April 25, 2023 Posted April 25, 2023 Aircraft Spruce sells grips with 1 1/8" hole. https://www.aircraftspruce.com/catalog/elpages/hmbltcontrolstick.php
Kyle Communications Posted April 25, 2023 Posted April 25, 2023 I am about to make a new stick for my twin stick setup..it will have the Ray Allen grip on it
Marty_d Posted April 25, 2023 Posted April 25, 2023 Some of the wooden ones available look good. Maybe I'll try carving one.
spacesailor Posted April 25, 2023 Posted April 25, 2023 My sentiment entirely. Wood Never gets cold enough to freeze on your hand , also can be shaped to your hand , Large or Small . Made from " Rosewood " it doen't Burn , ( too dense, like Oak & Ironbark ) . spacesailor 1
spacesailor Posted April 25, 2023 Posted April 25, 2023 Now to get that ' Alloy ' ball , off my joystick & a nice bit of " Driftwood " shaped for my hand-size ! . But the ' ball ' atop the stick , feels good from any direction spacesailor
facthunter Posted April 25, 2023 Posted April 25, 2023 Spacey this is a "family safe" forum. remember. The OFF stuff's on the other one. Nev 1
spacesailor Posted April 25, 2023 Posted April 25, 2023 NO nothing like that . Just a Car gearshift ' ball ' . it looks good & of course being ' upmarket' is well finished . The Hoon look of yesteryear . spacesailor
facthunter Posted April 25, 2023 Posted April 25, 2023 Yeah I missed out on that. Spent every penny flying Aeroplanes. Nev
Marty_d Posted April 25, 2023 Posted April 25, 2023 4 hours ago, spacesailor said: My sentiment entirely. Wood Never gets cold enough to freeze on your hand , also can be shaped to your hand , Large or Small . Made from " Rosewood " it doen't Burn , ( too dense, like Oak & Ironbark ) . spacesailor If my joystick is in danger of burning, I've got bigger problems than what the grip is made of... 1
spacesailor Posted April 25, 2023 Posted April 25, 2023 '' If my joystick is in danger of burning, '' . Thinking of what you said !. I will 'cut a vent hole ' in the floor ,of my HummBird , to vent any ' leaking fuel ' OUT & away from my body . The amount of fuel Left from your flight , is of No use when the motor has died . But will keep the fire going longer. spacesailor
Marty_d Posted April 25, 2023 Posted April 25, 2023 I need to put another tap on the fuel line. I have a tap for each wing tank, but they're above the header tank which holds 7 litres. If there was an engine bay fire I wouldn't want fuel continuing to be provided.
facthunter Posted April 26, 2023 Posted April 26, 2023 If you isolate the fuel that's a good start to handling an engine fire but it could also be lube oil which burns quite well in it's own right. In flight fire is a real emergency where getting back on the ground safely & quickly is your top priority. Nev 1 1
facthunter Posted April 26, 2023 Posted April 26, 2023 Even if it catches fire on startup I'm sure you'll give thought to getting out of it quickly. Nev
Old Koreelah Posted April 26, 2023 Posted April 26, 2023 Good training is to sit in the cockpit and go though what you’d do in all the emergency scenarious. Putting hands on the lever, valve, switch as part of that might save a few precious moments when the proverbial happens.
spacesailor Posted April 26, 2023 Posted April 26, 2023 '' Good training is to sit in the cockpit and go though what you’d do in all the emergency scenarious. .. Unless . you do the ' start . OUTSIDE . Hand propping , may well be a dying art , but at least you can run away from that fire . spacesailor
BC0979 Posted November 19, 2023 Author Posted November 19, 2023 Just to close out this thread, I decided on natural wood grips. I am not talented in wood carving so I found a guy in Oregon that makes them. Thanks for all the valuable input 5
