Hi all.  What are the early skyfox taildraggers like.
Aeropower vw engine.
Can you check the airframe without removing the fabric .
I read that the ply wing ribs can rot and fail.
24 minutes ago, facthunter said:
Do you mean the aileron supports?   Nev
Not sure nev. I read about a skyfox that broke up in flight due to rotten ribs in one wing. I am talking about the early taildraggers not gazelles.
He is asking about the engine arrive as well, they are not the most powerful engine IMHO. At least 80 hp Rotax is best. I bent the undercarriage leg twice on my Ca21 with a 912 80hp.
Arrive is read as aerovee.
3 hours ago, onetrack said:
This was likely to be the event that Brendan is talking about.
https://www.atsb.gov.au/publications/investigation_reports/1998/aair/aair199800361
Here is the aircraft model history.
https://aeropedia.com.au/content/calair-ca-21-skyfox/
makes sense now.  plywood does not like the tropics.
The ply wood aileron hangars are good; just need to assess them and maintain them.  They don’t tolerate standing in water as the plywood rots (storing out side in rain, drain holes in underside of fabric blocked etc.).
Edited by Blueadventures
The AD linked by Onetrack above does not appear on the RAAus website, there are some listed. Bit piss poor RAAus, it should be all or nothing with a link perhaps
https://www.casa.gov.au/search-centre/airworthiness-directives-aircraft-below-5700kg
 to the casa website.
For people new to aviation it can be hard to understand how it all works. Do casa Airworthiness Directives apply to non VH aircraft?
Edited by Thruster88
Have a read of the casa Airworthiness Directives. All aircraft should now have inspection panels where required for things like the lift strut attachment etc. Yes you need to look inside the wings.
A lot of RAAus planes would NOT be but where the type is also able to be VH registered you'd be negligent in ignoring them.' Skyfox and Gazelle sare now pretty old and I noticed a  bit of airframe corrosion on some  20 years ago on the steel fuselage tubing. Some plastic parts should be checked also. I checked the elevator bell crank every flight.  The folding wings set up makes the aileron set up complex.. The TW version is not the easiest  thing to land on a rough field OR in gusts, contrasting with the Gazelle which is very forgiving. In the AIR they are similar but don't get the airspeed above 85 knots and have "G" loads or the wing may twist off. It's undercambered.   Nev
The Gazelle was a great training aircraft. Very easy to fly & forgiving. No flaps but super easy to side slip. Pretty slow but good if you are new to RA stuff from GA. It was the first RA aircraft I ever flew.  If the CA21 flys the same it will just be landing and ground handling that may be a handful in inexperienced hands
My view is the Gazelle  is the most forgiving plane you will ever fly. It's almost TOO easy to be a good trainer, but don't ever let it spiral..  My first RAAus plane was an SB Thruster 2 seat when they first came out Mid 80's . My Job was flying B 727's so you would be unlikely to get a bigger contrast. though I had access to a DH 82  occasionally.   Quite a few Airline types flew like this. Some never would but that's their choice. Nev
Edited by facthunter
