mcrowley Posted September 16, 2016 Posted September 16, 2016 Did you glue it down as well? Did you prime and paint the interior before the carpet install also? I'm at that stage and I keep dithering about putting a protective paint on the interior or just glue the carpet and save a little weight? Thanks!
Lyndon Posted September 16, 2016 Author Posted September 16, 2016 Every bit of my plane is primed in two pack. Have glued onto that. I don't know how much will dissapate but the glue is not light. I'm fitting a big prop. I'm sure it will be slow but it will climb. My thoughts are it will weigh what it will. Saying that I'm keeping every thing to a minimum Lyndon
mcrowley Posted September 16, 2016 Posted September 16, 2016 That's my thinking, I'd rather have long term protection over a few ounces. I'll also be a little heavy but should climb well as I'm building a 3.3L Corvair engine. Thanks for your thoughts, I enjoy your progress!
Lyndon Posted September 16, 2016 Author Posted September 16, 2016 Wow interesting engine. Are you building that your self or buying one done ??
mcrowley Posted September 16, 2016 Posted September 16, 2016 Building it myself, although I'm following a well established conversion manual and using high end aircraft grade conversion parts. It puts out 128 HP on the dyno. I'm currently learning how to paint :-)
Lyndon Posted September 16, 2016 Author Posted September 16, 2016 I'm not a painter but what I have learnt is make sure you have a decent size nozzle on your gun for the big parts when you want a nice finish. One dry and one wet will do the top coat. Also filter every bit of paint before going in the gun. Lyndon
mcrowley Posted September 16, 2016 Posted September 16, 2016 Excellent. Here is a link to the 100 HP version on a Zenith 701. Try not to grimace at the landing ;-) I love that sound!
IBob Posted September 16, 2016 Posted September 16, 2016 Here is a link to the 100 HP version on a Zenith 701. Try not to grimace at the landing ;-) Great sound....great looking aircraft...... erm....pity about the slats........evidently????.....................)
Lyndon Posted September 16, 2016 Author Posted September 16, 2016 Just aligned my pedals . After building it this far I just noticed when sighting up my front wheel the engine is of set about 20 mm. It occurs in the engine mount. Someone smarter than me will tell me why ??? Lyndon
rick morawski Posted September 16, 2016 Posted September 16, 2016 Just aligned my pedals . After building it this far I just noticed when sighting up my front wheel the engine is of set about 20 mm. It occurs in the engine mount. Someone smarter than me will tell me why ???Lyndon It's offset to counteract P factor of prop. Rotating prop wants to go a bit left so it is offset to the right.
Lyndon Posted September 16, 2016 Author Posted September 16, 2016 Amazing. To begin with I thought something was wrong
Lyndon Posted September 19, 2016 Author Posted September 19, 2016 I have a question. I'm working in the hole under the plane and have just done all my fuel lines. I must admit this is a lot of fun ?? Oh to be young and fit. My manual states to rivet the brackets on. This is easy without the flapperon unit and impossible with it in place. Before I go and rivet the two brackets ?? They will I take it flex enough for the flapleron unit to be squeezed in between the two brackets. Thanks Lyndon
rick morawski Posted September 19, 2016 Posted September 19, 2016 I have a question. I'm working in the hole under the plane and have just done all my fuel lines. I must admit this is a lot of fun ?? Oh to be young and fit. My manual states to rivet the brackets on. This is easy without the flapperon unit and impossible with it in place. Before I go and rivet the two brackets ?? They will I take it flex enough for the flapleron unit to be squeezed in between the two brackets.Thanks Lyndon No I wouldn't bend the brackets to get the flaps unit in. Do it with the unit in place, not impossible but difficult.
Lyndon Posted September 19, 2016 Author Posted September 19, 2016 Ok will give it a go. The rivit gun actually fit ??. I will limber up and give it a go. Thanks Lyndon Rick the rod arrived. Thanks again
Lyndon Posted September 19, 2016 Author Posted September 19, 2016 Well I riveted the right side. Bolted the left. With the nuts loose I placed the flapperon in position. Then did the nuts up. I couldn't rivet it as I only have the pneumatic one. If I did have an issue I would have a hell of time drilling them out. This way it can be removed easily. Well as easy as it will ever be.I now need a day off for back to recover Lyndon
rankamateur Posted September 19, 2016 Posted September 19, 2016 I now need a day off for back to recover A shame really, when you were having so much fun too.
rick morawski Posted September 19, 2016 Posted September 19, 2016 Next time put it in before you put the seat back/luggage shelf in, much easier on the back.
Lyndon Posted September 19, 2016 Author Posted September 19, 2016 I was thinking that. Pretty sure there won't be a next time but. Lyndon
Lyndon Posted September 19, 2016 Author Posted September 19, 2016 Do I fit bolts and lock nuts here. ?? Or is pretty much good for travel as is. I can't find anything in the manual. Lyndon
rick morawski Posted September 19, 2016 Posted September 19, 2016 Do I fit bolts and lock nuts here. ?? Or is pretty much good for travel as is. I can't find anything in the manual.Lyndon Pretty much good to go with nothing in there. You can put 6mm bolt in to limit aileron travel but I have never used it. Check aileron an other control travel at final assembly.
Lyndon Posted September 19, 2016 Author Posted September 19, 2016 Thanks for that. Jumping ahead what limits the elevator travel. I have fitted all the controls now. Quite an engineering marvel. All works perfectly and it fits Lyndon
Lyndon Posted September 19, 2016 Author Posted September 19, 2016 I'm after some fuel inlets for my carbs. Any thoughts. Really don't want new as prices are just over the top . A straight brass fitting would be fine but I believe its not a gas thread it's metric. Lyndon
rankamateur Posted September 19, 2016 Posted September 19, 2016 All works perfectly and it fits The bad news is that the little plate with the four rivets and the bolt through the middle doesn't go there. It's bolt usually has to be moved any where up to half way out to one of the mounting rivet to line up with the flaperon pivot brackets on the wing when you get the wings on.
