You have indicators (up/down) and you call them.  Quick and reliable.  Don't get Upset Don. I meant it light-heartedly, but still wanted to Make the Point about the focus of the subject.  It's a forum for ALL Pilots, and I've Instructed VH and in ultra-lights and flown Gliders. Not JUST Heavies. A lot of Heavies Pilots haven't flown U/ls but I've given them a LOT of support over the years. Nev
Gotcha. So the feedback sensors are physically on the control surfaces. Along the lines of the undercarriage down switches.
Not sure who Don is, but I don't want him to be upset either 🙂
U/C etc have Micro switches and can have sequencing switches. Gear doors close after wheels are UP and operate the indicator lights. 3 greens. Nev
Danny,
This is how it happens on any airbus:
During taxi both pilots do a flight control check. As soon as a sidestick moves the flight control page on the lower centre screen is displayed. The pilot flying announces, "flight control check" and moves the stick full up, full down, neutral, full left, full right, neutral. As this occurs the support pilot calls that as it is displayed on the screen with the exact words as I have written. The PF then says "rudder". He/she presses a button on the middle of the steering tiller. This disengages the rudder from the steering system whilst pressed so that when the rudder is moved it does not affect the steering of the aircraft. They then with feet push left then right rudder. The support pilot again calls what he see from the screen, "full left, full right, neutral". The PF releases the button and continues looking outside while the other pilot silently does their flight control check by moving their stick in the same manner and confirming correct movement from the screen. A few seconds after the stick movements are completed the flight control screen automatically reverts to another systems page.
PS. Don't ask me how I know this 🙂
Edited by Gadjet
12 hours ago, Gadjet said:
Danny,
Yes, once Nev answered I realised I knew all along. My concern was how do you know the actual surface is moving, and in the right direction. That is, what is there, at that point, to tell you. And I knew the answer all along, from having flown the Tecnam Golf with it's electric flaps and trim. Your 'guy in the know', so to speak is (on the tecnam) a potentiometer on the flaps and elevator, sending it's position by wire back to the cockpit which gives me a direct correlation with position which is interpreted by a gauge or leds on the panel. Works pretty much like a fuel level sender. Every other aircraft that needs it will have a  variation on that, pots or hall effect sensors or grey scale encoders etc for variable positions like trim, or simply switches for undercarriage or that aileron rudder check you described etc. and then dedicated gauges, or as you big boy drivers have, a readout on a LCD panel ☺️
