skippydiesel Posted June 26 Posted June 26 Just in case there are Rotax owners who do not get the Rotax ASB's or CASA Airworthiness Directives EASA AD 2026-0121-E 😈 2
SGM Posted June 26 Posted June 26 and if you want to search for your engine/gearbox number... ASB_A-2026-001- Inspection of the propeller gearbox for ROTAX 912,914 and 912i Series Aircraft Engines.pdf 1 2
rgmwa Posted June 26 Posted June 26 That's a LOT of engines, and the unlucky owners won't be happy. Luckily mine's not on the list. 1 1
facthunter Posted June 26 Posted June 26 They charge enough for their Product. Leaving bits out is not good enough. Nev 1 4
BurnieM Posted June 26 Posted June 26 Is warranty 2 years ? If in warranty I guess Rotax cover the removal and inspection and if required gearbox replacement. If outside warranty is there any coverage or are you just expected to cough up $6k plus labour ? Lots of serial numbers in that SB including spare part gearbox only. 1
KRviator Posted June 26 Posted June 26 25 minutes ago, BurnieM said: Is warranty 2 years ? If in warranty I guess Rotax cover the removal and inspection and if required gearbox replacement. If outside warranty is there any coverage or are you just expected to cough up $6k plus labour ? Lots of serial numbers in that SB including spare part gearbox only. The protections of the Australian Consumer Law may come into play here - just because something is outside a manufacturers or statutory warranty doesn't mean your SOL. We're going through that kerfuffle now with our pool - turns out the builder we used wasn't licensed to actually do pool installs and royally phucked the pavers and fencing which is now failing. His response? "Not my problem, it's non-structural and only has a 2 year warranty!" - so we're pursuing him under the "Not done with due care and skill;.." section of the ACL rather than the Home Building Act. 3
facthunter Posted June 26 Posted June 26 Leaving a Part out should have No time limitations. Any secondary damage to the gearbox or motor caused as a result of it should be covered also.. A motor supplied in that state is not fit for purpose. Nev 2
BurnieM Posted June 26 Posted June 26 (edited) Second problem is that if there are a few gearboxes that need replacing do Rotax have enough spares in stock ? If my plane was not airworthy for 6 months I would not be happy. Seems to me Rotax have had a number of manufacturing quality control problems in the last 2 years. Makes you wonder what is going on ? Edited June 26 by BurnieM 1
facthunter Posted June 26 Posted June 26 Cross that bridge when you come to it.. Your entitlement to it is more important at this stage. . Nev
skippydiesel Posted June 26 Author Posted June 26 59 minutes ago, BurnieM said: Lots of serial numbers in that SB including spare part gearbox only. You have made a very good point ITS NOT JUST ENGINE SERIAL NUMBERS - anyone who has replaced a gear box needs to check GEARBOX SERIAL NUMBERS😈 1
T510 Posted June 27 Posted June 27 1 hour ago, BurnieM said: If outside warranty is there any coverage or are you just expected to cough up $6k plus labour ? In the Rotax service bulletin it says "Labor time A labor credit will be provided for work performed by a technician with current applicable iRMT rating. To apply for labor credit, contact your ROTAX® Authorized Distributor or their independent Service Centers." Also "Any possible support by BRP-Rotax will be provided on request by ROTAX® Authorized Distributors or their independent Service Centers. Exchanged parts must be returned FCA (Free Carrier) and/or proof of scrapping parts must be provided to ROTAX® Authorized Distributors or their independent Service Centers. This exchange program and cost sharing is valid until June 23th 2027. Up to this date limited reim-bursement of costs can be applied for. Shipping costs, downtime costs, loss of income, telephone costs etc. or costs of conversion to other engine versions or additional work, as for instance simultaneous engine overhauls are not covered in this scope and will not be borne or reimbursed by ROTAX®." 1
Thruster88 Posted June 27 Posted June 27 Removing the fuel pump and using a borescope should show if the 4 bearing screws and the oil jet are in place. This may not be an approved procedure. 2 3
T510 Posted June 27 Posted June 27 33 minutes ago, Thruster88 said: Removing the fuel pump and using a borescope should show if the 4 bearing screws and the oil jet are in place. This may not be an approved procedure. It's described as an approved method in the Rotax document if I read it correctly 3 1
Moneybox Posted June 27 Posted June 27 I can’t get to check my engines but I expect they are too old to be included. Pity, because it might be a good opportunity for an internal inspection with most of the labour covered. 1 1
