Feature      Vane-Based System     Pressure-Ratio Based System
Primary Method
  • Mechanical Alignment
  • Pressure Ratio
Complexity
  • High (Mechanical components such as bearings and seals)
  • Low (No moving parts)
Installation
  • Requires a precision-cut hole in the aircraft’s skin and complex internal electronics
  • Can be bolted on or integrated into an existing plate, making it a much simpler retrofit for GA aircraft.
Accuracy
  • Accurate across all flight regimes.
  • Accurate across all flight regimes, except during significant slips/skids.
Maintenance
  • Requires thorough inspection for sticking, wear, and damage before every flight.
  • Low maintenance; primarily requires keeping the ports clear of debris.
Failure Modes
  • Mechanical jamming, bird strikes, icing, snow, or heavy rain; often fails without warning.
  • Blocked ports (ice/bugs) or water in lines, but includes built-in diagnostic warnings.
Weight/Size
  • Larger, heavier, and creates more aerodynamic drag.
  • Smaller, lighter, and creates lower drag.
Target Aircraft
  • Preferred for commercial airliners and fighter jets due to high sensitivity; typically 2 to 4 redundant units per aircraft.
  • Widely popular in General Aviation because they are lighter, cost-effective, and easier to install.
Summary
If you are flying a high-performance jet where precision at Mach speeds is critical, a redundant vane-based system is the industry standard. However, for those flying light piston or turboprop aircraft who want a reliable, low-maintenance safety tool to prevent stalls and loss-of-control accidents, a pressure-ratio system is usually the more practical and cost-effective choice.
Advanced pressure-ratio systems have the ability to sense blocked ports and produce appropriate cockpit warnings. Historically, fatal accidents resulting from relying on false indications from damaged vane-based systems have even forced some manufacturers of those systems out of business.
Edited by Frank JK
Allignment Correction
I have an AoA through my Dynon Classic - no other stall warning device.
Its satisfying to hear it sound, as I flair for landing - tell myself my speed was about right.
Have heard it, on rare occasion, in a tight turn, which is good, as it alerts me to keep my speed/power up.
The visual display, is way too small and below the glare shield (out of line-of- sight), so its of little use when landing. I guess I could set it to go off at higher speeds but then I may find I am too fast on approach.
Many "wax lyrical" about these devises as a landing aid - could be good for STOL, when there is a visual display up on glare shield/HUDS .
I wonder if relying on an AoA makes you less able to land without it and possibly airspeed as well ? - something I have had to do on three occasions (tiny little ants in my system).😈
I have pointed out  advantages  but not linked to actual landing judgement. It's mainly the Indication/confirmation of stall  safety Margins in various configurations and weights and manoeuvres..  Very useful if you have a complex Flap /Slat retraction schedule.  It doesn't show overspeeds etc Just AoA related stuff.   Nev
