Marty_d Posted 23 hours ago Posted 23 hours ago Interesting piece about Germany working on intelligent trailing edge warping instead of flaps/ailerons. As much as I don't want AI in the cockpit, the concept is intriguing. Mighty morphin' flap-less wings trialed on experimental aircraft NEWATLAS.COM Imagine looking out the window of an airborne airplane and seeing the wing rippling and twisting. You'll probably...
pmccarthy Posted 22 hours ago Posted 22 hours ago It surely must be the way of the future, eventually giving us control like birds have. But that might take another fifty years. 1
Thruster88 Posted 16 hours ago Posted 16 hours ago I believe it is aerodynamicly advantageous for the wings on heavy aircraft to separate into the multiple separate high lift devices that we see on every airliner for take off and landing. 1
skippydiesel Posted 12 hours ago Posted 12 hours ago 3 hours ago, Thruster88 said: I believe it is aerodynamicly advantageous for the wings on heavy aircraft to separate into the multiple separate high lift devices that we see on every airliner for take off and landing. True but is till only mans best effort at emulating what nature has crafted for birds.😈
facthunter Posted 11 hours ago Posted 11 hours ago No Bird ever flew supersonic.. Speed range requires those Lift devices and also the drag(Lift destroyers.) Without ground spoilers you wouldn't get Much brake effect at high speeds and the Plane could skip a long distance at touchdown. Large slotted flaps reduce the Landing distances required substantially. Planes like the B 727 are a good example. Flaps are not permitted to be extended above FL210. Spoilers anytime. Once the flaps are retracted only the smaller inboard ailerons operate.. Having the 3 engines at the rear enables full trailing edge flap to be used . The flap limits the Bank available when Landing. Nev
facthunter Posted 10 hours ago Posted 10 hours ago Applying aileron at High speeds applies a lot of twisting force to the Wing structure itself. You can even get aileron reversal effect. Nev
Thruster88 Posted 10 hours ago Posted 10 hours ago 18 minutes ago, facthunter said: Applying aileron at High speeds applies a lot of twisting force to the Wing structure itself. You can even get aileron reversal effect. Nev Do you mean the aileron acts like a trim tab?
facthunter Posted 10 hours ago Posted 10 hours ago YES. That's how you rip wings off C- 210's. Happened quite a few times. Usually on a base turn in the circuit. Nev
kgwilson Posted 8 hours ago Posted 8 hours ago Wing warping excels in slow flight. That's how hang gliders are controlled. The early Rogallo gliders of the 1970s had large billowing sails with few if any battens to maintain some rigidity & could perform 360 degree turns in not much more than their own length. 1
Marty_d Posted 8 hours ago Author Posted 8 hours ago My main issue with this is not the concept, the mechanics or even the structure - it's trusting AI to control it.
facthunter Posted 6 hours ago Posted 6 hours ago It would be difficult to structure a Wing to warp satisfactorily at High speeds (damping). As KG says it's real good for LOW speed manoeuvring. Tiny controls work at High cruise speeds. Savage control capability at high speed risks overloading the Airframe inadvertently, with just a bump of the Hand. Nev
