I was going to do an oil change this weekend, but realised I don't have a new crush washer for the oil tank, which it's recommended to change. I have a feeling my oil tank just has a copper washer, but I could be misremembering it. What are people's experiences here? Can a copper washer be substituted? If I need the crush washer, where are people buying them from?
As long as it hasn’t been over tightened before you’ll most likely be able to reuse it. If you can’t get you hands on one and it’s solid metal it could be annealed and reused.
My experience with purchasing Rotax parts is you could save a few bucks by buying an assortment box of sump plug washers from your local automotive part supply.
If the washer has a neoprene seal inserted then a hydraulic parts supplier should have one.
  • Informative 3
Reuse original one this time, make sure you use two spanners on drain nut. One for can hex and one on drain nut and undo between spanner forces.
Edited by Blueadventures
"I have a feeling my oil tank just has a copper washer, but I could be misremembering it. What are people's experiences here? Can a copper washer be substituted? If I need the crush washer, where are people buying them from?"
It should be a "copper crush washer".
Yes any correctly sized sump style washer, can be substitutes  eg soft aluminium, solid copper, neoprene, etc.
The above washers can be purchase from almost any auto accessory supply store.
I purchased my "stash" from Floods at the same time that I purchased oil filters. I get x3 washers to filters, as I use the same crush washer on the magnet and I practise 50 hr oil changes, filter at 100 hrs.😈
THAT would be a' single use' washer, so should not be reused, by rights   I'd also recommend filter and oil at the same time . Nev
Yes, there is a reason I'm doing this, as you would note from the oil filter cutter thread ☺️
Mind you, when I drove old clunkers, I used to change the filter every second oil change. And air filter? The engines still running , isn't it? I just didn't worry on a five hundred dollar car 😄
THAT would be a' single use' washer, so should not be reused, by rights   I'd also recommend filter and oil at the same time . Particularly with an aircraft where the oil can be costly... so why not do the Job properly and cut the filter open as well? It's in an aeroplane. Nev
Edited by facthunter
expand
Electrician arrived and power off for a while.
  Old clunkers need filter changes more often. You are trying to ensure reliability. OK IF you just drive to the Pub and back. Nev
I had a few motorcycles (20-25?) and after the first one I never replaced the crush washer just keep reusing it. Never had a leak. The main thing is not to overtighten the drain plug.
Edited by BurnieM
If you just drive to the pub and back you should change your oil more often.
There are "crush washers" and then there are other washers;
  • The crush washers supplied by Rotax are really one use items (very thin formed/folded copper)- at a pinch may do a second period.
  • Soft thick, aluminium, copper, washers can be used almost indefinitely, with care (as you suggest).
  • Thick plastic/neoprene types, can also be used many times, with similar care but doubt you will get the X uses that the above may deliver.
  • Rubber - with extreme care (very low tightening/torque) may give weep free service, once if you are lucky.
The old style thick aluminium, copper, plastic, are not see easy to find these days, in the the automotive stores😈
My brother bought a 1970 Mazda Capella new, took it back for the first free service and never removed the drain plug after that. It lived for nearly 200,000km before it was sold. He said he saved a fortune on service costs.
  • Sad 1
It takes a LOT to totally block an oil filter. And the oil itself, it was always pretty fresh, since I had to keep topping em up all the time. My worst was a Mustang I drove from Vancouver BC to Phoenix AZ. I could only buy 1 litre bottles of oil at the time. So I bought four and pretty much used them up in two weeks 😄
