skippydiesel Posted November 28, 2025 Posted November 28, 2025 From RAA Members and Subscribers Newsletter; "AvTraffic™ air traffic conflict monitoring and alerting app for iPhone and iPad. In today’s increasingly busy airspace, AvTraffic is a powerful, practical safety tool for pilots. Designed to operate either as a standalone app or alongside your preferred EFB—such as OzRunways™—AvTraffic enhances traffic awareness by monitoring and alerting using multiple data sources, including: ADS-B traffic from your ADSB-IN or electronic conspicuity device (e.g. SkyEcho2) AvTraffic provides both visual and audible alerts and integrates seamlessly with your existing EFB map display. Its key advantage? It shows traffic even from pilots who aren’t using the same EFB platform as you. You can also route audible alerts directly to your Bluetooth headset—delivering superior situational awareness in busy airspace while keeping your eyes outside the cockpit" Most if my flying starts & finishes in congested airspace. Consequently I am intersted in any system/technique that might assist in allerting me to aircraft in my proximity (10NM?) especially those that may be closing with my position. I ave three conspicuity devices in my aircraft two of which display on my iPad ie require me to look at my panel The above infomercial caught my eye. Something that will give me an audible warning, freeing my eyes for look & avoid - sounds great. Unfortunatly I am of a generation that doesn't quite grasp the compatibilities of systems - so hoping the Forum will give me some advice. I use a recently refurbished David Clark H10-13X ENC head set - works very well. The AVTraffic appears to works via Bluetooth to a headset (also Bluetooth??) - I assume I will either need a Bluetooth compatible headset or a Blue tooth/headset adapter . Is there a Bluetooth adapter for an old tech headset? If so what does the Forum recomend?😈 1
BrendAn Posted November 28, 2025 Posted November 28, 2025 found this. It might be what u are looking for. 1
skippydiesel Posted November 28, 2025 Author Posted November 28, 2025 Thank BrendAn - have writen to the company😈 1
BrendAn Posted November 28, 2025 Posted November 28, 2025 (edited) 2 minutes ago, skippydiesel said: Thank BrendAn - have writen to the company😈 Can you let us know if you get one. I have a bose anr headset and would like to add Bluetooth as well Edited November 28, 2025 by BrendAn
Thruster88 Posted November 28, 2025 Posted November 28, 2025 7 minutes ago, skippydiesel said: Thank BrendAn - have writen to the company😈 There is a Bluetooth adapter available in the shop right here at Aircraft Pilots. 1
BrendAn Posted November 28, 2025 Posted November 28, 2025 Just now, Thruster88 said: There is a Bluetooth adapter available in the shop right here at Aircraft Pilots. Thanks . Will have a look
skippydiesel Posted November 28, 2025 Author Posted November 28, 2025 1 hour ago, Thruster88 said: There is a Bluetooth adapter available in the shop right here at Aircraft Pilots. Yeah! - had a look yesterday - couldn't make "head nor tail" Hence my contacting the learned member's of the Forum Which one, of the several similar sounding units, will do the job for me??.😈
Thruster88 Posted November 28, 2025 Posted November 28, 2025 Headsets :: Headset Accessories :: Aircraft Pilots Headset Bluetooth Cell Phone & Music Adapter - GA WWW.CLEARPROP.COM.AU Headset Bluetooth Cell Phone & Music Adapter - GA Introducing the Aircraft Pilot s Headset Bluetooth Mobile Phone Adapter with GA Plugs and Auxiliary Input the ultimate solution for seamless communication... This one, has a full description of what it will do.
BrendAn Posted November 28, 2025 Posted November 28, 2025 1 minute ago, Thruster88 said: Headsets :: Headset Accessories :: Aircraft Pilots Headset Bluetooth Cell Phone & Music Adapter - GA WWW.CLEARPROP.COM.AU Headset Bluetooth Cell Phone & Music Adapter - GA Introducing the Aircraft Pilot s Headset Bluetooth Mobile Phone Adapter with GA Plugs and Auxiliary Input the ultimate solution for seamless communication... This one, has a full description of what it will do. You have better eyes than me. I can only find one with a heli plug
Blueadventures Posted November 28, 2025 Posted November 28, 2025 Just now, Thruster88 said: 3rd item in Headset accessories. Correct, listed in incorrect heading. 1
Mewp Posted November 28, 2025 Posted November 28, 2025 click on the heading will take you to the shop entry
skippydiesel Posted November 29, 2025 Author Posted November 29, 2025 (edited) 45 minutes ago, Thruster88 said: Headsets :: Headset Accessories :: Aircraft Pilots Headset Bluetooth Cell Phone & Music Adapter - GA WWW.CLEARPROP.COM.AU Headset Bluetooth Cell Phone & Music Adapter - GA Introducing the Aircraft Pilot s Headset Bluetooth Mobile Phone Adapter with GA Plugs and Auxiliary Input the ultimate solution for seamless communication... This one, has a full description of what it will do. Yes I read that BUT there is no mention of connection with an iPad, nor am I the least bit intersted in "Cell Phone & Music" - just want to be able to receive verbal/in head set, aircraft in proximity /conflict messages - Will this gizmo do this for me? How is it powered? What is an "Auxiliary Input."? 😈 Edited November 29, 2025 by skippydiesel
BrendAn Posted November 29, 2025 Posted November 29, 2025 21 minutes ago, skippydiesel said: Yes I read that BUT there is no mention of connection with an iPad, nor am I the least bit intersted in "Cell Phone & Music" - just want to be able to receive verbal/in head set, aircraft in proximity /conflict messages - Will this gizmo do this for me? How is it powered? What is an "Auxiliary Input."? 😈 Auxiliary input is for a physical cable. Your iPad should have Bluetooth. 1
Blueadventures Posted November 29, 2025 Posted November 29, 2025 28 minutes ago, BrendAn said: Auxiliary input is for a physical cable. Your iPad should have Bluetooth. Be good to view a user manual and likely require power via a cord (USB or similar) Not branded either. 1
skippydiesel Posted November 29, 2025 Author Posted November 29, 2025 BrenDan - I appreciate your willingness to help this old duffer BUT ; Aircraft Pilot's Headset Bluetooth Mobile Phone Adapter with GA Plugs and Auxiliary Input The photos show what looks to be two male & two female jacks. I assume this is for the input/ear circuit of the headset (s). I do not see an "Auxiliary Input." Nor do I see any mention of how the unit is powered. Yes my iPad has Bluetooth and it may be able to deliver music (never tried), definitely no phone, although it does have a Telstra "chip". Does the existing iPad Bluetooth automatically mean that it will connect with this headset adapter device & deliver the warning messages from AvTraffic? Then there is the BLULINK INTERFACE/GA - even less information. 😈 1
skippydiesel Posted November 29, 2025 Author Posted November 29, 2025 Found this - Aircraft Spruce $95/43 + delivery. It happens to have a good explanation of what it does & how its powered 😈
BrendAn Posted November 29, 2025 Posted November 29, 2025 (edited) 8 minutes ago, skippydiesel said: Found this - Aircraft Spruce $95/43 + delivery. It happens to have a good explanation of what it does & how its powered 😈 Does it answer your question about delivering avtraffic alarms Edited November 29, 2025 by BrendAn
skippydiesel Posted November 29, 2025 Author Posted November 29, 2025 (edited) 1 hour ago, BrendAn said: Does it answer your question about delivering avtraffic alarms "If you use an iPad with ForeFlight, Garmin Pilot, or any navigation software/device with terrain or traffic notifications, you need the BLUETOOTH Headset Interface. Our Bluetooth interface allows you to WIRELESSLY hear "TERRAIN" warnings or "TRAFFIC" notices, right in your headset - without the risk or inconvenience of wires!" https://www.aircraftspruce.com.au/catalog/avpages/crazedpilot11-14137.php 😈 Edited November 29, 2025 by skippydiesel 1
BrendAn Posted November 29, 2025 Posted November 29, 2025 I have asked this question before but forget the answer. On Oz runways I can see aircraft around me. Do those planes have adsb or is it Oz runways own signal
Blueadventures Posted November 29, 2025 Posted November 29, 2025 21 minutes ago, BrendAn said: I have asked this question before but forget the answer. On Oz runways I can see aircraft around me. Do those planes have adsb or is it Oz runways own signal Oz shows oz and skyecho 2 will bring in others. 1
skippydiesel Posted November 29, 2025 Author Posted November 29, 2025 (edited) SE2 is a ADSB IN/OUT devise - so yes it "brings in others" but only ADSB transponders. This is a big step forward HOWEVER older Mode C (I think) systems will not appear on your EFB. The three deaths at The Oaks (12 months ago) - the Cessna 182 had the old transponder, the Jabiru an SE2/OzRunways. Not saying the incompatibility of the systems was the cause of the mid-air, just that if they had both been on the same system, there may have been a chance for evasive action. We have this crazy situaton with aircraft flying in congested airspace with the older (legal) transponders - can be "seen" by ATC but not by OZRunways/SE2 - go figure!!!!!!😈 Edited November 29, 2025 by skippydiesel 2
skippydiesel Posted December 2, 2025 Author Posted December 2, 2025 On 29/11/2025 at 12:10 PM, skippydiesel said: Found this - Aircraft Spruce $95/43 + delivery. It happens to have a good explanation of what it does & how its powered 😈 Check out the reviews - https://www.aircraftspruce.com.au/catalog/avpages/crazedpilot11-14137.php. An uncomfortable number of unhappy purchasers, with just a few rave reviews. Price is great. Instructions good. Looks nice & simple, small/light weight. Aircraft Spruce is a reputable supplier - anyone had a bad experince with them? What do you think? 😈
BlurE Posted December 3, 2025 Posted December 3, 2025 I have just flown with this for the first time today and I have to say I am quite impressed. I have been flying with Ozrunways with ADSB in for years but was always concerned that I couldn't 'see' regular (non-ADSB) transponder traffic or Avplan users. This might be finally something that beings all sources together* *Noting transponders not mandatory VFR class-G and, yes, yes eyeballs are still important. 1
