Lyndon Posted June 14, 2025 Posted June 14, 2025 What's a good comfortable grip and what are people putting on it. I have manual flaps so we can remove this. Thanks Lyndon
Underwood Posted June 14, 2025 Posted June 14, 2025 I tend to use MX type motorcycle grips, ODI make decent ones 1
rgmwa Posted June 14, 2025 Posted June 14, 2025 Ray Allen make a good but expensive range of stick grips. I just have the basic PTT foam grip but you can get much more fancy ones. Available from Skyshop or Aircraft Spruce and probably other places. I ordered mine direct from Ray Allen in the US.
Moneybox Posted June 14, 2025 Posted June 14, 2025 I bought originals from Evektor. The invoice showed bicycle grips.
skippydiesel Posted June 15, 2025 Posted June 15, 2025 In Cruise, I fly with the proverbial "two " fingers, about midway down the stick, so that my arm rests on my knee/thigh. I may add further fingers, as required, in strong turbulence. My hand turned "grips" look good, are comfortable, do give my hand a place to reside in more demanding stages of flight - TO, Climb, descent to Landing.😈 1 2
skippydiesel Posted June 15, 2025 Posted June 15, 2025 Better - more advanced pic; PTT buttons are from JayCar😈
Moneybox Posted June 15, 2025 Posted June 15, 2025 8 hours ago, skippydiesel said: In Cruise, I fly with the proverbial "two " fingers, about midway down the stick, so that my arm rests on my knee/thigh. I may add further fingers, as required, in strong turbulence. My hand turned "grips" look good, are comfortable, do give my hand a place to reside in more demanding stages of flight - TO, Climb, descent to Landing.😈 Very nice, what timber did you use?
Lyndon Posted June 15, 2025 Author Posted June 15, 2025 PTT Radio flip flop Trim AP disconnect Ident AP level On the other side a trim and PTT. Lyndon
KRviator Posted June 15, 2025 Posted June 15, 2025 I use a pair of customized grips from Infinity Aerospace. They are highly customizable for your application in terms of pushbutton (NO/NC/Momentary) or lever-action and have left & right styles available. Well worth it if you want more than a couple of features on your stick. In my application, I have them assigned as follows: Trigger: PTT Pinkie: Engine Start (not connected on Coey's grip) Thumb pushbutton: AP Disconnect/CWS Inboard rocker: Flaps 'Coolie hat': Pitch & Roll trim Outboard rocker: Rudder trim (Not installed "yet") The switches usually ground a particular circuit, so if you gang the grounds together, then route them through another NO rocker switch on the panel labelled "Copilot Disc" you can disable all features from the Coey's grip if you don't trust them to not lower the flaps at cruise speed, or similar.
skippydiesel Posted June 16, 2025 Posted June 16, 2025 15 hours ago, Moneybox said: Very nice, what timber did you use? Sorry, no recollection - possibly yellow box.😈 1
Red Posted June 16, 2025 Posted June 16, 2025 18 hours ago, Lyndon said: PTT Radio flip flop Trim AP disconnect Ident AP level On the other side a trim and PTT. Lyndon So you want all that on the grip?, would have helped if you said that in the first post 1
skippydiesel Posted June 16, 2025 Posted June 16, 2025 There is a real danger that those with "Top Gun" phantasies, will complicate what should be a simple system and in doing so have less reliable electrical control . Dont know to what aircraft Lyndon is wishing to fit this fancy "stick grip" If its anything less than a military turboprop trainer, he might like to consider - what is to be achieved by doing so?😈
danny_galaga Posted June 16, 2025 Posted June 16, 2025 On 15/06/2025 at 10:56 AM, skippydiesel said: In Cruise, I fly with the proverbial "two " fingers, about midway down the stick, so that my arm rests on my knee/thigh. I may add further fingers, as required, in strong turbulence. My hand turned "grips" look good, are comfortable, do give my hand a place to reside in more demanding stages of flight - TO, Climb, descent to Landing.😈 Two fingers? Luxury! The Bushcat has very heavy ailerons. Have to lead with rudder. I suspect if ever I needed to fly an Edwardian aircraft, I would need no further training 😄
skippydiesel Posted June 16, 2025 Posted June 16, 2025 11 hours ago, danny_galaga said: Two fingers? Luxury! The Bushcat has very heavy ailerons. Have to lead with rudder. I suspect if ever I needed to fly an Edwardian aircraft, I would need no further training 😄 Hi Danny, Yes the Sonex Legacy almost flies, in Cruise, hands & feet off. Very light controls. I say almost, because its designed as an aerobatic aircraft (Neutral stability ?) which does mean it does not return to set level/direction if disturbed. No rudder inputs are required, assuming no steep turns initiated, once established in Cruise, unlike the Zephyr which seemed to like / respond very well to rudder at all stages of flight. 1
