1 hour ago, Blueadventures said:
Agree, talk about making a mountain out of a mole hill.  A test fine polish cut would be all and some different shades would still exist.  Do it on boat hulls all the time.  The old rego numbers show due to the gel coat having been shaded by the numbers.
Attached is what I posted that I use.
If you care to go back you'll see what we recommended for the OP and the op said it didn't work. Under those circumstances, Meguiars wouldn't be able to do any better.
So some of us went looking for further solutions and if you look up a few posts you'll see that Skippy asked a very reasonable question and I gave him the best answer I could.
What would you have preferred I do to Skippy? tell him to belt up?
Thanks, I'm not sure if that is available in the UK but I'll look into it.
Sorry my question turned into such a thing, it isnt really a biggie just aesthetics really
Blue skies
As at times your wrong, as he only used Starbrite which is a sort of acid based cleaner for stains, what I posted is perfect for a detail and surface protection, the. See what’s still there and the UK guys will has good advice.
Blue skies
Is over your way, this is UK available.  Don't apply over any stickers.  I go around all mine, details of use will be in the instructions.  Cheers.  Post an image of your bird in the Skyranger forums under a new topic say 'UK Skyrangers'.  Best Regards.
Edited by Blueadventures
