onetrack Posted January 19, 2025 Posted January 19, 2025 (edited) This Welsh bloke has found some great spots for military aircraft spotting, as they zoom through the valleys below him. Some good footage here, even though it's Winter there. Mach Loop - Wikipedia EN.WIKIPEDIA.ORG Edited January 19, 2025 by onetrack addendum... 3
facthunter Posted January 19, 2025 Posted January 19, 2025 You won't see a Hercules banking steeply. Transports don't have high load factors. Faster planes have to bank more steeply with the same turn radius Just like motorbikes do. Nev 1
BrendAn Posted January 23, 2025 Posted January 23, 2025 we have a spot like that here. the macalister valley in gippsland. raaf used to use it for low level training. my uncle was grading a road once and said he looked down at 2 jets as they flew past. probably macchis or mirages. would be great to see. 1
BrendAn Posted January 23, 2025 Posted January 23, 2025 On 20/01/2025 at 10:18 AM, facthunter said: You won't see a Hercules banking steeply. Transports don't have high load factors. Faster planes have to bank more steeply with the same turn radius Just like motorbikes do. Nev how many deg do you consder steep when banking.
Red Posted January 23, 2025 Posted January 23, 2025 its an A400M They fly past my house often before turning low level up a valley Here is a pic 4 1
turboplanner Posted January 23, 2025 Posted January 23, 2025 ...a lot of other houses as well apparently. Mountain Passes South Africa (Action photo of the day) where Lucy innocently asks: "What's happening to the road at the bottom of the photo?" Las Vegas Athletics Club (reversed photo) RAF A400 following the road 4 years ago r/aviation Airlines.Net 4 years ago Pinterest - several Tranquil Flight Scene Jet refuelling over landscape [really] Qatar Airways Wallpaper Linkedin Defence Express 1
Red Posted January 23, 2025 Posted January 23, 2025 This was taken in Wales, a looooong way from South Africa but to answer the road question it is simply obscured by the rising terrain in the foreground. Nice googling btw🤣
Bosi72 Posted January 23, 2025 Posted January 23, 2025 8 hours ago, BrendAn said: we have a spot like that here. the macalister valley in gippsland. raaf used to use it for low level training. my uncle was grading a road once and said he looked down at 2 jets as they flew past. probably macchis or mirages. would be great to see. I am frequent visitor to Licola area and always hoping to see a training aircraft. VTC chart still has an information about random low level mil flying. 1
BrendAn Posted January 23, 2025 Posted January 23, 2025 3 minutes ago, Bosi72 said: I am frequent visitor to Licola area and always hoping to see a training aircraft. VTC chart still has an information about random low level mil flying. Hi bosi. I assume they still do it. You would have to be lucky to see it though. They usually don't fly weekends and holidays. I miss the days when the jets were flying. Much more exciting to watch than pc21s 1 1
facthunter Posted January 23, 2025 Posted January 23, 2025 Airliners can't exceed 30 degrees these days without having to answer for it. The load when banked depends on the AoA of the wing and Airspeed. The AoA is controlled by the Elevators. I'd consider above 50 degrees steep if I had to pick a figure. A well executed barrel roll wouldn't pull excessive "G" or spill a cup of coffee. Nev 1
BrendAn Posted January 23, 2025 Posted January 23, 2025 1 hour ago, facthunter said: Airliners can't exceed 30 degrees these days without having to answer for it. The load when banked depends on the AoA of the wing and Airspeed. The AoA is controlled by the Elevators. I'd consider above 50 degrees steep if I had to pick a figure. A well executed barrel roll wouldn't pull excessive "G" or spill a cup of coffee. Nev I read a pilots story about flying a Hercules. He said 60 degree banks are normal for them. I guess they are trained to get in and out quickly to avoid ground attack. 1
facthunter Posted January 24, 2025 Posted January 24, 2025 They are not stress rated for much more, nor are airliners. IF you hit turbulence at the same time it's additive. 60 is 2 G that's safe in still air Goa bit more and it increases faster per degree. ..Nev 1
onetrack Posted January 24, 2025 Author Posted January 24, 2025 The bank angle is difficult to gauge from many shots, due to camera angles, lens distortion, and viewers position - but the A400M bank certainly does appear to be more than 60°. I'm surprised there isn't more wing flex visible on the steep banking turns, the A400M must have a pretty stiff wing. Get a look at the numbers of people standing on the steep slopes, to get their own particular, "outstanding photo"!
