Lyndon Posted September 30, 2024 Posted September 30, 2024 I'm going to incorporate an auto pilot into my build. Do I spend the extra dollars and get a 3 axis over the 2 ??? Lyndon
Deano747 Posted September 30, 2024 Posted September 30, 2024 I would think that it depends on how much adverse yaw your aircraft exhibits. Pronounced amount, then yes. Tiny amount, probably spend elsewhere. Will the autopilot work through your electric trim motors, or seperate?
Lyndon Posted September 30, 2024 Author Posted September 30, 2024 I have no idea how it flies. It's a kit and I'm doing the options now. Eg they will weld a bracket for the yaw sevo. It's not cheap for a bracket I may not ever use . Roll and pitch Ive already included.
Lyndon Posted September 30, 2024 Author Posted September 30, 2024 I'm not sure Dynon do a 3 axis. That is my initial thoughts for Avionics on the build. So it may require Garmin. Lyndon
spacesailor Posted September 30, 2024 Posted September 30, 2024 just get a ' mother-in-law ' . LoL Then again 3axis will be the cheapest option. spacesailor 1
rgmwa Posted September 30, 2024 Posted September 30, 2024 I have a Dynon two-axis autopilot in the RV-12 (standard for the 12 kit). Can't see the need for three-axis. The two-axis works fine.
Lyndon Posted September 30, 2024 Author Posted September 30, 2024 Thanks. That makes sense. You have been happy with the Dynon ?
rgmwa Posted September 30, 2024 Posted September 30, 2024 Yes. Great product. Free periodic software updates. Does the job. Of course Garmin does too, but I think Dynon is better value for money.
mkennard Posted September 30, 2024 Posted September 30, 2024 I like my Dynon as well. I'm very sure there is a yaw dampner there but for me, don't need the extra weight for the minimal use.
Flightrite Posted October 3, 2024 Posted October 3, 2024 It’s rare to have a 3 axis A/P in a light A/C. There’s simply no need for it. TruTrack is a nice unit as is the Trio Pro, even the earlier Trio EZ3 with the seperate Alt Module is very capable, there’s no need to spend big bucks on fancy Dynon and Garmin unless you want to go full on IFR.
Freizeitpilot Posted October 3, 2024 Posted October 3, 2024 (edited) Kanardia ? Edited October 3, 2024 by Freizeitpilot
fallowdeer Posted October 3, 2024 Posted October 3, 2024 Plenty of adverse yaw in a Savannah but the Dynon autopilot I installed in my build performs beautifully. 1
Lyndon Posted October 3, 2024 Author Posted October 3, 2024 I've ordered the kit with roll and pitch only. We are talking 12 months away before I have to fit servos. A lot can change but Dynon at this stage. I believe I can always fit the yaw servo afterwards if needed. Maybe just pre wire it in the fuselage. Thanks Lyndon 1 1
Moneybox Posted October 4, 2024 Posted October 4, 2024 What about Trim Tab autopilots is that a viable option?
facthunter Posted October 4, 2024 Posted October 4, 2024 Most small planes only have adjustable trim on Pitch. Nev
Thruster88 Posted October 4, 2024 Posted October 4, 2024 4 hours ago, Moneybox said: What about Trim Tab autopilots is that a viable option? I have a friend that has installed an iLevel auto pilot. He is happy with its performance. 2 axis, very small and light trim tabs, very easy install.
Moneybox Posted October 4, 2024 Posted October 4, 2024 2 hours ago, Thruster88 said: I have a friend that has installed an iLevel auto pilot. He is happy with its performance. 2 axis, very small and light trim tabs, very easy install. I would like to fit them but I think I'd better wait until it's registered. Hopefully I can add it later after I've got over the first obstacle. Every flight from Cue will be quite a long way to somewhere so autopilot will make it easier to travel the distance. 1
rgmwa Posted October 4, 2024 Posted October 4, 2024 An autopilot is great for long trips, however as the turbulence gets worse the autopilot wants to fight the plane by trying to hold altitude and heading, so you are often better off hand flying if it gets rough. Hand flying long distances is tiring though. 2 1
facthunter Posted October 4, 2024 Posted October 4, 2024 In turbulence you will more than likely need to hand fly the plane. Fitment of an autopilot is not without risks.. If you are not alone someone can take over at times 1
