BillLipson Posted September 27, 2024 Posted September 27, 2024 Can anyone advise where I can get my Transponder tested/calibrated in line with the biennial testing requirement. I am based at Gympie.
Thruster88 Posted September 27, 2024 Posted September 27, 2024 Go to your local LAME, (gympie aircraft maintenance)? Usually an avionics LAME will come to such places every few months to do a number of aircraft so travelling expenses are shared.
skippydiesel Posted September 27, 2024 Posted September 27, 2024 BillLipson, Maaat! If you were in NSW I could help . I suggest ; You contact your local flying clubs. Google radio/transponder services in Qld
rodgerc Posted September 27, 2024 Posted September 27, 2024 Scott Burgess at YCAB does mine biennially.
KRviator Posted September 27, 2024 Posted September 27, 2024 18 hours ago, skippydiesel said: BillLipson, Maaat! If you were in NSW I could help . I suggest ; You contact your local flying clubs. Google radio/transponder services in Qld Who do you use, @skippydiesel? Need to get the RV done.
skippydiesel Posted September 27, 2024 Posted September 27, 2024 There was a service at Mudgee (Airborne Avionics) -no longer BUT they will refer you to their past employee/ technician, who has gone out on his own. Last service (befor aircraft out of test flying) provided by Pacific Avionics , Bankstown - pricy but did the job.
Freizeitpilot Posted September 27, 2024 Posted September 27, 2024 You can try these guys if you need. They can do a 100.5. https://www.dlavionics.com/
KRviator Posted September 27, 2024 Posted September 27, 2024 1 hour ago, skippydiesel said: There was a service at Mudgee (Airborne Avionics) -no longer BUT they will refer you to their past employee/ technician, who has gone out on his own. Last service (befor aircraft out of test flying) provided by Pacific Avionics , Bankstown - pricy but did the job. Thanks Skip, have it in my mind a mate out at Narromine used the Mudgee folks for his test a couple years ago, I'll give 'em a call.
409tonner Posted September 28, 2024 Posted September 28, 2024 Jetfix avionics in Toowoomba done mine last year . I flew down from Roma in the morning and I was home at 1 pm about $300 then .
Garfly Posted September 28, 2024 Posted September 28, 2024 BTW, this video gives some insight into what's involved in such testing - at least in the US. https://www.youtube.com/watch?v=tj5F1FFPYb8&t=781s At 24 mins it's longer than it needs to be but for peeps with enough interest, it might be worth the slog.
Red Posted September 29, 2024 Posted September 29, 2024 (edited) I checked the calibration on mine once using a syringe tee'd into the static line, Iirc 5000' was the highest altitude I could replicate the vacumn force needed to even simulate this mediocre altitude was quite an effort. actually that raises a question....what material are thestatic lines when they enter the pressurised section of an airliner, they must be rather stoutly engineered so as not to collapse with the pressure differential, thick walled stainless tubing I guess or something similar Actually now I think about it in this day and age they are probably electronic pressure sensors outside the pressure shell with just wires to feed the instruments coming inside...but they couldnt do that in the olden day of first generation jetliners Edited September 29, 2024 by Red 1 1
onetrack Posted September 30, 2024 Posted September 30, 2024 Red, there's a somewhat surprising range of materials used in pitot-static lines, and I wouldn't be sure that purely electric/electronic arrangements are used in modern pressurised airliners, there would have to be physical line connections as part of fail-safe systems. Pitot-Static Systems WWW.AVIATIONPROS.COM Pitot-Static Systems Basic for flight By Jim Sparks March 2000 Air is one of the basics needed to support life. In fact for most of us, it is also the basis for our profession...
RFguy Posted September 30, 2024 Posted September 30, 2024 (edited) it takes a bit of time to do because the altitude encoder needs to be walked at a reasonable rate (500 fpm) up AND down from peak altitude, and corresponding transmitter pressure altitude needs to be checked off. Most seem to use a a climbing 9declining pressure) rate and just watch the dials on the transponder and the instrument pressure generator. output of the encoder is 100 ft steps. +/-50' / 125' error, Per CAO100.5, section 14, refers to Appendix F of FAR part 43 eCFR :: 14 CFR Part 43 -- Maintenance, Preventive Maintenance, Rebuilding, and Alteration (FAR Part 43) More advanced gear reads the PA from the decoded, transmitted waveform, and checks for waveform fideltity, timing , which these days will be working, or not. The two techs I have see use a little buggery box that generates a ping to the transponder next to the aircraft (a few microwatts) and lists for the return and displays it. for those interested in the other instrument requirements - how to check : and has requirements, tolerable errors etc , subpart E eCFR :: Appendix E to Part 43, Title 14 -- Altimeter System Test and Inspection (Appendix E to Part 43, FAR) Edited September 30, 2024 by RFguy 1
Red Posted September 30, 2024 Posted September 30, 2024 6 hours ago, onetrack said: Red, there's a somewhat surprising range of materials used in pitot-static lines, and I wouldn't be sure that purely electric/electronic arrangements are used in modern pressurised airliners, there would have to be physical line connections as part of fail-safe systems. Pitot-Static Systems WWW.AVIATIONPROS.COM Pitot-Static Systems Basic for flight By Jim Sparks March 2000 Air is one of the basics needed to support life. In fact for most of us, it is also the basis for our profession... Physical tubes are no more failsafe than cables. I think you mean there needs to be redundancy. There has to be a pressure tube to the sensor of course but I'm not convinced that any of the current glass cockpit setups use anything other than electronic pressure sensors that wouldn't need to have the sense tube enter the pressurised cockpit or display itself. The efis in my microlight does have the sensor in the panel but that's non pressurised cockpit of course. I honestly don't know though, just rambling 1
Red Posted September 30, 2024 Posted September 30, 2024 (edited) Found this explanation, the presure sensors go to an ADC then from there its an electrical signal to the flight displays, so no need for pitot/static lines inside the pressure hull. I think any backup instruments are also fully electronic these days Oh hold on....further reading indicates the avionics bay that the ADC resides in actually pressurised so that throws out my theory of not needing really strong pressure lines from the static at some point inside the Pressure hull ...doh Anyway Ill stop my rambling nonsense now as it has no relevance to our systems and Im just blurting out stuff as I learn it (shouldnt go posting before my second morning coffee) Edited September 30, 2024 by Red 1 1
