danny_galaga Posted February 10, 2024 Posted February 10, 2024 I have this tacho in my plane. Rotax 912 specific.  http://www.aviasport.com/Pagina_348.aspx  I must have run it close to an hour by now on the ground. The hour meter is supposed to measure time when the engine is over 1800 rpm. Because I haven't fine tuned the throttle assemblies yet most of the time it's never below 1800 rpm. But it seems to have stopped at 00:22. (I just realised that's in minutes, not 1/10 hours) . The tacho seems to read rpm reliably.  Anyone have one of these tachos? Am I having a brain fart and not doing something correctly? I didn't think there was anything to do 🤔
Blueadventures Posted February 10, 2024 Posted February 10, 2024 8 hours ago, danny_galaga said: I have this tacho in my plane. Rotax 912 specific.  http://www.aviasport.com/Pagina_348.aspx  I must have run it close to an hour by now on the ground. The hour meter is supposed to measure time when the engine is over 1800 rpm. Because I haven't fine tuned the throttle assemblies yet most of the time it's never below 1800 rpm. But it seems to have stopped at 00:22. (I just realised that's in minutes, not 1/10 hours) . The tacho seems to read rpm reliably.  Anyone have one of these tachos? Am I having a brain fart and not doing something correctly? I didn't think there was anything to do 🤔 I would email the company.  From what you say your getting pulse from engine with rpm showing.  I would also verify 12 volts to the + post. I had an issue with a gauge and most helpful with trouble shooting and then a replacement arranged with floods.  Roberto was the owner at the time 7 years ago.  110% product backup. 1 1
skippydiesel Posted February 10, 2024 Posted February 10, 2024 As always, with 12V systems - Check your (-) earth/ground connections are clean & secure/firm 1
sfGnome Posted February 11, 2024 Posted February 11, 2024 Look on the bright side. You’ll never have to bother with your 100 hourly inspections… 😛 3
facthunter Posted February 11, 2024 Posted February 11, 2024 Unfortunately it doesn't work that way. You could use fuel used, but check on that. Faking required records doesn't go down well. Nev 1
danny_galaga Posted February 11, 2024 Author Posted February 11, 2024 5 hours ago, facthunter said: Unfortunately it doesn't work that way. You could use fuel used, but check on that. Faking required records doesn't go down well. Nev I SUSPECT sfGnome was joking... 1
danny_galaga Posted February 11, 2024 Author Posted February 11, 2024 8 hours ago, skippydiesel said: As always, with 12V systems - Check your (-) earth/ground connections are clean & secure/firm Tacho is working, so earth is fine. I have a feeling there is some sort of fault internally, but thought I'd check here in case someone knew something I didn't about it's operation. I will contact the manufacturer, hopefully they come to the party. That's a problem with builds isn't it? By the time you get to test stuff, most of the stuff is out of warranty 😄 1
facthunter Posted February 11, 2024 Posted February 11, 2024 I do too. but everybody reads this stuff. Aren't they called a Hobbs meter?. I suspect that they are abit like some mechanical speedos with some skinny little gears involved.? Nev
danny_galaga Posted February 11, 2024 Author Posted February 11, 2024 (edited) 59 minutes ago, facthunter said: I do too. but everybody reads this stuff. Aren't they called a Hobbs meter?. I suspect that they are abit like some mechanical speedos with some skinny little gears involved.? Nev No, this one is digital. The tacho has an analog face (but no doubt converting a digital signal, same as my altimeter) and a little LCD readout at the bottom. When the engine is running it just shows the RPM in digital form as well as the analog face. But if the engine isn't running, it shows as an hour meter.  If I'm stuck with this tacho (as in can't get it replaced under warranty) I will get a little standalone Hobbs or BDO hour meter. Edited February 11, 2024 by danny_galaga
cscotthendry Posted February 16, 2024 Posted February 16, 2024 Just had a look at the doc you posted the link to. It says that when the engine is running over 1800 RPM, the readout shows RPM. It shows the time in Hrs minutes and seconds when less than 1800 RPM. What does the display look like when the unit is powered but the engine isn't running? From the picture, it looked like the display only has 4 digits. I don't see how that can display H, M, S unless it scrolls somehow. Also there has been an issue with Avia Sport tachos on Rotax engines. There is a thread about it on these forums. I had an issue with erratic readings which I solved with a resistor between the signal and ground pins at the gauge connections. 1
skippydiesel Posted February 17, 2024 Posted February 17, 2024 On 11/02/2024 at 7:19 PM, danny_galaga said: Tacho is working, so earth is fine. .................................. This could be faulty logic. Â Partial/intermittent earth return, can effects 12 V systems in a wide variety of ways. Sometimes one system will show normal function, while another is completely dead. The clever electronically savvy, folk on this Forum, will I have no doubt have an explanation. Â 1
danny_galaga Posted February 17, 2024 Author Posted February 17, 2024 12 hours ago, skippydiesel said: This could be faulty logic.  Partial/intermittent earth return, can effects 12 V systems in a wide variety of ways. Sometimes one system will show normal function, while another is completely dead. The clever electronically savvy, folk on this Forum, will I have no doubt have an explanation.  The hour meter is built in to the tacho. The tacho is working fine, thus the earth is fine. Perfectly logical 🙂  On top of that, when the revs are above 1800, the hour meter switches to revs. It does this faultlessly.  I have a reply from aviasport. I'll see where we go from there, but I just bought an $8 hour meter from eBay as recommended by a friend. He fits them to all motorbikes he's owned. The oldest hour meter is 6 years now and still fine. 1
facthunter Posted February 18, 2024 Posted February 18, 2024 Even Ride on lawnmowers have them these days. Nev 1
danny_galaga Posted March 4, 2024 Author Posted March 4, 2024 Inside the plane, on the firewall.  Rotate your screen 90° anti - clockwise for correct view 🤪
