red750 Posted 1 hour ago Author Posted 1 hour ago The Dassault Mirage G, also known as the Mirage IIIG, is a variant of the French Dassault Mirage series of supersonic warplanes, but with a variable-sweep wing. Three prototypes were flown; one single-engined G and two twin-engined G8 examples (which had begun construction as the G4). Various roles, equipment fits and other variants were proposed, but none entered production., 1
red750 Posted 1 hour ago Author Posted 1 hour ago 41 minutes ago, facthunter said: In regard to the Landing air cushion, Is THAT Successful? I can't see how you'd stop or steer it in a x wind. Nev Apparently not. Only one research model converted.
skippydiesel Posted 1 hour ago Posted 1 hour ago 6 minutes ago, red750 said: Apparently not. Only one research model converted. I imagine it would have similar handling characteristics to landing on water. You would always land/TO into wind. Stopping may involve reverse thrust and /or reducing the aircushion height to increase drag/friction with the ground. While the idea does not seem to have found favour, I can see how it may be helpful for freight landings/TO on unconsolidated (soft) surfaces😈. The extra weight of the inflation system, would likly reduce payload considerably.😈
facthunter Posted 1 hour ago Posted 1 hour ago A float Plane has a Keel. On land you can't always land into wind and stopping would be very chancy from Normal touchdown speeds. Reverse thrust is Most effective early . Nev
