The Cunningham-Hall GA-21 was an American two-seat monoplane design to compete for the Guggenheim Safe Aircraft Competition in 1934. Its distinguishing feature was full span flaps which could be manually or automatically adjusted. The GA-36 was a military version of it with tandem, rather than side-by-side seating.
The GA-21M was all metal aircraft apart from the fabric covering of parts of the wing, otherwise metal-covered, and the control surfaces. The low-set wings were rectangular in plan out to rounded tips and had a high lift section. Both flaps and ailerons filled the whole straight part of the trailing edge, so the latter only opened upwards.
Apart from its unusual flaps and lateral control the GA-21M was conventional. Powered by a 145 hp (108 kW), seven cylinder Warner Super Scarab radial engine, it had a round-sectioned, metal-skinned, monocoque fuselage. An open cockpit over the forward wing seated two side-by-side. The tailplane was mounted just above the fuselage on the fin and could be trimmed; essentially triangular in plan, it carried rounded elevators. A rounded rudder reached down to the keel.
The GA-21Ms had conventional, tailwheel landing gear with the landing wheels ahead of the leading edge within aircraft fairings that also enclosed the legs.
The GA-36 was a 1936 military trainer rebuild of the Ga-21M. This included a revised, tandem cockpit and more trouser-like landing gear fairings, making it 15% heavier.
The automated flaps worked well but were more complicated than, for example, Fowler flaps and more expensive to construct. Simpler systems were preferred and the sole GA-21M/36 was sold in 1941, stripped of major components and dumped until the 1980s when it was recovered, fully restored and put on display at the Niagara Aerospace Museum.
GA-21M
GA-36
The Martin XB-51 was an American trijet ground-attack aircraft. It was designed in 1945 and made its maiden flight in 1949. It was originally designed as a bomber for the United States Army Air Forces under specification V-8237-1 and was designated XA-45. The "A" ground-attack classification was eliminated the next year, and the XB-51 designation was assigned instead. The requirement was for low-level bombing and close support. The XB-51 lost out in evaluation to the English Electric Canberra which — built by Martin — entered service as the Martin B-57 Canberra.
This unorthodox design, first flying on 28 October 1949, was fitted with three General Electric J47 engines - an unusual number for a combat aircraft - two underneath the forward fuselage in pods, and one at the extreme tail with the intake at the base of the tailfin. The innovative, variable incidence wings, swept at 35° and with 6° anhedral, were equipped with leading edge slats and full-width flaps. Spoilers gave most of the roll control and undersized ailerons provided feel for the pilot. The combination of variable incidence and slotted flaps gave a shorter takeoff run. Four 954 lb (4.24 kN) thrust Rocket-Assisted Take Off (RATO) bottles with a 14-second burn duration could be fitted to the rear fuselage to improve takeoff performance. Spectacular launches were a feature of later test flights.
The main landing gear consisted of dual wheel sets in tandem in the fuselage, similar to the Boeing B-47 Stratojet, with outrigger wheels at the wingtips (originally proved on a modified Martin B-26 Marauder named "Middle River Stump Jumper"). The XB-51 was a large but aerodynamically "clean" design which incorporated nearly all major systems internally. The aircraft was fitted with a rotating bomb bay, a Martin trademark; bombs could also be carried externally up to a maximum load of 10,400 lb (4,700 kg), although the specified basic mission required only a 4,000 lb (1,814 kg) bombload. Eight 20 mm cannon mounted in the nose would have been installed in production aircraft.
Crew was a pilot under a "fighter"-type bubble canopy and a Short-range navigation and bombing system (SHORAN) operator/navigator in a compartment located lower than and to the rear of the cockpit (only a small observation window was provided). Both crew members were provided with a pressurized, air conditioned environment, equipped with upward-firing ejection seats. The XB-51 was the first Martin aircraft equipped with ejection seats, these being of their own design.Number built - 2.
The Epic Victory was the second experimental jet designed by Epic Aircraft, a company that was based in Bend, Oregon. Epic Aircraft declared bankruptcy in 2009. Its assets were acquired by Aviation Industry Corporation of China and LT Builders Group; which as of July 2010 were in the process of restarting production of the Victory.
The Victory is a single-engine very light jet that was intended to be powered by a single Pratt & Whitney Canada PW600. Epic used the Williams FJ33 engine for testing but planned to switch to the PW600 for final production.
The aircraft seats 4 to 5, including the pilots, in a 2+2 or a 2+1+2 configuration. The aircraft took Epic six and a half months to design from concept to a flying prototype, with the first flight on 6 July 2007 from Roberts Field in Redmond, Oregon.
The company had intended that the jet would be available for less than US$1 million. The aircraft was displayed at the Experimental Aircraft Association's AirVenture fly-in in 2007 at Oshkosh, Wisconsin, where the company began accepting down payments.
The prototype's Federal Aviation Administration registration expired on 31 May 2017. It has not been renewed and the aircraft has been deregistered.
  • 1 month later...
The Douglas XTB2D Skypirate (also known as the Devastator II) was a torpedo bomber intended for service with the United States Navy's Midway- and Essex-class aircraft carriers; it was too large for earlier decks. Two prototypes were completed, but the dedicated torpedo bomber was becoming an outdated concept, and with the end of World War II, the type was deemed unnecessary and cancelled.
In 1939, Douglas designers Ed Heinemann and Bob Donovan began work on a VTB Proposal to replace the TBD Devastator torpedo bomber. In 1942, the team led by Heinemann and Donovan began work on a new project named the "Devastator II". On 31 October 1943, just four days after the very large Midway-class aircraft carriers were ordered into production, Douglas received a contract for two prototypes, designated TB2D, receiving the official name: "Skypirate".
The TB2D was powered by a Pratt & Whitney R-4360 Wasp Major driving contra-rotating propellers. Four torpedoes (such as the Mark 13 torpedo) or an equivalent bomb load could be carried on underwing pylons. Defensive armament consisted of two 20 mm (.79 in) cannon in the wings and .50 in (12.7 mm) machine guns mounted in a power-operated dorsal turret.
Very large for a single-engined aircraft, the TB2D would have been the largest carrierborne aircraft at the time; it could carry four times the weapon load of the Grumman TBF Avenger. With only limited support from the US Navy, and facing a recommendation for cancellation on 20 May 1944 due to the aircraft being designed only for the CVB carriers, the TB2D project was in peril even at the design and mockup stage.
  • 2 weeks later...
The Dyle et Bacalan DB-70 was a large three engine French airliner with a thick airfoil centre section which accommodated the passengers. Two fuselages, part of the centre section at the front but distinct further aft, carried the empennage. First flown in 1929, only one was built.
In 1925 the large naval ship builders Société Anonyme de Travaux Dyle et Bacalan, established in 1879 and based in Bordeaux, developed an aircraft manufacturing interest. They built several all-metal prototypes incorporating very thick wings. The DB-70 was the largest of these and the last to carry the company name: Dyle et Bacalan ceased trading in July 1929, before the DB-70 had flown, though the company reformed as Société Aérienne Bordelaise (SAB) that same month. As a result, the aircraft is sometimes referred to as the SAB DB-70; the letter prefix DB was retained, though aircraft designed later by SAB used the AB- form .
The DB-70 was a very large, all metal aircraft built, like all Dyle et Bacalan aircraft, largely of duralumin. As on the 1926 DB-10, the centre section of the wing of the DB-70 was extremely thick and twice the chord of the outer wings, with a chord/thickness ratio of about 25%. The layout of the two designs was different, though; the otherwise conventionally laid-out DB-10 had thick wings inboard of its two engines, whereas the DB-70 was built around its thick centre section with twin fuselages, developed from it rearwards, carrying the empennage. The centre section also mounted the three 450 kW (600 hp) Hispano-Suiza water-cooled inline engines and the pilots' cockpit and enclosed the passenger accommodation.
More details here.
The Hanriot H.110 was an unusual pusher configuration, twin boom, single seat fighter aircraft built in France in the early 1930s. It proved to be slower and less manoeuvrable than its contemporaries and failed to reach production, even as the Hanriot H.115 after receiving a more powerful engine and cannon armament.
From 1916 until 1933, the only Hanriot fighter aircraft had been tractor biplanes. The Hanriot H.110, a twin boom pusher cantilever monoplane was therefore a considerable departure from the past. It was designed to compete in the STAé (Service Technique de l'Aéronautique or Technical Section of Aeronautics) 1930/31 C1 (single seat Chasseur of fighter) programme.
The all-metal H.110 had an open cockpit and engine in a short central nacelle. It was powered by a 485 kW (650 hp) Hispano-Suiza 12Xbrs supercharged upright water-cooled V-12 engine behind the pilot, driving a three-blade pusher propeller. The pilot's headrest was smoothly faired into the engine cowling. There was a circular Chausson radiator in the short nose ahead of the open cockpit, with a variable position central cone to control the airflow.
The wings were built around two spars. The central 25% of their span, between the booms, had constant chord. Immediately outboard they had a wider chord and beyond were double straight tapered to rounded tips. They carried almost full-span, narrow-chord Frise ailerons. Forward, the slim, square section and untapered tail booms blended into the wings at about mid-chord, the aft ends carrying a constant-chord tailplane slightly above them. This had rounded tips and a central elevator with a trim tab. A central, single, tall, round-tipped, wire-braced vertical tail was mounted on in it. The H.110 had a fixed, split, conventional undercarriage with each spatted mainwheel on a faired, near vertical shock absorber and a rearward leaning strut together forming a V, laterally braced with an inverted V-strut attached near the under-fuselage centre line. There was a central tailwheel on a long leg under the fin.
The H.110 began flight testing in April 1933. Tested against its smaller and lighter competitors, it proved slower and less manoeuvrable and was returned to Hanriot for modification. It flew in April 1934 as the H.115, with its HS 12Xbrs engine uprated to 515 kW (691 hp), a new four-blade propeller with variable-pitch and a revised nacelle, shortened forward of the cockpit by 360 mm (14.2 in). A 33 mm (1.30 in) APX cannon was now housed in a fairing below the nacelle as an alternative to the earlier pair of Chatellerault 7.5 mm (0.295 in) machine guns. With its new engine and propeller the H.115 was quicker than the earlier version, with a top speed of 390 km/h (242 mph). After more modifications over the winter of 1934-5 it returned to Villacoublay in June 1935 and was officially flight tested until mid August, but failed to attract a contract.
HanriotH.11002.thumb.jpg.f744c9e670a2e808238711a2271e063f.jpgHanriotH.11003.thumb.jpg.5afe15709f7b3320a2f06a39e4ced45a.jpg
The Hodkinson HT-1 was a U.S., eight place, three-engined sesquiplane, first flown in 1929. Despite an order for five, only one had been completed before Hodkinson Aircraft went bankrupt near the start of the Great Depression. It operated in Guatemala for several years.
Hodkinson Aircraft was founded in 1929 by William Wadsworth Hodkinson, one of the pioneers of the film industry who in 1916 had organized Paramount Pictures. He later went into film distribution, founding the W.W.Hodkinson Co. and then moved into the aviation business. The HT-1 was built by Valley Manufacturing Co. a division of Hodkinson Aircraft based in Glendale, California. Its designer, Don R. Berlin, later designed the Curtiss P-40.
The wings of the HT-1 were both built around spruce spars and had rectangular plans out to rounded tips. The upper wing, with three-quarters of the total wing area, provided most of the lift and mounted narrow chord, Friese ailerons that reached from wingtips to above the outer engines. The short, lower wings were braced to the upper ones with parallel interplane struts between the wing spars.
The HT-1 was powered by three 170 hp (130 kW) Curtiss Challenger radial engines, one in the nose and the others on top of the lower wing, braced by vertical struts to the upper spars. Behind the central engine the fuselage was flat sided, with the wing centre-section fixed to it by inverted V cabane struts faired into the fuselage's chrome-molybdenum tube structure. These provided a clear rear view from the pilots' cabin under the leading edge of the wing. Pilot and co-pilot sat side-by-side with dual controls, though the co-pilot's controls could be removed to allow an extra passenger to be carried. Their cabin was normally accessed through doors on either side but there was also a door in the rear which led down to the passengers' windowed, six seat cabin. There was a toilet at the back and also a baggage compartment, though this was only accessible from outside. Cabin access was via doors on either side, opening just ahead of the rear seats.
Its tail was conventional, The fixed surfaces, like the fuselage, had chrome-molybdenum tube structures and the tailplane was mounted on top of the fuselage. The fin was braced to the tailplane and had a cropped, roughly triangular profile. The balanced rudder had a blunted rectangular profile.
HodkinsonHT-101.thumb.jpg.3ccb7d452001f4d21fac602a04605287.jpgHodkinsonHT-102.thumb.jpg.a93b7bd58097c0de3d0e702a8ed3b1e2.jpg
The Kennedy Giant was a British biplane heavy bomber designed by Kennedy Aeroplanes Ltd. during the First World War. The design was an imitation of works by Igor Sikorsky, with whom the owner of Kennedy Aeroplanes Ltd., C. J. H. Mackenzie-Kennedy, had ostensibly worked prior to setting up the company. The aeroplane was a notorious failure; its size meant that construction had to take place in an open field as none of the hangars near Hayes, Middlesex, where the prototype was assembled, were large enough to house it. For its weight, the aircraft's four engines were inadequate, and the resulting under-powered aircraft could only fly in a straight line once airborne.
Following the unimpressive test flight, the design was cancelled and the prototype was left derelict at Northolt Aerodrome for a number of years.
The Kinney HRH (Hot Rod Helicopter) is an American helicopter that was designed by Robert Kinney and produced by Vortech, Inc in the form of plans for amateur construction. The aircraft was first shown at Sun 'n Fun in 2002.
The HRH was designed to comply with the US experimental – amateur-built rules. It features a single main rotor, a single-seat enclosed cockpit with a windshield, skid-type landing gear and a four-cylinder, air-cooled, four-stroke, 165 hp (123 kW) Subaru EJ25 automotive engine. It is the high power to weight ratio that gives the aircraft its name.
The aircraft fuselage is made from a mix of welded 4130 steel tube and bolted-together aluminum tubing, with a composite cabin shell. Its 25 ft (7.6 m) diameter two-bladed Waitman composite rotor has a chord of 8 in (20 cm). The tail rotor has a 46 in (117 cm) diameter. The aircraft has an empty weight of 1,000 lb (454 kg) and a gross weight of 1,350 lb (612 kg), giving a useful load of 350 lb (159 kg). With full fuel of 18.5 U.S. gallons (70 L; 15.4 imp gal) the payload is 239 kg (527 lb). The HRH can hover in ground effect at 7,000 ft (2,134 m) and out of ground effect at 5,000 ft (1,524 m).
By January 2013 there was one example, the 2001 prototype, registered in the United States with the Federal Aviation Administration.
KinneyHRH02.thumb.jpg.03a693bc89534eadce26f6447ed398bf.jpgKinneyHRH01.thumb.jpg.f09ca0c659274638b44e5f7c5f14e646.jpg
The Johns Ra-Son Warrior or X-3 Warrior is a low wing bushplane with a large short coupled tail surface.
The aircraft has a large tapered low wing, with a large horizontal tail surface mounted close to the trailing edge of the wing and conventional tailwheel landing gear. The fuselage has welded steel tube construction with fabric covering. The wings have fabric-covered wooden ribs and spars. A 1,000 lb (454 kg) payload can be lifted by the 185 hp (138 kW) engine. The five-seat cabin can be converted for cargo operations, and two oversized gullwing cabin doors allow loading.
The prototype was built over a four-year period. The aircraft received the Experimental Aircraft Association award for achievement in 1963.
The 1958 Lanier Paraplane Commuter 110 or 110 Paraplane Commuter PL-8 was one of the last designs stemming from Edward H. Lanier's 1930s patents, and aircraft incorporating apertures in the upper surfaces, which claimed to give benefits in safety, lift and STOL ability.
In the early 1930s Edward H. Lanier published six US patents concerned with increased aircraft lift and stability, minimising the stall, sideslip and spin. This was to be achieved through vacuum chamber ("Vacua-cells"), initially in the upper fuselage but later in the upper wing, where the reduced pressure established by airflow over a curved surface would act on the lower surface inside the cell, providing lift. The second patent suggests that the cell should contain angled spanwise slats to prevent air entering them at low speeds and that these should be adjustable so that the cells could be closed when required. The earlier patents stress stability improvements; claims of enhanced lift begin with the fourth patent. Five Lanier Vacuaplanes were built in the 1930s, followed by three Paraplanes from about 1948, before the Paraplane Commuter 110 which first flew in 1958.
The Commuter 110 had a wing area of 111 sq ft (10.3 m²), large for its 20 ft 7 in (6.28 m) span, and controllable air entrance slots ("Vacua-Jets") under the lower surface near its leading edge, passing air to the upper surface for boundary layer control. Other details of the upper surface are scarce but photographs appear to show rear hinged, single-piece slats over Vacua-cells as well as narrow open channels next to the fuselage in the very long wing root fairings. Structurally, the cantilever mid wing had strongly cranked inner sections and was tapered in plan with elliptical wing tips. The outer panels carried control surfaces which operated differentially as ailerons and together as flaps. In addition there were split flaps under the trailing edges of the wing roots.
More details here.
LanierParaplaneCommuter11001.thumb.jpg.8e5d5d6dbc8decc906095a84072467b3.jpgLanierParaplaneCommuter11002.thumb.jpg.d40fd22e5c820b9afed1b8f5a7043dc1.jpg
The Lambert Mission 212 is a conventionally laid out low-wing, fixed undercarriage, single-engine, four-seat kit built aircraft designed in the UK by a Belgian college student. Kits are manufactured in Belgium.
The M212 has had an unusually long gestation time. It was designed in 1992 by Filip Lambert, then a student at the College of Aeronautics, Cranfield, and was selected as one of three winners of the Royal Aeronautical Society Light Aircraft Competition in 1995. Construction of the M212-100 prototype began in 1996. This aircraft was registered in the UK in 2000 and was displayed, complete apart from some engine and fuel supply systems, at the Popular Flying Association (PFA) Rally held at Cranfield in June 2002. The first flight, delayed by another two years, took place on 13 April 2004 at Cranfield with Roger Bailey as pilot.
The M212 is an all-composite aircraft with 95% of its weight in pre-pregs. The wing has two main spars plus an auxiliary one, all formed from glass and carbon fibre in epoxy resin. In plan the wing is gently straight tapered, with most sweep on the trailing edge and with turned up wingtips. It has 5° of dihedral and 2° of washout. Electrically actuated single slot flaps are fitted. Fin and rudder are swept, with a small dorsal fin; the rudder is horn-balanced. The tailplane is rectangular and set a little above the fuselage, carrying inset elevators.
The fuselage is a monocoque construction, tapering strongly to the rear. The cockpit seats four in two rows with dual controls in front, covered by a forward-hinged, single-piece canopy. There are two side windows for the rear seat passengers. The M212 has a fixed tricycle undercarriage, the mainwheels mounted on forward-leaning cantilever legs in narrow chord fairings, attached to the fuselage. The mainwheels have brakes and the nosewheel is steerable. Only 2 examples were built.
More details here.
LambertMission21201.thumb.jpg.989246aafb811b95bfe27b7957465077.jpgLambertMission21202.thumb.jpg.654776cde7cb07f205ebcec83d9d2557.jpg
The Laron Wizard is an American homebuilt aircraft produced by Laron Aviation Tech of Borger, Texas. When it was available the aircraft was supplied as a kit for amateur construction.
The Wizard features a strut-braced high-wing, a twin-boom tail layout, a two-seats-in-side-by-side configuration enclosed cockpit, fixed tricycle landing gear, with a tail skid, and a single engine in pusher configuration.
The aircraft is made from a combination of bolted-together aluminum tubing and fiberglass, with its flying surfaces covered doped aircraft fabric. Its 30.50 ft (9.3 m) span wing, mounts flaps and has a wing area of 140.0 sq ft (13.01 m²). The wing is supported by a single lift strut and jury strut per side. The acceptable power range is 64 to 80 hp (48 to 60 kW) and the standard engines used are the 64 hp (48 kW) Rotax 582, the 74 hp (55 kW) Rotax 618 or the 65 hp (48 kW) Hirth 2706 two stroke powerplants or the 80 hp (60 kW) Rotax 912UL four stroke engine.
With the Rotax 582 engine the Wizard has a typical empty weight of 462 lb (210 kg) and a gross weight of 925 lb (420 kg), giving a useful load of 463 lb (210 kg). With full fuel of 10 U.S. gallons (38 L; 8.3 imp gal) the payload for pilot, passengers and baggage is 403 lb (183 kg).
The manufacturer estimated the construction time from the supplied kit as 450 hours.
By 1998 the company reported that 240 kits had been sold and 220 aircraft were completed and flying.Despite this, a search of most major aircraft photo sites, including jetphotos.com, airliners.net and airport-data.net. only one example could be found on the Russian site airwar2.ru. The image is shown below-
The O'Neill Model J Magnum, also called the Magnum Jake and the Magnum Pickup, is a homebuilt aircraft design for bush flying operations similar to the de Havilland Beaver.
O'Neill intended to modify the Aristocraft II six-place homebuilt with a 350 hp (261 kW) radial engine. Eventually a clean sheet design was drawn up based on a bush pilot survey in Alaska.
The Magnum is a single-engine, strut-braced, high-wing aircraft with an uncommon dual-main, four-wheel landing gear. The fiberglass gear legs support castoring wheels in the front, allowing for conversion to floats and providing support when the tail section is swung open for cargo loading. The fuselage is constructed from welded steel tubing, with aluminum skin. The engine cowl is sourced from a Cessna UC-78. The wings have full-span flaps, and spoilerons and are designed to fold like those of a Fairchild FB-2C. The fuel tank is mounted under the cockpit and can be released to reduce fire risk during emergency landings.
Post flight-testing modifications resulted in changes to the landing gear layout, spoileron airflow control and engine cooling.
The Magnum was demonstrated at the EAA Airshow in 1984. In 1996, O'Neill folded the O'Neill aircraft company due to low interest and funding for further development. The prototype was sold in 1996 for an intended turboprop conversion.
  • Sad 1
"Hey Jethro, I jest shotgunned outta the sky, the biggest darn skeeter ah ever did see!!! .... and the noise of its buzzin', you could hear a-coming for miles!!! ...."
  • Haha 2
  • 3 weeks later...
The Monsted-Vincent MV-1 Starflight was built in Louisiana. The sole aircraft built first flew on the 1st of October 1948.  Powered by 4 Continental C-85 engines driving pusher-propellers and it could carry up to 6 passengers. The test results did not encourage any potential customers and the aircraft was put in the Wedell-Williams Memorial Aviation Museum in the Patterson, Louisiana.
In 1992, the museum was hit by hurricane Andrew and MV-1 was virtually destroyed. The aircraft was relocated to a storage hanger and in 2005 the hanger along with the aircraft was leveled by hurricane Rita.
The museum moved to a new location in Patterson.
  • Sad 1
  • 3 weeks later...
The Tupolev Tu-91 (NATO reporting name Boot) was a two-seat Soviet attack aircraft built during the 1950s. It was initially designed as a carrier-borne aircraft, but was converted into a land-based aircraft after Joseph Stalin's death in 1953 cancelled the aircraft carriers being designed. Two prototypes had been built and production had been approved by the Soviet Navy when it was inspected by the General Secretary, Nikita Khrushchev, in 1956. He remarked how ridiculous the Tu-91 looked and the program was cancelled.
Kuznetsov had ordered preliminary design work to begin on the Project 85 light aircraft carrier and the aircraft for the ship before Stalin's death, although the ship was never more than a paper design. This allowed the Tupolev Design bureau to decide upon on a single-engined turboprop aircraft to meet Soviet Naval Aviation's requirement for a long-range strike aircraft, capable of attacking targets with bombs or torpedoes. The new leaders of the Soviet Union rejected proposals for carriers and the Council of Ministers issued a requirement for a land-based bomber powered by a Kuznetsov TV-2 turboprop engine that was capable of level and dive bombing attacks on targets with bombs, torpedoes, rockets, gunfire and naval mines, in addition to coastal reconnaissance missions, on 29 April 1953. This forced the bureau to revise the design to eliminate the wing-folding mechanism, arresting gear and other carrier-specific equipment for the second prototype.
The Tu-91 first flew on 17 May 1955, when the manufacturer's flight testing began. They concluded successfully about September with the test pilots concluding that the aircraft was highly manoeuverable, although barrel rolls should be forbidden. The aircraft also passed the subsequent state testing and the design bureau began preparing for production at Factory No. 31, in Tbilisi, Georgia. The Tu-91 was part of a display of the latest military aircraft for the Soviet leadership in mid-1956, one of the very few propeller-driven aircraft present. When the newly elected Khrushchev inquired about the aircraft, the officer detailed to the aircraft misspoke, stating that it could do the job of a heavy cruiser rather than it had the firepower of that ship. Khrushchev replied, "But nobody needs heavy cruisers any more", and commented how ridiculous it looked. This off-hand comment caused the program to be cancelled. Only 2 had been built.
Video here.
  • 3 months later...
The SNCASE SE-700 was a three-seat passenger autogyro designed during World War II. Two were completed but only the first flew and the programme was soon abandoned.
Design of the SE-700 began in 1939 but World War II delayed its completion and first flight until 25 May 1945. Compared with most autogyros of its time it had a very advanced appearance, with a sleek, streamlined fuselage, an enclosed central engine and a three blade rotor on a straight edged, aerofoil section pylon. The enclosed cabin, which seated three, was ahead of the engine and behind a nose which tapered smoothly into the spinner of the two blade propeller.
At the rear of the short fuselage was a low aspect ratio tailplane, externally braced to the fuselage underside and fitted with elevators. It carried swept, oval tail fins taken from the SNCASE SE-100 twin engine fighter at its tips, which were externally braced to the tailplane underside. The fins were fitted with rudders and, more unusually, wheels; the SE.100 had fin mounted tail wheels but the SE.700 had tricycle gear so these became the main wheels, tidily faired into the bottom of the fins. Its nosewheel retracted backwards, placing the wheel partly in the fuselage and its leg within a small ventral fairing.
The first prototype, piloted by Stakenburg, flew with a 164 kW (220 hp) Renault 6Q-01 six cylinder, inverted air-cooled inline engine. It proved difficult to control and crashed after a few test flights. Though the damage was not great, the SE-700 was not repaired and SNCASE decided instead to complete a more refined second prototype, the SE-701 or SE-700A. This was fitted with a more powerful 246 kW (330 hp) Béarn 6D-07 engine, another six cylinder, inverted air-cooled inline. However, the company then decided that the post-war market for small commuter autogyros was too limited to proceed, so the SE-700A did not fly and a proposed production series of four SE-702s or 700Bs were not begun.
snias_se700.thumb.jpg.0c01cc8bd8819ca73e8790482f584b2d.jpgsncasese-70002.thumb.jpg.7d14936c9dbda1f1f0cacdb441e4ffdc.jpg
The Hawker Siddeley HS.141 was a 1970s design study and submission for a British V/STOL airliner requirement. Designed by Hawker Siddeley Aviation and tested in wind tunnels neither prototypes nor production aircraft were produced.
In 1969 the British Transport Aircraft Requirements Committee (TARC) issued a design study "Outline Requirement" (OR) for a 100-seat VTOL airliner capable of a range of 450 miles (725 km). Emphasis was to be on noise reduction by using steep approach and departure profiles, much like those used today at London City Airport. It was thought at the time that money would be better invested on designing new aircraft types than building a third London airport.
Hawker Siddeley investigated various configurations of aircraft, powerplant and control systems including an early proposal using ogival delta wings and twin fins, before submitting their draft design proposal to the TARC in January 1970. At the March 1970 German Aviation Show in Hanover, the first official details were released of the newly named HS.141 project.
The HS.141 design was a jet airliner of all-metal construction with a T-tail and a low-mounted swept wing with a quarter-chord sweepback of 28 degrees. The design featured two wing-mounted "cruise" engines and 16 lift jet engines mounted in sponsons either side of the fuselage (eight per side). The engines under main consideration were the Rolls-Royce RB.220 turbofan for forward propulsion and the Rolls-Royce RB.202, a high bypass ratio lift turbofan engine using technology developed for the Rolls-Royce RB.162 lift jet. Both engines were themselves design studies by Rolls-Royce and it was feared that there would be delays in their development due to the company's problems at the time. One new engine type also considered for main propulsion was the 'SNECMA M.56', which became the CFM International CFM56. Variations using fewer lift jet engines for STOL operations only were also studied as it was realised that the engines could account for 15% of the total weight of the aircraft and 35% of the final cost.
During the design stage many solutions involving high-lift devices were explored including flaps blown by the "cruise" engines. The flight control system proved the greatest challenge to the design team, systems had to be devised to control the aircraft in slow or hovering flight. This was to be achieved by swivelling the lift engines in their mounts combined with varying the thrust of each engine to provide control in pitch, roll and yaw. The lift engines were said to be a useful safety feature in the event of failure of the main 'cruise' engines. Significant design information was gained from flight trials with the Dornier Do 31 aircraft being developed at the same time in Germany.
The passenger cabin was conventional with five or six seats abreast, luggage and freight was to be loaded in pre-packed pallets and raised up into the lower fuselage using a system similar to the Douglas DC-8.
Extensive wind tunnel testing with 1/10 scale models was carried out.
  • 1 month later...
The Hiller X-18 was an experimental cargo transport aircraft designed to be the first testbed for tiltwing and V/STOL (vertical/short takeoff and landing) technology.
Design work started in 1955 by Stanley Hiller Jr and Hiller Aircraft Corporation received a manufacturing contract and funding from the United States Air Force to build the only X-18 built, serialized 57-3078.
To speed up construction and conserve money, the plane was constructed from scavenged parts including a Chase YC-122C Avitruc fuselage, 49-2883,[1] and turboprops from the Lockheed XFV-1 and Convair XFY-1 Pogo experimental fighter programs. The tri-bladed contra-rotating propellers were a giant 16 ft (4.8 m) across. The Westinghouse turbojet engine had its exhaust diverted upwards and downwards at the tail to give the plane pitch control at low speeds. Hiller nicknamed their X-18 the Propelloplane for public relations purposes.
Number built    1
The Lesher Nomad is an innovative two-place homebuilt aircraft.
Designer Edgar J Lesher had previously worked at Stinson Aircraft Company in Wayne, Michigan on the Stinson 106 Skycoach. The Skycoach was a four-place aircraft with a pusher propeller, a configuration which captured Lesher's imagination.
In August 1958, he attended one of the early Experimental Aircraft Association Fly-Ins. The homebuilt aircraft he saw there inspired him to design one himself. Remembering the Skycoach, he began the design of an all-aluminum two-place, side-by-side, pusher propeller aircraft. Construction began in February 1959. In October 1961, after 5,000 hours of construction, he first flew his aircraft, the Lesher Nomad (N1066Z) at Willow Run Airport in Ypsilanti, Michigan. A novel design feature was his use of a Dodge Flexidyne Coupling in the drive train to dampen torsional vibrations. The aircraft was powered by a 100 hp Continental O-200 engine driving a 72-inch Hartzell ground-adjustable propeller.
Lesher flew the Nomad to the 1962 EAA Fly-In in Rockford, Illinois, where the design attracted a lot of interest. In 1964, flying Nomad, he took the grand prize in the AC Spark Plug Rally. The aircraft was regularly flown until Lesher's death in 1998.
The aircraft is on display in the atrium of the Francois-Xavier Bagnoud building at the University of Michigan.
Full view
The Martin XB-48 was an American medium jet bomber developed in the mid-1940s. It competed with the Boeing B-47 Stratojet, which proved to be a superior design, and was largely considered as a backup plan in case the B-47 ran into development problems. It never saw production or active duty, and only two prototypes, serial numbers 45-59585 and 45-59586, were built.
In 1944, the U.S. War Department was aware of aviation advances in Germany and issued a requirement for a range of designs for medium bombers weighing from 80,000 pounds (36,000 kg) to more than 200,000 pounds (91,000 kg). Other designs resulting from this competition, sometimes nicknamed "The Class of '45", included the North American XB-45 and the Convair XB-46.
All of the bombers comprising the Class of '45 were transitional aircraft, which combined the power of turbojets with the aeronautical design of World War II, notably the unswept wings and tail surfaces. The XB-48 was no exception, as its round fuselage and unswept wings showed a distinct influence of Martin's B-26 Marauder medium bomber.
At the time of the XB-48's design, jet propulsion was still in its infancy. While the B-26 had enough thrust with two massive 18-cylinder radial engines, the XB-48 needed no less than six of the low-thrust turbojets available at the time. And, although it appeared superficially to have six separate engine nacelles – that is, three under each wing – the XB-48 actually had only two, unusually wide, three-engined nacelles. Each of these large nacelles also contained an intricate set of air ducts that constituted the engines' cooling system.
The XB-48 was the first aircraft designed with bicycle-type tandem landing gear, which had previously been tested on a modified B-26. The wing airfoil was too thin to house conventional landing gear mechanisms. The main landing gear was in the fuselage and small outriggers located on each wing were used to balance the aircraft.
During development, Boeing was using German swept-wing research to develop the dramatically more capable Boeing B-47 Stratojet for the same role. As this outperformed all of the Class of '45, development of the XB-48 continued only as a backup in case the B-47 ran into problems, which did not occur. The only member of the '45 to be put into production was the North American B-45 Tornado, which only served for a few years as a bomber before being replaced by the B-47.
The XB-48 made its first flight on 22 June 1947, a 37-minute, 73 mi (117 km) hop from Martin's Baltimore, Maryland plant to NAS Patuxent River, Maryland, but blew all four tires on its fore-and-aft mounted undercarriage on landing when pilot Pat Tibbs applied heavy pressure to the specially designed, but very slow to respond, insensitive air-braking lever. Tibbs and co-pilot Dutch Gelvin were uninjured.
Full view
The Cornelius Mallard was a single-engined light aircraft of very unusual configuration, tailless and with a swept forward wing of variable incidence. It flew between 1943-4.
The Mallard was the third aircraft type produced by Cornelius Aircraft. The first two, the FreWing and the LW-1 were conventional in layout but unusual in using independently variable incidence wings for pitch and roll control. The wings of the Mallard could also be adjusted in the air, but they were of low aspect ratio with marked forward sweep. The trailing edge carried conventional ailerons near the tips and elevators close to the fuselage. The Mallard was also a tailless aircraft, in the sense of lacking a horizontal tailplane. The rest of the aircraft was conventional, with single fin and rudder and a side-by-side cockpit for two behind a flat four engine. The undercarriage was fixed and of the tailwheel type. Like other Cornelius designs, the sole Mallard was built by the Spartan Aircraft Company.
The Mallard first flew on 18 August 1943, flown by Arthur Reitherman, though some sources suggest that most of the subsequent 18 flights were in the hands of the Romanian aerobatic pilot Alexander Papana. The first public flight was on 7 September 1943. It was reported to have been 700 lb (320 kg) overweight and there were plans to install a more powerful engine. The designer claimed that the Mallard was stall and spin proof, though the later loss of the much larger but similarly configured Cornelius XFG-1 in an irrecoverable spin has cast doubt on this.
