rhtrudder Posted December 9, 2020 Posted December 9, 2020 Fitted up skyecho, all registered, turned on , send young bloke up and raced inside to see him on ozrunways but not to be seen , could see other aircraft, what am I missing
Thruster88 Posted December 9, 2020 Posted December 9, 2020 24 minutes ago, rhtrudder said: Fitted up skyecho, all registered, turned on , send young bloke up and raced inside to see him on ozrunways but not to be seen , could see other aircraft, what am I missing Did you have a SkyEcho connected to your tablet as well? Mine is working well at displaying ADSB traffic (ozrunways android) and presumably they can see me. Given the 20 mile range I am showing on flightradar24 quite alot.
RFguy Posted December 9, 2020 Posted December 9, 2020 (edited) REMEMBER to be seen on flight radar 24, you need to be seen from their base stations ! And there is some varying input- some receivers look at the 978 MHz UAT, others the Mode-S Extended Squitter (1090 MHz), , others -both. Thruster88- I actually want to talk with you about getting a project going to access to some hills around the central west and putting some ADSB receivers on them. solar powered, costs a couple of hundred bucks to establish....can talk tot flight radar24 etc.. Edited December 9, 2020 by RFguy
RFguy Posted December 9, 2020 Posted December 9, 2020 (edited) Range on the skyecho with 20 watts in the sky echo and internal antenna will be only be able 3x less than the theoretical maximum. About - 300-450 km approx. MUST BE RADIO LINE OF SIGHT Recently I have been running some numbers to see where the nearby SSRs to the central west, what height they'll be able to see us. This is for Mode A, Mode C transponders. Mt Bobbara (Young) 3000' Edited December 9, 2020 by RFguy
SplitS Posted December 9, 2020 Posted December 9, 2020 Skyecho is good for about 20nm I have been flying with one for a while. You see other skyechos pop up intermittently at around 25nm and usually steady under 20nm. If they are flying with Ozrunways they go from light to a darker blue ADSB has priority (dark blue) when signal is strong enough. 20 nm won't trigger base stations very often.
RFguy Posted December 9, 2020 Posted December 9, 2020 It is possible it has been intentionally limited. and that either 1) Uavionix does not want to canabalize its higher end products 2) they licensed the tech from someone , with the same caveat as (1) 3) Or, that was the deal with the devil , (regulator) - a limited range. I'll do some research on where ozrunways gets its info from. Many ADSB receivers will actually be Mode S on 1090, not 978 UAT.
SplitS Posted December 9, 2020 Posted December 9, 2020 Ozrunways talks over the mobile network so you can see other Ozrunways traffic if you and them have mobile service. Skyecho is a low power portable ADSB device 20w output is fine and 20nm is more than enough to assist in being seen by other ADSB in traffic. It was never intended to be in competition with the commercial IFR 200w transmitters. CASA has done a great job allowing us to use these cheap low power ADSB's for VFR they add a large safety factor for a low cost expecting it to be the same as the 10k plus systems is not reasonable IMHO. 3 1
RFguy Posted December 9, 2020 Posted December 9, 2020 I agree, SkyEcho it is a great box , especially for being visible to to IFR traffic like Rex in VCY of AD. 1 1
jmal Posted December 10, 2020 Posted December 10, 2020 As with Pilot Aware and Flarm, SkyEcho is predominately a collision avoidance system between aircraft in the air. CAA refer to these devices as conspicuity aids and are currently offering a 50% rebate when purchased. Each operator enters their aircrafts stall speed, and ident hex number. Below that GPS derived stall speed ADSB out ceases and the aircraft will not be seen. Owners of aircraft should not play with them in their car with ADSB out enabled as they will be 'seen' as an aircraft 'flying' along the motorway when driving faster then the stall speed of their aircraft. I did not know that, unlike the US, ATC or radar services in the UK currently do not have ADSB receivers that could receive and ident an ADSB out equipped aircraft. Without a mode C transponder in my aircraft I was hoping ADSB out would allow me to be identified and transit controlled airspace ...but that is not the case.
RFguy Posted December 10, 2020 Posted December 10, 2020 https://www.casa.gov.au/sites/default/files/advisory-circular-91-23-ads-b-enhancing-situational-awareness.pdf
SGM Posted December 10, 2020 Posted December 10, 2020 A shame CASA isn't subsidising SkyEcho. Has anyone had any experience with PingUSB? Obviously it is ADSB-In only so you need to be looking at Avplan/Ozrunways on a tablet to make use of it, and of course you are not 'visible' to other aircraft.
Downunder Posted December 10, 2020 Posted December 10, 2020 1 hour ago, SGM said: A shame CASA isn't subsidising SkyEcho. Has anyone had any experience with PingUSB? Obviously it is ADSB-In only so you need to be looking at Avplan/Ozrunways on a tablet to make use of it, and of course you are not 'visible' to other aircraft. I'm using the ping. Works well. (Already have mode S adsb-out transponder) I can pickup aircraft 100nm away in a straight line. The only issue is that without an external antenna, parts of the aircraft mask reception. As I have it on the front windscreen, everything in front of me is shown but behind me aircraft "come and go" a bit. In reference to the opening question, the ping does pick up my own aircraft..... Overall, I think it does help with situational awareness.
Garfly Posted December 10, 2020 Posted December 10, 2020 (edited) 6 hours ago, jmal said: I did not know that, unlike the US, ATC or radar services in the UK currently do not have ADSB receivers that could receive and ident an ADSB out equipped aircraft. Without a mode C transponder in my aircraft I was hoping ADSB out would allow me to be identified and transit controlled airspace ...but that is not the case. According to CASA's ADVISORY CIRCULAR AC 91-23v1.0 it is the case in Australia that SkyEcho type devices are/will be visible to ATC, within range. "6.3 Integrated TABS device 6.3.1 Aircraft operated to the VFR can use an integrated TABS device. TABS devices were designed primarily for those aircraft in USA that were not required to comply with the FAA's stringent ADS-B requirements but want to be ‘seen’ by ADS-B and TCAS. In Australia, it is expected that these devices will provide a level of visibility to ATC as well, for situational awareness purposes" And based on some earlier discussion we had on this on this forum, it seems that the range will probably be a lot more than the nominal 20 NM from station. Anyone on here in ATC who knows more about this? Edited December 10, 2020 by Garfly
RFguy Posted December 10, 2020 Posted December 10, 2020 Well they should be because they transmit on 1090 MHz.
Garfly Posted December 10, 2020 Posted December 10, 2020 But I was surprised to hear that they are invisible to ATC in the UK.
Downunder Posted December 10, 2020 Posted December 10, 2020 (edited) 6 hours ago, jmal said: I was hoping ADSB out would allow me to be identified and transit controlled airspace ...but that is not the case. In Australia, skyecho is not allowed to be used in controlled airspace. It must be a Mode S transponder.... Perhaps the UK, being substantially smaller, primary and secondary radar do the job? As I understand it, most of the UK airspace is "controlled" anyway. Whereas most of Aus is class G. https://www.airservicesaustralia.com/about-us/projects/ads-b/ads-b-coverage/ Edited December 10, 2020 by Downunder
Garfly Posted December 10, 2020 Posted December 10, 2020 But at least ATC should be able to identify you in times of trouble. I wonder if they'll get around to accepting these devices for the purposes of flight following. I guess they'd want to see how they work in practice first. Also there are times when you need/want to advise ATC of your position/intentions when skirting OCTA, so it would be nice to know that you are conspicuous to them. This VFR route south west of Canberra between Cotter and Tharwa is an example of being required to advise even OCTA.
RFguy Posted December 10, 2020 Posted December 10, 2020 Mode S extended squitter transmits with the DF17 protocol. IE mode S transponder with ES-ADSB-OUT) ADSB OUT devices transmit with DF17 or DF18 protocol, usually. DF18 is also transmitted on 978 by UAT capable transmitters. there are a few sub classes of ADSB messages. Maybe the ATC doesnt decode ADSB or broadcast ext-sq,ie only decodes interrogated sensors . Have to do some reading @Downunder, where did you find this information you quoted- "In Australia, skyecho is not allowed to be used in controlled airspace."???? - a link please.??????
Garfly Posted December 10, 2020 Posted December 10, 2020 (edited) CASA, details that restriction in ADVISORY CIRCULAR AC 91-23v1.0: (In this table alongside "Integrated TABS; SIL>1") Edited December 10, 2020 by Garfly
RFguy Posted December 10, 2020 Posted December 10, 2020 That's my understanding also. There is some concern that ADSB devices (non interrogated, unlike a Mode S 1090ES) will generate alot of extra signal clutter and congestion. Hence, that is why there is the use of ADSB on 978 MHz, (IE away from the busy 1090 MHz used for Mode A,C,S) The Mode S system can tell a sensor in an aircraft to shut up, also. useful for reducing congestion. Generally , you want a Mode S 1090ES+ADSB mode transponder for lurking around in CTA/ CTZ. Not sure if SkyEcho performs functions of TCAS etc, or emulation. I think it is only a pure ADSB-IN (displaying other aircraft 1090ES-ADSB transmissions) and ADSB-OUT broadcasts. TCAS systems actually interrogate each other. I am absolutely positive that ATC can see ADSB-OUT transmissions from SKyEcho. There isnt much difference with 1090ES transmission.
Kyle Communications Posted December 10, 2020 Posted December 10, 2020 I am led to believe yes you can been seen by ATC because that is why you need the hex code for it as it goes into the system so you can be seen. TCAS in another aircraft will not see you apparently as it is the type that it is here The restricted power and radiation of the Skyecho will drop in and out of the ATC ground stations but they will still register on their system because you are outputting a ID that they give to you
Downunder Posted December 10, 2020 Posted December 10, 2020 35 minutes ago, RFguy said: @Downunder, where did you find this information you quoted- "In Australia, skyecho is not allowed to be used in controlled airspace."???? - a link please.?????? A quick search. VFR aircraft- a rule of thumb.....
RFguy Posted December 10, 2020 Posted December 10, 2020 Mark is correct The only difference between what a ModeS transponder with ADSB-OUT (1090ES) generates (DF17 frame) , and what the SKyEcho transmits (DF18) is that the format flag is set such that it can inform the receiver that the device cannot be interrogated. WHile it's possible ATC might have their equipment set to deliberately ignore DF18 frames, I cannot think of why they would...
RFguy Posted December 10, 2020 Posted December 10, 2020 (edited) And Downunder, I think you have interpreted that page the wrong way. What it means for VFR : - you must have a transponder in CTA (Mode A, C or Mode S) - new transponders MUST be Mode S. you cannot put a old A/C transponder in if your old one fails - EC devices like Skyecho DO NOT REPLACE the transponder requirement for CTA CTZ Edited December 10, 2020 by RFguy 1
Downunder Posted December 10, 2020 Posted December 10, 2020 (edited) It's about "quality control ". You can't just let any random device into controlled airspace....... where there are potentially hundreds of lives on the line. Edited December 10, 2020 by Downunder
