"The "problem" at the moment is that aircraft using the same airspace can be on one of 5  frequencies - all legitimate. There is also a sixth legal option - no radio at all (crazy for congested airspace)"
I have come up with a proposed solution to the above insanity ;
One frequency for ALL VFR aircraft operating, below the CTR steps, outside the current Controlled GA fields of Bankstown & Camden, above (Circ alt +500ft) & away from (3-5 Nm) the non controlled Circuits  of The Oaks, Mittagong, Wedderburn and may be  Shell Harbour. The outer boundaries would have to be decided on.
The existing frequencies would remain BUT only be used within the Circuit area and for 10 Nm Inbound calls.
In my mind this is a simplification that reduces risk by having all (non Circuit)  aircraft on the one operational frequency.
The requirement to maintain a listening/monitoring watch on Area frequency, would also remain, allowing ATC to  make contact with the PIC (& visa versa) and for the PIC to maintain situational awareness of any IFR operations.
Remember, I also think, that as a minimum standard, ALL aircraft, within this operational boundary should be fitted with a dual channel transceiver and SE2 (or similar) ADSB In/Out.
What do you suggest???
Fortunately I don’t have your problem but your suggestion makes sense to me. It’s hard enough to be swapping frequencies when you cross boundaries but if you can be on the correct frequency and be different to the aircraft around you then there will never be clear lines of communication.
I do not have a suggestion for the Sydney metro airspace due to the complexity of the current airspace, number of frequencies currently  and procedures currently in use for both Mascot and Bankstown. I expect this to get worst when Western Sydney becomes more active.
All of the aircraft I have flown have radio receivers capable of monitoring 2 frequencies.
I agree in/out ADS-B transponders for all aircraft are a very good idea.
CASA has already said you need a minimum of a mode C transponder to enter controlled airspace.
ie more than a SE2 is required for this airspace.
You have offered a suggestion.
I have suggested that this will make the current bad situation even worse.
We obviously do not agree.
If it's any help, the 2026 Visual Flight Rules Guide, in Chapter 5, Page 349 has 74 pages which include:        Communication Rules        Standard Templates        Equipment Requirement.
Its absolute fine that we disagree.
Unfortunatly your rational for doing so is wanting, in that you continue to bring Controlled Airspace into the debate, when its clearly not part of my concern.
The aircraft using the two major airports, Sydney & Badgerys Creek ("metro"?), are usually above 10,000 ft, in the area I am addressing ie no issue.
Bankstown & Camden are also Controlled, both of these facilities host very active training operations and large GA fleets. How these aircraft communicate when approaching/in their Controlled Circuit area, is also not of my concern (they use their discreet radio frequencies).
I am concerned with the communication of aircraft that currently use the Uncontrolled Airspace. in the area directly to the south of Greater Sydney. Its always been congested. With the changes to the CTR boundaries, to facilitate Badgerys Creek, its got worse.
The aircraft, using this area, are are predominantly flying to/ from Bankstown, Camden, The Oaks /Mittagong (same CTAF), Wedderburn & I presume Shell Harbour.
It would seem that the PIC/Student remains on or switches to, their airfield frequency while in the congested area.
This means that the aircraft PIC can not communicate with other aircraft that are in very close proximity.
The solution would seem to be, get them all on the same frequency, once outside their Circuit area.
14 hours ago, BurnieM said:
I thought the problem you were trying to fix was The Oaks/Camden communication omissions ?
Since Western Sydney went live we also have a Bankstown training aircraft/Wedderburn problem.
Creating another frequency (low level area) on top of CTAFs and area freqs creates another level of confusion likely leading to even more communication omissions.
what a busy area to operate in.   wouldn't suprise me if casa kick all rec pilots out of the sydney area eventually.  they don't like us to start with.
Turbs, it's no surprise that you tend to see the solution to all problems as a recourse to Rules. That is, that rules rule.
And though most of us do love the VFG and accept that aviation rules are written in blood, your suggestion really is not of any help.
After all, Skippy's whole premise here is that certain Rules as they exist, in a changed world, risk actually drawing blood if not challenged and changed:
'the "problem" at the moment is that aircraft using the same airspace can be on one of 5  frequencies - all legitimate. There is also a sixth legal option - no radio at all (crazy for congested airspace)'
So you may disagree but I think not on the dodgy premise that 'rules rule, okay!?'
Edited by Garfly
I take it you don't fly because everyone knows the what the VFRG is for.        Skippy can contact Airservices, who may already have a solution; there are plenty of complications in other cities like this with two major Airports in Melbourne against against each other plus a Light Aircraft Lane. They may revert everyone to Controlled Airspace and manage all aircraft, or they may Control two and leave three to work with each other. Or some of the five may be making unnecessary calls. Airservices will sort it out.
 Some radios Permit the selection of the Next frequency. A good thing is to leave the Previous one still there till you establish contact on the Next one. Confusion on frequencies is dangerous an distracting and increases Workload.  Prepare and Plan the flight with frequencies listed alongside  waypoints. Be as organised as Possible . P.P.P.P.P.P, Proper Planning Prevents Piss Poor Performance..  Nev
