Riley Posted July 27, 2020 Posted July 27, 2020 Gentlemen (and Ladies) I'm seeking informed response as to what is the most successful and long-lasting, clear gap-seal tape for use on painted fabric aileron and empennage surfaces. Advice on your experience (good/bad) and supply source with a good/best Australian procurable seal stripping would be very much appreciated. Tks in anticipation. Riley.
Old Koreelah Posted July 27, 2020 Posted July 27, 2020 (edited) Riley I too am interested in gap tape. What I have discovered is the width of your gap is an issue; the stuff used for sailplanes won’t bridge the 20+ mm gap on my fabric wing. I currently have bookbinders tape across the space between each panel (applied from underneath). It’s wide and sticky enough and flexible, but collects an unsightly strip of crud. Edited July 28, 2020 by Old Koreelah
Kenlsa Posted July 28, 2020 Posted July 28, 2020 I used a 3m product ( can't remember the name or code though) and bought it in a crash and paint supplies outlet and is 50mm wide. It is clear and is used for stone protection along the bottom car sill. On a 7m roll from memory. I used it for leading edge of the stab for stone protection. It is very flexible and will work for a gap seal. Ken 1
Paul davenport Posted July 28, 2020 Posted July 28, 2020 Leuko silk, available from pharmacies, sticks well, comes off when you want and not before
skippydiesel Posted July 28, 2020 Posted July 28, 2020 First of all you might like to research "gap seals" there are quite a few different types - not all are sticky tapes. Of the sticky tape variety - the best (most flexibly, longest lasting and the least likely to leave difficult to remove residue ) that I have come across, is sold by Premium Gap Seal Tape. It comes in a selection of widths any colour you like as long as its white. Bunnings sell a very similar product in about 50 mm width but have not tried it (yet). I have had good success using "Mylar" strips on my ailerons - very effective, durable and almost invisible. 1
Flightrite Posted July 28, 2020 Posted July 28, 2020 A mate if mine has what appeared to be Mylar strips painted the same as the plane that are glued on the wing ahead of the ailerons and on the tail-plane ahead of the elevators, they simply rub on the moving control surfaces, upper only, factory fitted and after 7 years and 500 hrs look like new!
skippydiesel Posted July 28, 2020 Posted July 28, 2020 A mate if mine has what appeared to be Mylar strips painted the same as the plane that are glued on the wing ahead of the ailerons and on the tail-plane ahead of the elevators, they simply rub on the moving control surfaces, upper only, factory fitted and after 7 years and 500 hrs look like new! In my "home" install I have Mylar on Mylar - that is the flexible seal "rubs" on another Mylar strip. Ideally the gap to be sealed is on the underside, as high pressure air "leaks" up to the low pressure on he upper wing surface. Compromises in this objective must be made according to the design of your control surfaces, sometimes the seal can only be on the upper side. Again in my install - my aileron hinge is offset on the upper side, so I have my aileron seals on the upper side BUT they are actually fixed on the lower side of a handy "ledge" so the higher pressure air presses works to improve the sealing effect. The flexibly seal is glued to the non moving wing ledge, the "wear" strip to the aileron ledge. After 3 years, all working as I would have hoped, with no sign of abrasion or loss of efficacy. 1
Bruce Tuncks Posted July 29, 2020 Posted July 29, 2020 The Jabiru kit came with a big roll of wide white reinforced "aileron " tape. You can get the same stuff it a hardware shop. it has a cloth weave showing through a plastic surface. Some years ago, I was doing an annual on a grob single seater glider and I couldn't find the proper tape ( German stuff we had bought from Harry Schneider) so I used this instead... BIG MISTAKE! Over a year, the tape I had used gradually shrank and it eventually stopped full control deflection. The stick still moved fully cos the pushrods flexed. The pilots didn't notice since they were first solo types. Gosh I was pleased to be the one who noticed the problem. On the Jabiru, that tape is on the underside while on the glider it was on the top... big difference to UV exposure. 2
Riley Posted August 3, 2020 Author Posted August 3, 2020 Thanks for the info Gents. Looks like Mylar is the most suitable. Can anybody point me in the right direction for a supply source in OZ that sells the strips and relevant safety and transfer tape by the meter rather than 33meter rolls? Tks Riley
skippydiesel Posted August 6, 2020 Posted August 6, 2020 Thanks for the info Gents. Looks like Mylar is the most suitable. Can anybody point me in the right direction for a supply source in OZ that sells the strips and relevant safety and transfer tape by the meter rather than 33meter rolls? Tks Riley I initially tried to get my Mylar from overseas and got caught up in the need to demonstrate that my aircraft manufacturer (its a kit) officially accepts the fitting of such devices. So I ended up finding an Australian print house that uses Mylar film in its systems. They not supplied but cut it into strips of the requited width(s). I used a 3M double sided tape to affix the Mylar strips. 1
Riley Posted August 6, 2020 Author Posted August 6, 2020 I initially tried to get my Mylar from overseas and got caught up in the need to demonstrate that my aircraft manufacturer (its a kit) officially accepts the fitting of such devices. So I ended up finding an Australian print house that uses Mylar film in its systems. They not supplied but cut it into strips of the requited width(s). I used a 3M double sided tape to affix the Mylar strips. Thanks SD. I'll ultimately resort to that if I can't get the curved 'real thing' cheers
skippydiesel Posted December 16, 2020 Posted December 16, 2020 On 06/08/2020 at 11:43 PM, Riley said: Thanks SD. I'll ultimately resort to that if I can't get the curved 'real thing' cheers Riley - did you ever find a cooperative supplier ? Australia ? USA? Europe ?
trailer Posted March 22, 2023 Posted March 22, 2023 Along the lines of my post earlier, can anyone dirct traffic to an aussie supplier?
Blueadventures Posted March 22, 2023 Posted March 22, 2023 31 minutes ago, trailer said: Along the lines of my post earlier, can anyone dirct traffic to an aussie supplier? Ask the Glider people they use it. Maddog Composites is one gilder detail repair shop I know of. 1
skippydiesel Posted March 22, 2023 Posted March 22, 2023 14 hours ago, trailer said: Along the lines of my post earlier, can anyone dirct traffic to an aussie supplier? Reference: Australian Supplier of Gap Seal/ Gap Tape Have no up-to-date advise re purpose made stuff - I purchased my Gap Tape from good old Uncle Sam (I think it was https://wingsandwheels.com/gap-seal-tape.html) and my Mylar Gap Seals from a cooperative Sydney print shop (they had to cut it to width for me). I see that Bunnings Aerospace has a wide selection of tapes - at least one of which is clear (also white) and comes in about 50 mm width - may worth looking at/giving a try.
