Lyndon Posted November 4, 2015 Author Posted November 4, 2015 No worries. Thanks. Where about s in the rear of the fuse
rick morawski Posted November 5, 2015 Posted November 5, 2015 No worries. Thanks. Where about s in the rear of the fuse where abouts what? me no undystandy
Lyndon Posted November 5, 2015 Author Posted November 5, 2015 Where does it come out on the rear fuse skin
rick morawski Posted November 5, 2015 Posted November 5, 2015 Where does it come out on the rear fuse skin here, the dimensions in the picture are where you drill a hole, put a grommet in then the wire thru.
Kyle Communications Posted November 5, 2015 Posted November 5, 2015 Lyndon...have you actually read the manual?....you should read it section a couple of times BEFORE you do anything...you need your brain to translate the italian english.....I know its a pain but it helps you understand what you are doing 1
Lyndon Posted November 5, 2015 Author Posted November 5, 2015 Yep. My kit has the small trim tab in the manual. But the kit is supplied with the later trim. It also has some parts of the smaller trim. Thus my manual shows a complete different way to wire it. But then in another section it has the later wiring. My top skin has hole already in it for the grommet and wire. But it is in the very rear. Double checking before I go drilling again. Reg has informed me the manual for the vg was much improved for the xl. I think my kit and manual is during a time of change. But I do ask a lot of questions. Thanks Lyndon
Lyndon Posted November 6, 2015 Author Posted November 6, 2015 Conformation that the angular is on the outside. Yes I looked and the manual is not clear at all. Thanks
eightyknots Posted November 20, 2015 Posted November 20, 2015 Conformation that the angular is on the outside. Yes I looked and the manual is not clear at all.Thanks Is the ItalanianoEnglish still hard to follow?
Lyndon Posted November 20, 2015 Author Posted November 20, 2015 I think it's just not a real good manual. Be fine if you had a built a few or with friends that had. Getting by though quite well. Lyndon
rankamateur Posted November 20, 2015 Posted November 20, 2015 Is the ItalanianoEnglish still hard to follow? This kit has been sitting around for a long time and the language in the manual hasn't benefited from the revisions that have taken place over that time. the current manuals have 3D drawings and much clearer Italglish descriptions. Remember the advice about the picture when supplied being over the page, then it becomes much more useful. 1
Lyndon Posted November 20, 2015 Author Posted November 20, 2015 I'm having a break for a few weeks. Been bike riding and then hopefully in a few weeks my engine arrives. Then I can spend a few weeks on that. Be nice not to prime and rivet for a bit. Lyndon
Lyndon Posted November 24, 2015 Author Posted November 24, 2015 Looks tight and needs to bent quite I bit to get the angle ??? Am I on the right track or ???? Thanks Lyndon
rick morawski Posted November 24, 2015 Posted November 24, 2015 Yes, needs a bit of caressing into position.
Lyndon Posted November 24, 2015 Author Posted November 24, 2015 Ta I have worked out it needs to on the rear as per the cut outs on the down sides of rib 8
Lyndon Posted November 24, 2015 Author Posted November 24, 2015 Little unclear here. The top skin is attached to something at a later stage. The top bracket is to be fitted now. Looks like the top skin is bent up and riveted to the top bracket in the corners ???? True or false ??? Lyndon
rankamateur Posted November 24, 2015 Posted November 24, 2015 Cabin frame tubes go in that gap where your finger is. 1
Lyndon Posted November 24, 2015 Author Posted November 24, 2015 So the way I have it now is correct. The manual generally has diagrams with how brackets and sheets are lined up but with this top bracket the manual is quite unclear. The frame tubes fit perfectly as I have them now. Thanks Lyndon
Lyndon Posted November 24, 2015 Author Posted November 24, 2015 Nothing conclusive bin the manual at all. But in my build video pics I was right first time. It goes on top . Thanks Lyndon
eightyknots Posted November 24, 2015 Posted November 24, 2015 Nothing conclusive bin the manual at all. But in my build video pics I was right first time. It goes on top .Thanks Lyndon Homebuilt Help produces quite a few videos, mainly for Zenith aircraft. Is there a build video for the Savannah too? Who produces this?
Lyndon Posted November 24, 2015 Author Posted November 24, 2015 I have Reg s video. Two builds. One shows this
