Measure the shaft of a small screwdriver! if you can find ones that have 1/8" and 5/32" shafts get them on the grinder and grind the tip down to a gentle taper. No real need to make a sharp point. When you are using them aligning sheets to the holes in the frames take care not to tear at the holes in the sheet. Work along the frames so any one hole doesn't have to cop all the load.
  • Replies 683
Will do at bunnings now. My tyres arrived from the states today. Happy as. $40 bucks from USA to Adelaide. Have to be happy with that.
Time to drill another rivet I think. The bottom lonererons are side specific. On these the rivets are off set except where a rib joins them. See pic one. Now on the rib a where it meets the longeron at rib a the holes are off set. There is no way in the world I can rivet the rib to the longeron see pic two. Thinking just drill another hole for an extra rivet. Thoughts.
Lyndon
I agree. Havnt drilled it yet. Having another look and running a measure over skin vs the holes. The tape is telling me I will fit. Time to have a cuppa
I dip all my rivets in the same two pack primer. I'm thinking that should work ???
Lyndon
Does two pack primer handle a long period before applying the top coat? I thought it had to go on right before the top coats.
Correct. Thus the longeron is only primed on the inside. The outside will be rubbed and primed just prior to painting.
Lyndon
You seem to be racing along, Lyndon. Soon there won't be a requirement to re-prime the parts as you will be painting the aircraft before long.
Yep but I can't do the wings yet as I'm waiting on tanks
Also, you're pretty ambitious, I see all your potential flying destinations, neatly written on that chair near the wing frame!
Well I was to have the colour on the rudder alerons stabilizer elevator and fin but I'm waiting on my solid rivet dies to finish them. I've done my wheels and landing gear and struts in colour. I may have an engine fingers crossed.
Lyndon
I think I have the fuse sorted. Those home made bars did the trick. Most of the issues at the front with double longerons. Off to Melbourne now so Monday I reckon I can rivet it all up fingers crossed. Best part of a week setting up this fuse.
Lyndon
I have looked everywhere in my manual. No mention of fit these or even a pic. I can find them in the parts list. Sg011 x2. They look like they belong here and hold the inspection panel. Am I correct ???
Lyndon
I have looked everywhere in my manual. No mention of fit these or even a pic. I can find them in the parts list. Sg011 x2. They look like they belong here and hold the inspection panel. Am I correct ???Lyndon
Yes correct, they are the aileron horn stops, see control section.
Flush a5 rivets in this section. I can't seem to find any in my kit but a bigger concern is that can one really make it truly flush. Why wouldn't I drill another two holes in the bottom plate and just rivet it all with a5. From what I can see they must want the upper hinge captive ??? Lyndon
I've run out of the long 1/8th rivets for the fuselage bottom. Are these specific or can I just buy them locally.
Lyndon
Flush rivets are countersunk rivets, they will be there next to the A3 rivets you couldnt find. Have another mummy look.
What I do is get everything thats in a plastic bag like nuts, bolts , rivets etc and stick them up on a board with drawing pins, lined up with each box they came out of. if you take it off the board you mark the board where it was so you know you actually had it. It works, all the little bags are there to see, no searching. Honestly every person who has built a kit (including myself) has sworn there's something missing, only, embarassingly, to find it later on down the track.
they are Avex rivets 01661-00416
Easy to get them off Reg at Aerokits or
Infastech (Australia) Pty Ltd
891 Wellington Road
Rowville, Victoria 3178
Tel: +61 3 9765 6400
Rick
Very true. But I can't find a5 flush rivets yet. But saying that I have found every thing else I couldn't find.
Lyndon
