  • Replies 683
I got all tank fittings pre assembled from icp with holes for tanks and sight gauge.
Australia don't want this?
Had a quick look but can't find it. Take it this is a tool for adjusting something ??? Much later in the build.
Lyndon
Had a quick look but can't find it. Take it this is a tool for adjusting something ??? Much later in the build.Lyndon
Flap/Ailerons fine adjustment.
Just learnt something. I bought the upgraded trim tab kit. Primed it and I'm now fitting it. It's exactly the same as my kit. Bugger . Anyway with the 15 and 16 mm of movement on the tab. Can I just power up the unit safety or do I have to wait till the plane is ready to fly and adjust it. Be a lot easier to it while I'm building it on the bench.
Lyndon
Same I think. 5 wires. Earth and an up and down I take it. ??? Anyone know the colours
Lyndon
Two white wires. Just reverse the polarity. 9 volt battery will even work
too long ago to remember the colours...You just work it out from the paperwork.
Mine uses a Ray Allen servo out on the end of the tailplane
I thought the VG had a separate trim tab and the servo was under a cover in the tailplane...yours may very be a antiblance tab then like the XL
So did I. Mine has a full a full length tab and mounts on the side in the kit ???
Ok maybe they upgraded the later VG kits to the XL style or the other way around...they bought the later version VG style across to the XL and S models
Tab that I had all along. I'm not the smartest but the manual isn't real good
Holes don't match. Before I drill it. One is Bush size one is bolt size .
Thanks Lyndon
Next issue is the elevator rubs on the stabilizer. Can't see why or an easy fix other than a mallet. Just scuffs as it cycles
Lyndon
Just rubs on the rivet. My concern is its so close. In the air with load on it it may still rub without knowing how much clearance should be there while static. I would have thought about 3 or 4 mm minimum. I have zero now so it's a lot to find .
