flying dog Posted October 26, 2009 Posted October 26, 2009 I have a plane I like to fly, but every time I load it, it is full trim back. So I have to remember to trim it to the middle before take off. Yeah, pre-take off check. BUT! It has (originally) got no trim indicator. Got one now. ;) But where is the setting in the file (which ever one) to give it full trim back?
F22 Posted March 9, 2010 Posted March 9, 2010 Are you trying to change the default trim setting? What flight sim are you using, lol
maddogmorgan Posted March 9, 2010 Posted March 9, 2010 If you are using FSX, load up your aircraft, set the trim, and all the other things you want eg: If you want to do a complete start up from cold and dark turn everything off etc I haven't played with FSX for awhile but you then hit 'ALT' I think from memory...save this as a default flight...from then on in whenever you start FSX regardless of airport etc your plane will be as you left it.
allanw Posted March 22, 2010 Posted March 22, 2010 The instructions MadDog has given you should also work for fs9.
