That's the one, Peter. Latvian designed and built, flew with Soviet markings after the Soviet occupation, then with German markings after the German invasion.
Sorry Willie, I cheated. (Hehee). I used Google Image Search.
And I erased the prefix lettering and everything.
Ok, how about this one - not overly successful either.
I've found it, but I'll let someone else have a crack at it.
Front end looks like a Polikarpov (sp?) but the rear end looks a bit spindly.
[ATTACH=full]44913[/ATTACH]
OK. It's been a cuppla hours. So here it is.
Grigorovich IP-4 (DG-53)
Correct, Peter.
I think the IP-4 had four 45mm. cannons and the first prototype tried two 75mm. cannon. They say that's why the horizontal stabilizer is so high, to avoid the cannon gases.
Cheers, Willie.
Enough of prototypes - this one was an operational warbird.
Apologies for the low resolution.
OK I'm out. Beats me.
Looks very much like a Focke-Wulf Fw190, but the 190 doesnt have a bracing strut uder the tail.
It's not Russian. Same company, post war, made some agricultural aircraft and light sports/trainers. Pre-war production was mainly fighters.
Ok, no takers - it's a Romanian I.A.R.81. I think at some stage during the War I.A.R. also license built Messerschmitt Bf-109's.
Interesting, Willie. When I googled I.A.R.81, I found your photo, only a mirror image. Funny the Image Search couldn't locate it. Looking at photos from other angles, it looks like the pilot could almost see the u/c under the wing.
I'll have to fess up, Peter. I removed the markings and reversed the image to make it a bit trickier. So the image you found was the original.
Had a look at other photos, and I see what you mean about the undercarriage.
Cheers, Willie.
What a cunning stunt. What willedoo next?
He is a stunning... er... bloke.
Don't know if this one's been shown before.
looks a lot like a Globe Swift- maybe a early prototype?
Tail is wrong shape and cowl a bit weird but?
Started out as a high performance (for it's time) two place retractable under one name. Taken over, upgraded to four place under a different name. This is the four place. Enough hints.
