danstee Posted July 6 Posted July 6 I’m pretty sure I have the oil pressure and oil temperature senders, but what is the sensor just below the silver oil pressure sender?
skippydiesel Posted July 6 Posted July 6 My guess its oil temperature. Is it possible you have two or that the other (not pictured) is something else like CHT?😈
Kiwi Posted July 6 Posted July 6 (edited) 3 hours ago, danstee said: I’m pretty sure I have the oil pressure and oil temperature senders, but what is the sensor just below the silver oil pressure sender? The lower oil pressure switch starts the Hobbs Meter on my Rans S6S. The one on the sump would definitely be temperature. I can look for the wiring diagram if you need it. Edited July 6 by Kiwi
BrendAn Posted July 6 Posted July 6 4 hours ago, danstee said: I’m pretty sure I have the oil pressure and oil temperature senders, but what is the sensor just below the silver oil pressure sender? temp
Kiwi Posted July 6 Posted July 6 (edited) I think he is talking about this one. But I'm thinking about a Rotax engine, not a Jabiru. Edited July 6 by Kiwi 1
danstee Posted July 7 Author Posted July 7 Thanks Kiwi, that’s exactly the question - I couldn’t edit my photo otherwise I’d have done exactly what you did. A switch for an hour meter is an interesting idea. It’s possible - does anyone know if that is common? Or maybe a low pressure alarm? Could I replace it with another oil pressure sender and use it with the EFIS? so many questions 1
T510 Posted July 7 Posted July 7 Could be a low oil pressure light sender, only way to be sure would be to trace the wire back to the other end, or unplug it and see what stops working 1
440032 Posted July 7 Posted July 7 I have a low oil pressure sensor for cockpit red light, right there. 1 1
Kiwi Posted July 7 Posted July 7 If it is the hour meter (sounds like it might for the idiot light) and you want to use the port for something else, this is how Rans now run the hour meter.
