BurnieM Posted 5 hours ago Posted 5 hours ago https://www.australianflying.com.au/latest/casa-working-group-recommends-changes-to-class-5 "CASA this week published the deliberations of a Technical Working Group (TWG) that has recommended several changes to the Class 5 medical standard limitations, but will leave the 2000-kg restriction in place. The TWG met in November last year under the supervision of Principal Medical Officer Kate Manderson, making several recommendations to CASA through the Aviation Safety Advisory Panel (ASAP), which, if accepted, could see modifications to most of the restrictions applied operations under the Class 5 self-declared medical. Among the key recommendations are: the 2000-kg MTOW limit remain in place POB limit of two be increased to four the 10,000-feet altitude limit remain in place, but be reviewed under the Class 4 framework controlled airspace access remain in place aerobatics be permitted provided the aircraft has no passengers and not be flown in competition or air shows day VFR only be retained, but IFR be reviewed under the Class 4 framework formation flying be permitted provided with one passenger only and not in air shows or flying displays the requirement for a Class 5 candidate to never have been refused a CASA medical be removed the ban on medical stimulants to treat ADHD be removed." 7
BurnieM Posted 4 hours ago Author Posted 4 hours ago CASA working group report; https://www.casa.gov.au/sites/default/files/2026-04/class-5-pir-twg-report-19-november-2025.pdf 1
Thruster88 Posted 1 hour ago Posted 1 hour ago This all sounds like a serious case of common sense prevailing. 1 2
Headwind Posted 1 hour ago Posted 1 hour ago I’m trying not to be sceptical but it certainly looks promising. Let’s hope Santa doesn’t disappoint. 1
BurnieM Posted 1 hour ago Author Posted 1 hour ago 11 minutes ago, Thruster88 said: This all sounds like a serious case of common sense prevailing. These are only recommendations at this stage. As the CASA PMO was there hopefully most of this actually happens. But we are talking about CASA ....... 1
facthunter Posted 1 hour ago Posted 1 hour ago The Logic behind some of that thinking is a bit amusing but there is a Problem there that Needs to Be addressed so ANYTHING that helps is something You CAN build a Plane without Understanding Much about structures stress and deformation Shear. Tension and compressive loads Flutter and Many other things You need to Know Proper repair techniques for all manner of defects. Building it doesn't ensure any of this. You don't need Jigs for an RV. The Preformed Rivet Holes align it. Nev 1
