Im pre wiring my wings and fuselage for a tail and wing tip lights. In not running any lights but want the wire for future proofing for LED lights
Do I need some or all shielded.
20awg with 4 to 5 wires in each run.
Any advice would be great
Lyndon
Assuming you are only using LEDs (ie low current, low voltage), then you don’t need shielded. Of course, the other option is to just run a string through lightweight corrugated conduit, and then you can pull through whatever wires you actually need when the time comes.
Hi Lyndon,
i suspect that to prewire or not is entirely a decision for you.
As for shielded wire - LED aircraft light suppliers would be your best informer. In the past (old tech?) I have read of light systems that caused radio interference.
Three questions for you;
  • Why 5 wires?
  • Why do you think you might add lights at a later date?
  • What is the aircraft?
Kitfox.
I don't intend on having the aircraft long-term. The next buyer may want it.
If they wig wag I think 5, if not definitely 4.
I've decided on two wires just for lights. ( Not used)
I will have star burst LED under the plane installed and leave it at that I'm thinking.
Thanks Lyndon
Edited by Lyndon
I used the existing wing tip nav light wire to pull more wires through the wing on my RV to install a tailbeacon x in the wing tip.
